[NEW BSP] Mbed lpc1768 board
Marcos Díaz marcos.diaz at tallertechnologies.com
Fri Jun 6 14:47:09 UTC 2014
If you prefer we could make it more suitable to RTEMS coding style.
Which examples can we get of it?
Thanks!
On Fri, Jun 6, 2014 at 11:31 AM, Sebastian Huber
> On 2014-06-06 16:25, Marcos Díaz wrote:
>> Sorry, i didn't understand what is the new coding style we are adding.
> You use for example four space characters for indentation and sometimes
> align function parameters in this way
> +static inline uint8_t lpc176x_uart_get_register(const uintptr_t addr,
> +        const uint8_t i)
> +    volatile uint32_t *reg = (volatile uint32_t *) addr;
> +    return (uint8_t) reg [i];
> or this way
> +rtems_status_code lpc176x_gpio_config(const lpc176x_pin_number pin,
> +                                      const lpc176x_gpio_direction dir)
> You use
> +    if ((pin < LPC176X_MAX_PORT_NUMBER) && (dir <
> LPC176X_GPIO_FUNCTION_COUNT))
> +        const lpc176x_gpio_ports port = LPC176X_IO_PORT(pin);
> +        const uint32_t pin_of_port = LPC176X_IO_PORT_BIT(pin);
> and also
> +    for(i=0; i < function_vector_size; ++i)
> so not "for (".  Sometimes a space between operators, sometimes not.
> You use
> +    typedef struct
> +         * @brief Pin board.
> +        lpc176x_pin_number pin;
> +         * @brief A function that attends an interrupt for 'pin'.
> +        lpc176x_gpio_interrupt_function function;
> +    } lpc176x_registered_interrupt_function;
> So all in all is different to what we have, but we have so many styles in
> the BSP area, it doesn't matter.
______________________________
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
