[NEW BSP] Mbed lpc1768 board
Marcos Díaz
marcos.diaz at tallertechnologies.com
Fri Jun 6 15:36:55 UTC 2014
Now we see that the coding style wiki page was updated. we will follow
that guideline, and see if we could configure the astyle tool to meet
those parameters. Thanks for all!
On Fri, Jun 6, 2014 at 11:47 AM, Marcos Díaz
<marcos.diaz at tallertechnologies.com> wrote:
> If you prefer we could make it more suitable to RTEMS coding style.
> Which examples can we get of it?
> Thanks!
> On Fri, Jun 6, 2014 at 11:31 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 2014-06-06 16:25, Marcos Díaz wrote:
>>> Sorry, i didn't understand what is the new coding style we are adding.
>> You use for example four space characters for indentation and sometimes
>> align function parameters in this way
>> +static inline uint8_t lpc176x_uart_get_register(const uintptr_t addr,
>> + const uint8_t i)
>> + volatile uint32_t *reg = (volatile uint32_t *) addr;
>> + return (uint8_t) reg [i];
>> or this way
>> +rtems_status_code lpc176x_gpio_config(const lpc176x_pin_number pin,
>> + const lpc176x_gpio_direction dir)
>> You use
>> + if ((pin < LPC176X_MAX_PORT_NUMBER) && (dir <
>> LPC176X_GPIO_FUNCTION_COUNT))
>> + const lpc176x_gpio_ports port = LPC176X_IO_PORT(pin);
>> + const uint32_t pin_of_port = LPC176X_IO_PORT_BIT(pin);
>> and also
>> + for(i=0; i < function_vector_size; ++i)
>> so not "for (". Sometimes a space between operators, sometimes not.
>> You use
>> + typedef struct
>> + * @brief Pin board.
>> + lpc176x_pin_number pin;
>> + * @brief A function that attends an interrupt for 'pin'.
>> + lpc176x_gpio_interrupt_function function;
>> + } lpc176x_registered_interrupt_function;
>> So all in all is different to what we have, but we have so many styles in
>> the BSP area, it doesn't matter.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> ______________________________
> Marcos Díaz
> Software Engineer
> San Lorenzo 47, 3rd Floor, Office 5
> Córdoba, Argentina
> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
> Skype: markdiaz22
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
