[rtems-testing] Patch to the merge-helper script
Martin Boretto martin.boretto at tallertechnologies.com
Thu Jun 26 14:21:36 UTC 2014
Ping for maintainer...
diff --git a/merge-helpers/check_submission b/merge-helpers/check_submission
index a934646..5444b1b 100755
--- a/merge-helpers/check_submission
+++ b/merge-helpers/check_submission
@@ -198,10 +198,8 @@ function check_methods(){
            echo $bsp : ${i%(*}"()" present in file $(grep -rlE
"[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *)
           fi
        else
-          if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq
"1" ]]; then
            echo "$bsp : $(basename $filename) : ${i%(*}() function does
not exist in $filename "
            flag="1"
-          fi
            faults="1"
        fi
      fi
@@ -687,4 +685,6 @@ start "$@"
# End of Checks
if [[ $faults -eq "0" ]] ; then
  echo -e "\nNo faults found in BSP organization"
+else
+  echo -e "\nFound faults in BSP organization. Please, check"
fi
Regards.
Martin Boretto
Software Engineer
Taller Technologies - Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
*Mobile:* [+54 358 4206995 (ARG)]
*Skype:* tinacho_b
2014-06-04 18:21 GMT-03:00 Martin Boretto <
martin.boretto at tallertechnologies.com>:
> Hi everyone,
> This patch fixes a possible issue.
> When a needed function is not found it didn't show the warning but it
> still put the faults variable to 1.
> With this patch I propose to always see the warning and set the faults to
> 1. Also set an ending message saying when not everything went fine.
> Martin Boretto
> Software Engineer
> Córdoba, Argentina
> *Skype:* tinacho_b
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140626/7929ba7b/attachment-0002.html>
