[PATCH 2/4] score: SMP initialization and shutdown changes
Sun Mar 2 23:08:51 UTC 2014
On 27/02/2014 8:09 pm, Sebastian Huber wrote:
> On 2014-02-27 09:16, Chris Johns wrote:
>> On 26/02/2014 7:43 pm, Sebastian Huber wrote:
>>> First some words to this patch set.  It is a gradual improvement of the
>>> existing SMP low-level initialization and shutdown procedure.
>>> The existing solution was able to start an SMP system.  Only atomic
>>> reads/writes were used.  It is impossible to implement a controlled
>>> shutdown only with atomic reads/writes.
>> I cannot comment as I have no considered it in detail. It is a big
>> statement to
>> make. Maybe this is a suitable GSoC project.
>>> See also "The Art of
>>> Multiprocessor Programming", chapter 5, "The Relative Power of Primitive
>>> Synchronization Operations".
>> I will take a look but it might be a while.
>>> This patch introduces a statically initialized global SMP lock to manage
>>> the per-CPU state changes (_Per_CPU_State_lock).  It changes also the
>>> states and documents the state machine.
>>> It is now also possible to use fatal error handlers to control the
>>> shutdown on the lowest-level.
>>> Without this patch on NGMP the situation is like this:
>>> ***  SMP03 TEST ***
>>>    CPU 3 running task Init
>>>    CPU 2 running task TA1
>>>    CPU 1 running task TA2
>>>    CPU 0 running task TA3
>>>    CPU 0 running task TA4
>>> *** END OF TEST SMP03 ***
>>> CPU 0:  Unknown watchpoint hit
>>>          0x0000b1c4: 30800000  ba,a  0x0000B1C4
>>> <rtems_smp_process_interrupt+172>
>>> CPU 1:  Unknown watchpoint hit
>>> CPU 2:  Unknown watchpoint hit
>>> CPU 3:  Program exited normally.
>>> Now I have this:
>>> ***  SMP03 TEST ***
>>>    CPU 0:  Program exited normally.
>>>    CPU 1:  Power down mode
>>>    CPU 2:  Power down mode
>>>    CPU 3:  Power down mode
>>> I think we should try to discuss problems with a specific patch in one
>>> thread and general problems in a separate thread in the future.
>> Great. Please start the discussion. I am not doing the work or
>> creating the
>> patches and you are so it is up to you and in your interests to get
>> this under
>> way and discussed as soon as possible. Starting a discussion and
>> general design
>> and review process leaves this patch and any others in a difficult
>> position to
>> approve and it also effects your planned work. I am aware of this and
>> sensitive
>> to it however I do not agree with some parts of the presented design
>> and I am
>> concerned about the future parts that are known to be wrong and not
>> covered in
>> your current scope of work. We need an open discussion where the top
>> level
>> requirements need to be defined and the design path settled and
>> without it I am
>> limited to commenting in patches about general design issues.
> The SMP initialization existed before my involvement in this area.  It
> is not my work and I only fix basic problems here.
I know this is the case and I am also not asking you to fix the problem.
I am attempting to identify issues. There is a connected issue related
to the SMP application configuration setting.
> I put a great deal of information into the wiki page
> http://www.rtems.org/wiki/index.php?title=SMP
Yes and I have read it. It provides the details of your work however I
do not fully understanding the why and where it fits in the overall SMP
picture. I think this is where the requirements fit in.
> I also sent several e-mails to the list in the last couple of months
> will little response.
I am sorry if I did not respond. This is a complex topic with many many
interrelated parts. I did not become fully involved until I needed to
use SMP and even then it has taken me a while to digest what we have and
what the issues are. I am still struggling to keep up with the changes.
>>> On 2014-02-25 00:02, Chris Johns wrote:
>>>> On 21/02/2014 6:48 pm, Sebastian Huber wrote:
>>>>> On 2014-02-21 01:31, Chris Johns wrote:
>>>>>> On 21/02/2014 3:31 am, Sebastian Huber wrote:
>>>>>>> Hello Chris,
>>>>>>> On 2014-02-20 03:50, Chris Johns wrote:
>>>>>>>> On 20/02/2014 12:42 am, Sebastian Huber wrote:
>>>>>>>>> + * @brief State of a processor.
>>>>>>>>> + * @dot
>>>>>>>>> + * digraph states {
>>>>>>>>> + *   bi [label="PER_CPU_STATE_BEFORE_INITIALIZATION"];
>>>>>>>>> + *   rsm [label="PER_CPU_STATE_READY_TO_START_MULTITASKING"];
>>>>>>>>> + *   sm [label="PER_CPU_STATE_START_MULTITASKING"];
>>>>>>>>> + *   ds [label="PER_CPU_STATE_DO_SHUTDOWN"];
>>>>>>>>> + *   u [label="PER_CPU_STATE_UP"];
>>>>>>>>> + *   s [label="PER_CPU_STATE_SHUTDOWN"];
>>>>>>>>> + *   bi -> rsm [label="secondary processor\ncompleted
>>>>>>>>> initialization"];
>>>>>>>>> + *   bi -> u [label="main processor\nstarts multitasking"];
>>>>>>>>> + *   rsm -> sm [label="main processor\ncompleted
>>>>>>>>> initialization"];
>>>>>>>>> + *   rsm -> ds [label="a fatal error occurred"];
>>>>>>>>> + *   ds -> s [label="do shutdown\nstate observed"];
>>>>>>>>> + *   sm -> u [label="secondary processor\nstarts multitasking"];
>>>>>>>>> + *   u -> s [label="shutdown initiated"];
>>>>>>>>> + * @enddot
>>>>>>>> I do not see sm to ds if the main core goes to s after going
>>>>>>>> from bi
>>>>>>>> to u ?
>>>>>>>> I also see u to s and not to ds; why as the state is called "do
>>>>>>>> shutdown" ?
>>>>>>>> Should this state be PER_CPU_STATE_SHUTTING_DOWN ?
>>>>>>> I had to change the procedure considerably since I noticed
>>>>>>> unsolvable
>>>>>>> problems with the previous approach based only on atomic read/write
>>>>>>> operations. Attached is the new state diagram.
>>>>>> I do not follow this picture. I am assume there is one state machine
>>>>>> per CPU
>>>>>> and so I do not see where the state "starting multitasking" is. I see
>>>>>> a state
>>>>>> called "request start multitasking" then "up" and I am wondering what
>>>>>> the state
>>>>>> is after the request has happened and before up.
>>>>> The application defines a maximum count of processors (NP).  The
>>>>> configuration will then define the _Per_CPU_Information[NP] table.
>>>>> Each
>>>>> table entry has one per-CPU state entry.
>>>> Does the BSP define the max number of possible cores the hardware can
>>>> support ?
>>> Yes, via the return value of _CPU_SMP_Initialize().
>> This is what should be used to define the Per CPU area.
>>> This patch changes nothing in this area.
>> I have made my comments on this above.
>>>> I see later in this email you talk about AP being available processors
>>>> and
>>>> defined by the BSP. I think I am getting confused with the term
>>>> "maximum count
>>>> of processors". Does it mean the max count the application may require
>>>> or the
>>>> max count supported by the hardware ?
>>> It is a mix of both.  The application configures a desired maximum count
>>> and the BSP may reduce it to match the actual hardware.
>> This seems confused and wrong and why I feel a general lack of top level
>> requirements is appearing in the design. We do not configure any other
>> part of
>> the configuration this way. We do not let applications set the memory
>> size to
>> 1T byte of RAM and the BSP lowers it to the actual amount nor do we
>> have the
>> application set the CPU clock to 1PetaHz and the BSP lower it to the
>> hardware
>> defined maximum rate. It seems counter-intuitive and goes against how
>> everything else is configured.
> We have this since day-one of RTEMS SMP.  It is not my invention.  It is
> good enough for me at the moment and I have more pressing problems.
Yes I know. The SMP work has been done from the inside to out, that is
the deep inside the kernel and I suspect this way of configuring was
easy and worked and while we moved from nothing to something and that is
fine. We are now getting to a point where SMP is starting to be usable
and this is just one issue we now need to resolve. I have no idea when
and by who and that is not what I am after. I am only after a set of
requirements that capture what we need and to make sure our thinking is
aligned. My concern is having this code embedded so deep we cannot
change it if we wanted to.
>>>> There is another issue here I am struggling with and while
>>>> specifically not on
>>>> topic for this patch it relates to the configuration of processor
>>>> count so
>>>> please indulge me. The application having to define the number of
>>>> cores means
>>>> there is no default position and that means we have this ...
>>>> http://git.rtems.org/rtems/tree/testsuites/smptests/smp01/system.h#n28
>>>> which is based on this ...
>>>> http://git.rtems.org/rtems/tree/cpukit/sapi/include/confdefs.h#n205
>>>> A user builds RTEMS with --enable-smp and then has another gate in
>>>> CONFIGURE_SMP_APPLICATION. This does not make sense. Why build for SMP
>>>> and then
>>>> never use it yet incur lots of overhead ? If I build RTEMS with SMP
>>>> enabled for
>>>> a BSP that supports SMP I would expect it to work with SMP and not
>>>> default to
>>>> some half way point. For example if you build the Zync A9 qemu BSP
>>>> with SMP
>>>> enabled and build all the tests then run them on a patched qemu with
>>>> SMP
>>>> support you happily see about 10 maybe 15 failures for over 480 tests
>>>> however
>>>> these result are meaningless because CONFIGURE_SMP_APPLICATION is only
>>>> defined
>>>> for a few SMP specific tests and incorrectly for the Zync because it
>>>> only has 2
>>>> cores and not 4. I feel we should not go to a release with the tests
>>>> in this
>>>> state even with clear documentation. If the tests fail with SMP we
>>>> need to have
>>>> the test results show this and document what the failures are so users
>>>> are left
>>>> with a clear picture of the state of SMP support. For example with the
>>>> Zynq A9
>>>> qemu example none of the block (libbd) tests should pass as libbd uses
>>>> disable
>>>> pre-emption and this should generate an error if used.
>>>> The CONFIGURE_SMP_APPLICATION needs to go however there is no default
>>>> core
>>>> count defined by the BSP that can be used to allow this. IMO if the
>>>> application
>>>> does not define the core count it needs, ie less than the max
>>>> supported by the
>>>> hardware, the max possible should be used.
>>> I didn't invent this CONFIGURE_SMP_APPLICATION.
>> I know. All I am trying to do is bring out into the open all the
>> issues we have
>> with SMP in RTEMS so the community knows the state and so we can look
>> at the
>> list of things that needs doing.
>>> At the moment it is
>>> useful since we lack important features like thread deletion.
>> If the code is broken and tests fails we should have them fail.
> I am not opposed to change this, but I will not do it.  I have project
> deadlines and I have to focus on things important for my work.
I am happy to make the change however the change effects the NP and AP
settings. I will start another thread on this topic.
>>> With the
>>> introduction of clustered/partitioned scheduling the configuration will
>>> completely change. So I would like to postpone this discussion a couple
>>> of weeks.
>> I cannot comment as I have no idea what this means. I did not even know
>> "clustered/partitioned scheduling" was a requirement. We still cannot
>> run a
>> single real application under SMP (see the thread deletion comment
>> above).
> http://www.rtems.org/pipermail/rtems-devel/2013-November/004950.html
> http://www.rtems.org/wiki/index.php?title=SMP#Clustered_Scheduling
> http://www.rtems.org/wiki/index.php?title=SMP#Clustered_Scheduling_2
Thanks for providing the references. I will add this to the requirements
when I start on them.
>>>>>  Since this table is in the BSS
>>>>> section, all states start with PER_CPU_STATE_INITIAL.
>>>> Who is clearing the BSS and how is this managed ? There seems to be
>>>> some
>>>> implicit requirements here. The requirement being "RTEMS requires all
>>>> processors to run in an SMP environment must be started externally to
>>>> RTEMS".
>>>> Is this requirement what we really want ?
>>> This is not the case.  The low-level start-up is highly BSP specific.
>>> The leon3 BSP for example starts secondary processors on its own.  The
>>> QorIQ relies on U-Boot.  Our Altera Cyclone-V (ARM Cortex-A9 MPCore
>>> based) will also start secondary processors on its own.
>> Ok so we have a mix. I did not know this and when I raised this last
>> year with
>> you I was told it needs to be performed by the boot monitor. As a
>> result I went
>> down this path on the Zynq.
> This is fine if you have a boot loader.  On the Cyclone-V the boot
> loader didn't start the second processor so we had to do it in the BSP.
I will take a look at what you did and see what I can do in the Zync.
The standard FSBL from Xilinx is the same.
>>>> On the ARM (well the zynq I have used) starting processors is easy and
>>>> the code
>>>> needed is tiny and could be made available in the BSP shared area,
>>>> while I
>>>> understand on the PPC it is complex. I suppose the question is adding
>>>> this
>>>> support to RTEMS what we want to have and worth it verses adding this
>>>> code
>>>> gives us complete control over initialisation and makes the boot
>>>> monitor simpler.
>>>> Given I currently only use the ARM which is easy and I will not ship
>>>> uboot due
>>>> to licensing reason I favour adding support to RTEMS. :)
>>>>> The boot processor calls boot_card() and all other processors do what
>>>>> they want, but they must wait until the boot processor gives the go
>>>>> (explained later).
>>>>> The boot processor calls eventually:
>>>>>     * @brief Performs CPU specific SMP initialization in the
>>>>> context of
>>>>> the boot
>>>>>     * processor.
>>>>>     * This function is invoked on the boot processor by RTEMS during
>>>>>     * initialization.  All interrupt stacks are allocated at this
>>>>> point
>>>>> in case
>>>>>     * the CPU port allocates the interrupt stacks.
>>>>>     * The CPU port should start secondary processors now.
>>>> What does this mean ? I am not sure if you mean the boot monitor does
>>>> this or
>>>> this is handled in RTEMS in the BSP or related CPU code.
>>>>>     * @param[in] configured_cpu_count The count of processors
>>>>> requested
>>>>> by the
>>>>>     * application configuration.
>>>>>     * @return The count of processors available for the application in
>>>>> the system.
>>>>>     * This value is less than or equal to the configured count of
>>>>> processors.
>>>>>    uint32_t _CPU_SMP_Initialize( uint32_t configured_cpu_count );
>>>>> So here has the CPU port (or BSP in most cases) the chance to
>>>>> reduce the
>>>>> configured count of processors to the actually available (AP).  We
>>>>> have
>>>>> AP <= NP.  In case this function returns "you have three processors",
>>>>> then these three processors MUST start properly or terminate the
>>>>> system.  If some processors are not always available or otherwise
>>>>> unreliable this must be dealt with in _CPU_SMP_Initialize().
>>>> This is confusing me. The application controls the max number of cores
>>>> (NP) a
>>>> system can have and the BSP (or CPU port which knows the max that can
>>>> exist)
>>>> can configure that down to the actual number. Does this mean I could
>>>> define 32
>>>> cores at the application and Zynq BSP would say, sorry only 2 here so
>>>> this is
>>>> what you get ?
>>> Yes.  Its done in some tests, e.g.
>>> http://git.rtems.org/rtems/tree/testsuites/smptests/smplock01/init.c#n28
>>> Does this waste RAM ?
>>> Yes, but its not much, e.g. the _Per_CPU_Information table is a bit
>>> bigger than necessary.
>> Lets agree to just stick to yes.
>>>> What about an application defining 2 on a 4 core system ?
>>> It gets two.
>> Ok.
>>>>> System termination can happen at anytime on any processor.  So you can
>>>>> change from every state into PER_CPU_STATE_SHUTDOWN.  This ability is
>>>>> the core of this change set.  In the previous implementation this was
>>>>> not guaranteed.
>>>> Did the state diagram show this ? I am sorry if I missed this.
>>> Yes, you have arrows from all other states to PER_CPU_STATE_SHUTDOWN.
>>>>> Now lets look at the normal start-up (no shutdown).  The next state
>>>>> after PER_CPU_STATE_INITIAL is
>>>>> PER_CPU_STATE_READY_TO_START_MULTITASKING.
>>>>>     * @brief Processor is ready to start multitasking.
>>>>>     * The secondary processor performed its basic initialization
>>>>> and is
>>>>> ready to
>>>>>     * receive inter-processor interrupts.  Interrupt delivery must be
>>>>> disabled
>>>>>     * in this state, but requested inter-processor interrupts must be
>>>>> recorded
>>>>>     * and must be delivered once the secondary processor enables
>>>>> interrupts for
>>>>>     * the first time.  The boot processor will wait for all secondary
>>>>> processors
>>>>>     * to change into this state.  In case a secondary processor
>>>>> does not
>>>>> reach
>>>>>     * this state the system will not start.  The secondary processors
>>>>> wait now
>>>>>     * for a change into the PER_CPU_STATE_REQUEST_START_MULTITASKING
>>>>> state set
>>>>>     * by the boot processor once all secondary processors reached the
>>>>>     * PER_CPU_STATE_READY_TO_START_MULTITASKING state.
>>>>>    PER_CPU_STATE_READY_TO_START_MULTITASKING,
>>>>> The key point for a per-CPU state and not a global state is that every
>>>>> processor must perform some initialization steps to set up the "I can
>>>>> receive inter-processor interrupts (IPI)" state.  Before IPIs are
>>>>> possible the only why are spin variables (e.g. this per-CPU state
>>>>> variables).
>>>>> This PER_CPU_STATE_READY_TO_START_MULTITASKING is a synchronization
>>>>> barrier.
>>>>> The boot processor will then set the state to
>>>>> PER_CPU_STATE_REQUEST_START_MULTITASKING on all processors configured
>>>>> and available (AP).  Once the secondary processor observes this state
>>>>> change (it spins on its state variable), it will go into the
>>>>> PER_CPU_STATE_UP state and perform a context switch to the first
>>>>> thread.
>>>> If this is about getting to a suitable IPI state on each core then why
>>>> not have
>>>> this in the states and functions rather then the global state type
>>>> names of
>>>> "start multitasking" etc.
>>> I don't think we should be too specific about the IPI here.  The basic
>>> statement is that a processor is ready to start multitasking.
>>>> I see the issue of needing a clear path from no IPI to having IPI
>>>> however I am
>>>> still wondering why the need to have the synch point and all cores to
>>>> be there
>>>> before moving on. A new core in the system should be able to see the
>>>> system
>>>> state and IPIs are active and then enable its support then add itself
>>>> to the
>>>> system.
>>> Then you have to check each time which method you need to send a message
>>> to another processor.  I don't see a benefit here.
>> It is just a check when booting and not used once using IPI.
>>>> If there is a global state variable with suitable spinning locks and
>>>> atomics
>>>> that direct the per cpu paths taken I fail to see why we need this sync
>>>> barrier. The first core to a given global state makes the transition
>>>> and the
>>>> other cores need to wait or move to a different state. This assumes
>>>> the BSS
>>>> init issue is resolved.
>>> I fail to see why this barrier is a problem.
>> Because as I stated before this is a system design constraint and not
>> something
>> RTEMS should enforce. It could be optional but not mandatory and being
>> optional
>> then using it comes with some risks.
>>> The processors in an SMP
>>> system MUST work reliable if now or later it doesn't matter.
>> When I used the existing system and the boot monitor did not start a
>> processor
>> the system locked up. There was no recovery with the current design and I
>> consider this a flaw. A watchdog just looped.
> This is a problem of the boot process on this particular BSP and not a
> general problem.  In _CPU_SMP_Initialize() the boot processor could test
> if the other processors are up and then reduce the CPU count accordingly.
There are degraded modes RTEMS should support. For example a degraded
mode allows an application the ability to report and perform some level
of recovery without adding that complication to the boot loader.
>>> Do you
>>> really want to work an a system that works under this condition:
>>> "Sometimes scheduling actions take place, but you cannot assume that a
>>> thread will execute as planned.".
>> Again a system issue. It is up to system designers on a specific
>> project to
>> determine the fail states like this and not operating system kernel
>> designers.
>> Allowing a degraded state provides opportunity for recover or fault
>> reporting.
>> It is not for everyone or every system.
> In this case the operating system must detect the problems and notify
> the application about such error events.  I don't see any problems in
> adding this later, but this is not on my list.
It might be RTEMS provides ways for an application to monitor this and
the application can determines the course of action.
>>>>>>>> I do not see why we have main and secondary processors ?
>>>>>>> I changed "main processor" into "boot processor" to highlight that
>>>>>>> this
>>>>>>> is only the case during system boot.
>>>>>> Is there any code checking the processor number ? I see it in the
>>>>>>>> This is symmetric
>>>>>>>> multiprocessing which means each core is the same therefore
>>>>>>>> capable of
>>>>>>>> completing any required task. I understand there are paths which
>>>>>>>> need to
>>>>>>>> complete so if we have states for these phases as gates then any
>>>>>>>> processor that
>>>>>>>> arrives should be able to enter the gate (spinning lock for those
>>>>>>>> that
>>>>>>>> need to
>>>>>>>> wait) and complete the work. This means a degraded state can exist
>>>>>>>> and
>>>>>>>> things
>>>>>>>> at least start. The application would need to detect and manage the
>>>>>>>> degraded
>>>>>>>> state and so RTEMS should not be concerned with this condition
>>>>>>>> other
>>>>>>>> than doing
>>>>>>>> its best to run where possible.
>>>>>>> In case the boot procedure of the system is unstable then it
>>>>>>> makes no
>>>>>>> sense to run an application.
>>>>>> This depends on the application and its system requirements and
>>>>>> how the
>>>>>> hardware is constructed. A boot monitor can see cores are not
>>>>>> present and
>>>>>> decide not to start RTEMS or it can decide to start a single core.
>>>>>> This relates
>>>>>> to the system's requirement and can vary and has little to do with
>>>>>> RTEMS. If a
>>>>>> boot monitor passes control to RTEMS then it should run and only fail
>>>>>> if it's
>>>>>> integrity it not correct. RTEMS does should not move into the area of
>>>>>> system
>>>>>> requirements or constraints. Adding constraints like this in the
>>>>>> operating
>>>>>> system does not seem a good idea to me.
>>>>> I see no problem here.  See _CPU_SMP_Initialize() above.
>>>> I do not understand. Are you saying the design will run with a core
>>>> count that
>>>> does not match NP or AP ?
>>> It is min { NP, AP }.
>> IMO an application core count higher than the available cores is a
>> configuration error.
> I think its quite handy to be able to configure systems that way.  You
> can simply use a bunch of processors for worker pools.
I do not understand buts lets move this to a general requirements thread
and close this thread down.
>>>>>>>> I assume if we have n cores where n is 1..cpus available we
>>>>>>>> enter the
>>>>>>>> static
>>>>>>>> constructors once and 'main' [1] once and this independent of the
>>>>>>>> number of
>>>>>>>> defined and/or operating cores. If an application's static
>>>>>>>> constructor
>>>>>>>> starts
>>>>>>>> further threads it needs to manage the concurrency issues and
>>>>>>>> main is
>>>>>>>> only
>>>>>>>> entered once.
>>>>>>> This change is about the low-level boot procedure.  High level
>>>>>>> concepts
>>>>>>> like threads are not an issue here.
>>>>>> They are if you remove the all cores needing to sync plus using cpu
>>>>>> numbers to
>>>>>> control which cores go through to the static constructors and main
>>>>>> and
>>>>>> which
>>>>>> cores go direct to the score thread code.
>>>>> If you remove this synchronization barrier via
>>>>> PER_CPU_STATE_READY_TO_START_MULTITASKING, then you mandate that there
>>>>> is boot loader that does these steps.  With the current set-up this
>>>>> boot
>>>>> loader is optional.
>>>> Or the boot loading is not involved.
>>>>>> It is this sort of code that concerns
>>>>>> me ...
>>>>>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h#n88
>>>>> Yes, this is a dirty hack.  It works at the moment due to our immature
>>>>> SMP state, but this must definitely change.
>>>>>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/sparc/shared/start/start.S#n226
>>>>> Yes, exactly the same issue.  This processor index 0 == boot processor
>>>>> is a bad assumption.
>>>> I feel the single major issue here is a lack of defined requirement
>>>> for SMP.
>>>> The RTEMS Project and its community need to define the top level
>>>> requirements
>>>> and along with that tests that check those requirements. For me
>>>> reviewing
>>>> patches it is not clear what is a hack or temporary and what is long
>>>> term and
>>>> here for good. Questioning each patch or change to find this out is
>>>> time
>>>> consuming and not very productive.
>>> Yes, we have the wiki page for this:
>> Yes and the section is empty.
> What should I do now from your point of view?
Nothing. I will start a requirements process for SMP and we can unlock
this patch and hopefully further patches. All I ask is your
participation in the review of the requirements and then your support
when and as you can in getting RTEMS to meet those requirements. I see
the requirements unlocking some parallel paths, for example GSoC can
have a project to develop tests to test the requirements.
