GSoC 2014 | Poring RTEMS for OpenRISC
Tue Mar 4 18:47:13 UTC 2014
On Tue, Mar 4, 2014 at 1:22 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Mon, Mar 3, 2014 at 6:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Hesham,
>> On Mon, Mar 3, 2014 at 11:06 AM, Hesham Moustafa
>> >> Long term a port needs to be to a viable architecture from a "is it
>> >> alive"
>> >> view  this includes the cpu, tools, a way for us to test, etc
>> > Sure, that's what I hope to work on.
>> In order to have a chance that your proposal will be accepted, you
>> will need to demonstrate that the openrisc tools work for recent gcc /
>> newlib with an adequate simulator. Based on wikipedia, you should be
>> able to cross-compile Linux for the OpenRISC to run on Qemu, or you
>> may like to just try to get a bare-metal application to run in the
>> simulator.
> I have built their latest toolchain, gcc  4.9.0 and binutils 2.24.51.
> with newlib. A helloworld program is working fine with or1k-elf-run,
> or1k-elf-gdb (which connects to their or1ksim simulator) and qemu.
> The questions is, should this project include porting their toolchains to
> RTEMS toolchains (with their copyrights) ? or that may cause some
> licence/copyrights problems ?
In order for RTEMS Project to accept the BSP for inclusion, the GCC
toolchain must be available and prepared for upstream submission. If
there is already OpenRISC (or1k) support accepted by GCC for linux, it
should be straightforward to make it work for RTEMS. You will need to
propose it as part of your GSOC, and you will need to make the proper
steps including submitting FSF paperwork for contributing to GCC.
-Gedare
