GSoC 2014 | Porting RTEMS for OpenRISC
Hesham Moustafa
heshamelmatary at gmail.com
Wed Mar 5 01:49:12 UTC 2014
On Tue, Mar 4, 2014 at 8:36 PM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> I checked around at work and there is some interest in using the OpenRISC
> architecture, but no definite plans.
> Another idea is to advance the Microblaze port.
> Great. I can work on either, but I preferred OpenRISC because an RTEMS
port, hopefully,
can target both opensource HW and embedded SW communities. Industry
preferences
are of my concerns Alan, I appreciate your opinion regarding which
architecture would
you like to use a port for and why ?
> Alan
> On Mar 4, 2014, at 1:22 PM, Hesham Moustafa <heshamelmatary at gmail.com>
> wrote:
> On Mon, Mar 3, 2014 at 6:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Hesham,
>> On Mon, Mar 3, 2014 at 11:06 AM, Hesham Moustafa
>> <heshamelmatary at gmail.com> wrote:
>> > On Mon, Mar 3, 2014 at 5:06 PM, Joel Sherrill <
>> Joel.Sherrill at oarcorp.com>
>> > wrote:
>> >> On Mar 3, 2014 8:23 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> > Hesham,
>> >> > The first question to figure out is why was the older port dropped.
>> >> This I can answer. The tool chain rotted and had no maintainer. I also
>> >> recall not having a simulator to test on.
>> >> The final issue was some discrepancy between multiple openrisc CPU
>> >> projects where I thought the focus on the architecture we had a port
>> to was
>> >> losing interest from them.
>> > Thanks Dr Joel, I also wanted to know the answer :)
>> > Was this architecture OpenRISC 1000 or another core ?
>> If the toolchain is up-to-date and there are simulator and real hw
>> architecture supported, then it can be a feasible project to do a
>> port.
>> Yes the toolchain is up-to-date and I worked on their or1ksim simulator
> which can be connected to gdb. They support many boards, one of them is
> Atlys FPGA board which I have and worked on and I hope to create a BSP for.
>> >> > The second is what is your interest in porting to OpenRISC?
>> > Because I have been working on the last few months on FPGA project (
>> mips
>> > microprocessor).
>> > I wanted to port an OS to an opensource processor, and OpenRISC
>> architecture
>> > is mature enough to port a complex RTOS like RTEMS.
>> >> And who would use it?
>> > People using black box OpenRISC and others interested in Digital design,
>> > Computer architecture and
>> > HW/SW interfacing. Something like xilinx zynq ? except that both
>> OpenRISC
>> > and RTEMS are opensource.
>> If OpenRISC has settled on a specific reference architecture and has
>> an adequately active community, then a port would be acceptable.
>> I think they have. OpenRISC 1000 and 1200 architectures are both well
> supported
> and used, and their community is active.
>> >> Long term a port needs to be to a viable architecture from a "is it
>> alive"
>> >> view this includes the cpu, tools, a way for us to test, etc
>> > Sure, that's what I hope to work on.
>> In order to have a chance that your proposal will be accepted, you
>> will need to demonstrate that the openrisc tools work for recent gcc /
>> newlib with an adequate simulator. Based on wikipedia, you should be
>> able to cross-compile Linux for the OpenRISC to run on Qemu, or you
>> may like to just try to get a bare-metal application to run in the
>> simulator.
>> I have built their latest toolchain, gcc 4.9.0 and binutils 2.24.51.
> with newlib. A helloworld program is working fine with or1k-elf-run,
> or1k-elf-gdb (which connects to their or1ksim simulator) and qemu.
> The questions is, should this project include porting their toolchains to
> RTEMS toolchains (with their copyrights) ? or that may cause some
> licence/copyrights problems ?
>> Gedare
>> >> > Gedare
>> >> > On Sun, Mar 2, 2014 at 12:39 AM, Hesham Moustafa
>> >> > > Hi,
>> >> > > I am thinking of porting RTEMS for OpenRISC as a proposal for GSoC
>> >> > > project
>> >> > > this year.
>> >> > > I know there was an older port, but it's not available anymore on
>> the
>> >> > > current RTEMS mainsteam.
>> >> > > Would this project be of useful to RTEMS and suitable for GSoC ?
>> >> > > Thanks,
>> >> > > Hesham
>> >> > > _______________________________________________
>> >> > > rtems-devel mailing list
>> >> > > rtems-devel at rtems.org
>> >> > > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140305/ab4f8d9c/attachment.html>
