Patch - Enable POSIX Keys in All Configurations
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Mar 5 19:36:18 UTC 2014
Hi
As discussed in various threads and private conversations, task variables
are broken by design on SMP systems. POSIX keys are a standard way
to have SMP safe per task data. But currently they are only available
when --enable-posix is specified.
This rather tedious patch enables them all the time. It touches the
configuration, code, and reworks the tests to use Classic tasks.
The next step is to eliminate the use of task variables in the
cpukit code. That code is unsafe for SMP systems.
OK to apply?
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140305/9c144748/attachment.bin>
