Patch - Enable POSIX Keys in All Configurations
Wed Mar 5 20:51:08 UTC 2014
Joel,
I suspect you need more changes in confdefs.h to put the keys in the
configuration and debug configurations structures, and to accurately
estimate the workspace memory usage, in case POSIX_KEYS are used
without having posix enabled.
Nothing else seemed obviously wrong at a quick read through.
Considering you updated the .scn files, I take it you have run the
psxkey tests with this change.
Gedare
On Wed, Mar 5, 2014 at 2:36 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Hi
> As discussed in various threads and private conversations, task variables
> are broken by design on SMP systems. POSIX keys are a standard way
> to have SMP safe per task data. But currently they are only available
> when --enable-posix is specified.
> This rather tedious patch enables them all the time. It touches the
> configuration, code, and reworks the tests to use Classic tasks.
> The next step is to eliminate the use of task variables in the
> cpukit code. That code is unsafe for SMP systems.
> OK to apply?
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
