[PATCH] bsps/sparc: Remove fix for ERC32 with FPU rev. B/C
Sebastian Huber
Thu Mar 6 10:21:11 UTC 2014
c/src/lib/libbsp/sparc/shared/irq_asm.S | 66 -------------------------------
1 files changed, 0 insertions(+), 66 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index a586244..3de741c 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -427,70 +427,6 @@ dont_switch_stacks:
mov %l0, %g5
and %l3, 0x0ff, %g4
-/* This is a fix for ERC32 with FPU rev.B or rev.C */
-#if defined(FPU_REVB)
- subcc %g4, 0x08, %g0
- be fpu_revb
- subcc %g4, 0x11, %g0
- bl dont_fix_pil
- subcc %g4, 0x1f, %g0
- bg dont_fix_pil
- sll %g4, 8, %g4
- and %g4, SPARC_PSR_PIL_MASK, %g4
- andn %l0, SPARC_PSR_PIL_MASK, %g5
- or %g4, %g5, %g5
- srl %l0, 12, %g4
- andcc %g4, 1, %g0
- be dont_fix_pil
- nop
- ba,a enable_irq
-fpu_revb:
- srl %l0, 12, %g4 ! check if EF is set in %psr
- andcc %g4, 1, %g0
- be dont_fix_pil ! if FPU disabled than continue as normal
- and %l3, 0xff, %g4
- bne enable_irq ! if not a FPU exception then do two fmovs
- set __sparc_fq, %g4
- st %fsr, [%g4] ! if FQ is not empty and FQ[1] = fmovs
- ld [%g4], %g4 ! than this is bug 3.14
- srl %g4, 13, %g4
- andcc %g4, 1, %g0
- be dont_fix_pil
- std %fq, [%g4]
- ld [%g4+4], %g4
- set 0x81a00020, %g5
- subcc %g4, %g5, %g0
- bne,a dont_fix_pil2
- wr %l0, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
- ba,a simple_return
-enable_irq:
- or %g5, SPARC_PSR_PIL_MASK, %g4
- wr %g4, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
- nop; nop; nop
- fmovs %f0, %f0
- ba dont_fix_pil
- fmovs %f0, %f0
- .data
- .global __sparc_fq
- .align 8
-__sparc_fq:
- .word 0,0
- .text
-/* end of ERC32 FPU rev.B/C fix */
-#else
bl dont_fix_pil
@@ -500,8 +436,6 @@ __sparc_fq:
ba pil_fixed
or %g4, %g5, %g5
-#endif
dont_fix_pil:
or %g5, SPARC_PSR_PIL_MASK, %g5
pil_fixed:
1.7.7
