[PATCH 1/2] sapi: Add <rtems/test.h>
Mon Mar 10 15:35:38 UTC 2014
Provide support functions to print the begin/end of test message.
Provide a test fatal extension to print out profiling reports in the
future.
 cpukit/sapi/Makefile.am                     |    3 +
 cpukit/sapi/include/rtems/test.h            |  125 +++++++++++++++++++++++++++
 cpukit/sapi/preinstall.am                   |    4 +
 cpukit/sapi/src/testbeginend.c              |   43 +++++++++
 cpukit/sapi/src/testextension.c             |   30 +++++++
 testsuites/support/include/buffer_test_io.h |   16 ++++
 6 files changed, 221 insertions(+), 0 deletions(-)
 create mode 100644 cpukit/sapi/include/rtems/test.h
 create mode 100644 cpukit/sapi/src/testbeginend.c
 create mode 100644 cpukit/sapi/src/testextension.c
diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
index 19f7d87..37a2fa4 100644
--- a/cpukit/sapi/Makefile.am
+++ b/cpukit/sapi/Makefile.am
@@ -18,6 +18,7 @@ include_rtems_HEADERS += include/rtems/profiling.h
 include_rtems_HEADERS += include/rtems/rbheap.h
 include_rtems_HEADERS += include/rtems/rbtree.h
 include_rtems_HEADERS += include/rtems/sptables.h
+include_rtems_HEADERS += include/rtems/test.h
 include_rtems_HEADERS += include/rtems/timespec.h
 EXTRA_DIST = include/rtems/README
@@ -39,6 +40,8 @@ libsapi_a_SOURCES += src/delayticks.c
 libsapi_a_SOURCES += src/delaynano.c
 libsapi_a_SOURCES += src/profilingiterate.c
 libsapi_a_SOURCES += src/profilingreportxml.c
+libsapi_a_SOURCES += src/testbeginend.c
+libsapi_a_SOURCES += src/testextension.c
 libsapi_a_CPPFLAGS = $(AM_CPPFLAGS)
 include $(srcdir)/preinstall.am
diff --git a/cpukit/sapi/include/rtems/test.h b/cpukit/sapi/include/rtems/test.h
new file mode 100644
index 0000000..91a5a22
--- /dev/null
+++ b/cpukit/sapi/include/rtems/test.h
@@ -0,0 +1,125 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_TEST_H
+#define _RTEMS_TEST_H
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup RTEMSTest Test Support
+ * @brief Test support functions.
+ * @brief Each test must define a test name string.
+extern const char rtems_test_name[];
+ * @brief Fatal extension for tests.
+void rtems_test_fatal_extension(
+  rtems_fatal_source source,
+  bool is_internal,
+  rtems_fatal_code code
+ * @brief Initial extension for tests.
+#define RTEMS_TEST_INITIAL_EXTENSION \
+  { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension }
+ * @brief Prints a begin of test message.
+ * @param[in] printf_func The formatted output function.
+ * @param[in, out] printf_arg The formatted output function argument.
+ * @returns As specified by printf().
+int rtems_test_begin_with_plugin(
+  rtems_printk_plugin_t printf_func,
+  void *printf_arg
+ * @brief Prints a begin of test message using printf().
+static inline int rtems_test_begin(void)
+  return rtems_test_begin_with_plugin(rtems_printf_plugin, NULL);
+ * @brief Prints a begin of test message using printk().
+static inline int rtems_test_begink(void)
+  return rtems_test_begin_with_plugin(printk_plugin, NULL);
+ * @brief Prints an end of test message.
+int rtems_test_end_with_plugin(
+  void *printf_arg
+ * @brief Prints an end of test message using printf().
+static inline int rtems_test_end(void)
+  return rtems_test_end_with_plugin(rtems_printf_plugin, NULL);
+ * @brief Prints an end of test message using printk().
+static inline int rtems_test_endk(void)
+  return rtems_test_end_with_plugin(printk_plugin, NULL);
+#ifdef __cplusplus
+#endif /* _RTEMS_TEST_H */
diff --git a/cpukit/sapi/preinstall.am b/cpukit/sapi/preinstall.am
index d05ab25..7e18d3a 100644
--- a/cpukit/sapi/preinstall.am
+++ b/cpukit/sapi/preinstall.am
@@ -88,6 +88,10 @@ $(PROJECT_INCLUDE)/rtems/sptables.h: include/rtems/sptables.h $(PROJECT_INCLUDE)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/sptables.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/sptables.h
+$(PROJECT_INCLUDE)/rtems/test.h: include/rtems/test.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/test.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/test.h
 $(PROJECT_INCLUDE)/rtems/timespec.h: include/rtems/timespec.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/timespec.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/timespec.h
diff --git a/cpukit/sapi/src/testbeginend.c b/cpukit/sapi/src/testbeginend.c
index 0000000..dac0763
--- /dev/null
+++ b/cpukit/sapi/src/testbeginend.c
@@ -0,0 +1,43 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/test.h>
+  void *printf_arg
+  return (*printf_func)(
+    printf_arg,
+    "\n\n*** BEGIN OF TEST %s ***\n",
+    rtems_test_name
+  void *printf_arg
+    printf_arg,
+    "*** END OF TEST %s ***\n",
+    rtems_test_name
diff --git a/cpukit/sapi/src/testextension.c b/cpukit/sapi/src/testextension.c
index 0000000..a896c78
--- /dev/null
+++ b/cpukit/sapi/src/testextension.c
@@ -0,0 +1,30 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#endif
+  bool is_internal,
+  (void) source;
+  (void) is_internal;
+  (void) code;
diff --git a/testsuites/support/include/buffer_test_io.h b/testsuites/support/include/buffer_test_io.h
index 03d5419..3cadc48 100644
--- a/testsuites/support/include/buffer_test_io.h
+++ b/testsuites/support/include/buffer_test_io.h
@@ -5,6 +5,8 @@
 #ifndef __BUFFER_TEST_IO_h
 #define __BUFFER_TEST_IO_h
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -54,6 +56,10 @@ extern "C" {
     do { \
     } while (0)
+  #define TEST_BEGIN() rtems_test_begink()
+  #define TEST_END() rtems_test_endk()
  *  BUFFER TEST OUTPUT
@@ -152,6 +158,10 @@ extern "C" {
       fflush(stdout); \
     } while (0)
+  #define TEST_BEGIN() rtems_test_begin()
+  #define TEST_END() rtems_test_end()
  *  USE IPRINT
@@ -197,6 +207,12 @@ extern "C" {
       fflush(stdout); \
     } while (0)
+  #define TEST_BEGIN() \
+    rtems_test_begin_with_plugin((rtems_printk_plugin_t) fiprintf, stderr)
+  #define TEST_END() \
+    rtems_test_end_with_plugin((rtems_printk_plugin_t) fiprintf, stderr)
 #endif
 #ifdef __cplusplus
1.7.7
