[PATCH 2/2] tests/samples: Use <rtems/test.h>
Mon Mar 10 15:35:39 UTC 2014
 testsuites/samples/base_mp/apptask.c |    2 +-
 testsuites/samples/base_mp/init.c    |    4 +++-
 testsuites/samples/base_mp/system.h  |    3 +++
 testsuites/samples/base_sp/apptask.c |    2 +-
 testsuites/samples/base_sp/init.c    |    4 +++-
 testsuites/samples/base_sp/system.h  |    3 +++
 testsuites/samples/capture/init.c    |    6 ++++--
 testsuites/samples/capture/system.h  |    3 +++
 testsuites/samples/cdtest/main.cc    |    8 +++++---
 testsuites/samples/cdtest/system.h   |    3 +++
 testsuites/samples/fileio/init.c     |    6 ++++--
 testsuites/samples/fileio/system.h   |    4 ++++
 testsuites/samples/hello/init.c      |   10 ++++++++--
 testsuites/samples/iostream/init.cc  |    6 ++++--
 testsuites/samples/iostream/system.h |    3 +++
 testsuites/samples/loopback/init.c   |   10 +++++++++-
 testsuites/samples/nsecs/init.c      |    6 ++++--
 testsuites/samples/nsecs/system.h    |    4 ++++
 testsuites/samples/paranoia/init.c   |    6 ++++--
 testsuites/samples/paranoia/system.h |    3 +++
 testsuites/samples/pppd/init.c       |    4 ++++
 testsuites/samples/pppd/system.h     |    3 +++
 testsuites/samples/ticker/init.c     |    4 +++-
 testsuites/samples/ticker/system.h   |    3 +++
 testsuites/samples/ticker/tasks.c    |    2 +-
 testsuites/samples/unlimited/init.c  |    8 +++++---
 26 files changed, 95 insertions(+), 25 deletions(-)
diff --git a/testsuites/samples/base_mp/apptask.c b/testsuites/samples/base_mp/apptask.c
index a9ddc7f..4af9048 100644
--- a/testsuites/samples/base_mp/apptask.c
+++ b/testsuites/samples/base_mp/apptask.c
@@ -37,6 +37,6 @@ rtems_task Application_task(
   status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
   printf( "This task was invoked with the node argument (%" PRIdrtems_task_argument ")\n", node );
   printf( "This task has the id of 0x%" PRIxrtems_id "\n",  tid );
-  printf( "*** END OF SAMPLE MULTIPROCESSOR APPLICATION ***\n" );
+  TEST_END();
   exit( 0 );
diff --git a/testsuites/samples/base_mp/init.c b/testsuites/samples/base_mp/init.c
index e2a9b84..e7780ac 100644
--- a/testsuites/samples/base_mp/init.c
+++ b/testsuites/samples/base_mp/init.c
@@ -18,6 +18,8 @@
 /* forward declarations to avoid warnings */
 rtems_task Init(rtems_task_argument argument);
+const char rtems_test_name[] = "SAMPLE MULTIPROCESSOR APPLICATION";
 rtems_task Init(
@@ -26,7 +28,7 @@ rtems_task Init(
   rtems_id          tid;
   rtems_status_code status;
-  printf( "\n\n*** SAMPLE MULTIPROCESSOR APPLICATION ***\n" );
+  TEST_BEGIN();
   printf( "Creating and starting an application task\n" );
   task_name = rtems_build_name( 'T', 'A', '1', ' ' );
   status = rtems_task_create( task_name, 1, RTEMS_MINIMUM_STACK_SIZE,
diff --git a/testsuites/samples/base_mp/system.h b/testsuites/samples/base_mp/system.h
index e8210f2..45d8b7f 100644
--- a/testsuites/samples/base_mp/system.h
+++ b/testsuites/samples/base_mp/system.h
@@ -12,6 +12,7 @@
+#include <rtems/test.h>
 /* functions */
@@ -36,6 +37,8 @@ rtems_task Application_task(
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
  *  Put the overrides of default configuration parameters here.
diff --git a/testsuites/samples/base_sp/apptask.c b/testsuites/samples/base_sp/apptask.c
index 379e5c3..a7780d0 100644
--- a/testsuites/samples/base_sp/apptask.c
+++ b/testsuites/samples/base_sp/apptask.c
@@ -41,6 +41,6 @@ rtems_task Application_task(
     "and has id of 0x%" PRIxrtems_id "\n", argument, tid
-  printf( "*** END OF SAMPLE SINGLE PROCESSOR APPLICATION ***\n" );
+  TEST_END();
   exit( 0 );
diff --git a/testsuites/samples/base_sp/init.c b/testsuites/samples/base_sp/init.c
index 8ad2eed..5dcbf6d 100644
--- a/testsuites/samples/base_sp/init.c
+++ b/testsuites/samples/base_sp/init.c
@@ -19,6 +19,8 @@
+const char rtems_test_name[] = "SAMPLE SINGLE PROCESSOR APPLICATION";
 #define ARGUMENT 0
 rtems_task Init(
@@ -29,7 +31,7 @@ rtems_task Init(
   rtems_id          tid;
-  printf( "\n\n*** SAMPLE SINGLE PROCESSOR APPLICATION ***\n" );
+  TEST_BEGIN();
diff --git a/testsuites/samples/base_sp/system.h b/testsuites/samples/base_sp/system.h
index aa04d0a..837b52d 100644
--- a/testsuites/samples/base_sp/system.h
+++ b/testsuites/samples/base_sp/system.h
@@ -12,6 +12,7 @@
 /* functions */
@@ -33,6 +34,8 @@ rtems_task Application_task(
 #define CONFIGURE_MAXIMUM_TASKS            2
 #include <rtems/confdefs.h>
 /* end of include file */
diff --git a/testsuites/samples/capture/init.c b/testsuites/samples/capture/init.c
index 67f87dd..40562f4 100644
--- a/testsuites/samples/capture/init.c
+++ b/testsuites/samples/capture/init.c
@@ -28,6 +28,8 @@ rtems_task Init(rtems_task_argument argument);
   static void notification(int fd, int seconds_remaining, void *arg);
 #endif
+const char rtems_test_name[] = "CAPTURE ENGINE";
 volatile int can_proceed = 1;
 #if !BSP_SMALL_MEMORY
@@ -51,7 +53,7 @@ rtems_task Init(
   rtems_task_priority old_priority;
   rtems_mode          old_mode;
-  puts( "\n\n*** TEST CAPTURE ENGINE ***" );
+  rtems_test_begin();
   status = rtems_shell_wait_for_input(
     STDIN_FILENO,
@@ -78,7 +80,7 @@ rtems_task Init(
     rtems_task_delete (RTEMS_SELF);
   } else {
-    puts( "*** END OF TEST CAPTURE ENGINE ***" );
+    rtems_test_end();
     exit( 0 );
diff --git a/testsuites/samples/capture/system.h b/testsuites/samples/capture/system.h
index cbc6137..224800a 100644
--- a/testsuites/samples/capture/system.h
+++ b/testsuites/samples/capture/system.h
@@ -12,6 +12,7 @@
 /* functions */
@@ -49,6 +50,8 @@ extern void setup_tasks_to_watch(void);
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS (5)
diff --git a/testsuites/samples/cdtest/main.cc b/testsuites/samples/cdtest/main.cc
index 5edfc70..23a98fc 100644
--- a/testsuites/samples/cdtest/main.cc
+++ b/testsuites/samples/cdtest/main.cc
@@ -23,6 +23,7 @@
 #include <cstdio>
 #include <cstdlib>
@@ -31,6 +32,8 @@
 #include <iostream>
 #endif
+const char rtems_test_name[] = "CONSTRUCTOR/DESTRUCTOR";
 extern "C"
 #include <tmacros.h>
@@ -176,12 +179,11 @@ rtems_task main_task(
   rtems_task_argument
-    printf( "\n\n*** CONSTRUCTOR/DESTRUCTOR TEST ***\n" );
+    TEST_BEGIN();
     cdtest();
-    printf( "*** END OF CONSTRUCTOR/DESTRUCTOR TEST ***\n\n\n" );
+    TEST_END();
     printf( "*** TESTING C++ EXCEPTIONS ***\n\n" );
diff --git a/testsuites/samples/cdtest/system.h b/testsuites/samples/cdtest/system.h
index f9f13c2..90789fc 100644
--- a/testsuites/samples/cdtest/system.h
+++ b/testsuites/samples/cdtest/system.h
@@ -12,6 +12,7 @@
 /* functions */
@@ -33,6 +34,8 @@ rtems_task main_task(
 #define CONFIGURE_INIT_TASK_ENTRY_POINT   main_task
 #define CONFIGURE_INIT_TASK_NAME          rtems_build_name( 'C', 'T', 'O', 'R' )
diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
index 75d16a4..80da4ab 100644
--- a/testsuites/samples/fileio/init.c
+++ b/testsuites/samples/fileio/init.c
@@ -32,6 +32,8 @@
 #include <rtems/nvdisk-sram.h>
 #include <rtems/shell.h>
+const char rtems_test_name[] = "FILE I/O";
 #if FILEIO_BUILD
@@ -1220,7 +1222,7 @@ Init (rtems_task_argument ignored)
   rtems_id   Task_id;
-  puts( "\n\n*** TEST FILE I/O SAMPLE ***" );
+  TEST_BEGIN();
     STDIN_FILENO,
@@ -1244,7 +1246,7 @@ Init (rtems_task_argument ignored)
     status = rtems_task_delete( RTEMS_SELF );
     directive_failed( status, "delete" );
   } else {
-    puts( "*** END OF TEST FILE I/O SAMPLE ***" );
+    TEST_END();
     rtems_test_exit( 0 );
diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
index 1e575b6..726a507 100644
--- a/testsuites/samples/fileio/system.h
+++ b/testsuites/samples/fileio/system.h
@@ -12,6 +12,7 @@
 #include "tmacros.h"
 /* functions */
@@ -72,6 +73,9 @@ rtems_task Init(
 #define CONFIGURE_MALLOC_STATISTICS
 #define CONFIGURE_UNIFIED_WORK_AREAS
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index 8a44a88..3949c8d 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -11,6 +11,8 @@
 #include "config.h"
 #endif
 #include <bsp.h> /* for device driver prototypes */
@@ -19,13 +21,15 @@
+const char rtems_test_name[] = "HELLO WORLD";
 rtems_task Init(
-  printf( "\n\n*** HELLO WORLD TEST ***\n" );
   printf( "Hello World\n" );
-  printf( "*** END OF HELLO WORLD TEST ***\n" );
+  rtems_test_end();
   exit( 0 );
@@ -39,5 +43,7 @@ rtems_task Init(
diff --git a/testsuites/samples/iostream/init.cc b/testsuites/samples/iostream/init.cc
index c3dbec4..770d26f 100644
--- a/testsuites/samples/iostream/init.cc
+++ b/testsuites/samples/iostream/init.cc
@@ -29,6 +29,8 @@
 rtems_task Init(
@@ -36,9 +38,9 @@ rtems_task Init(
 #if BSP_SMALL_MEMORY
   printf ("NO STDC++. MEMORY TOO SMALL");
 #else
-  std::cout << "\n\n*** HELLO WORLD TEST ***" << std::endl;
+  std::cout << "\n\n*** " << rtems_test_name << " TEST ***" << std::endl;
   std::cout << "Hello World" << std::endl;
-  std::cout << "*** END OF HELLO WORLD TEST ***" << std::endl;
+  std::cout << "*** END OF " << rtems_test_name << " TEST ***" << std::endl;
 #endif
   exit( 0 );
diff --git a/testsuites/samples/iostream/system.h b/testsuites/samples/iostream/system.h
index cf144cc..ebe5380 100644
--- a/testsuites/samples/iostream/system.h
+++ b/testsuites/samples/iostream/system.h
@@ -12,6 +12,7 @@
 /* configuration information */
@@ -33,6 +34,8 @@
 /* Only remove when this macro is removed from confdefs.h. It tests it. */
 #define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
diff --git a/testsuites/samples/loopback/init.c b/testsuites/samples/loopback/init.c
index 398dbe7..c01d138 100644
--- a/testsuites/samples/loopback/init.c
+++ b/testsuites/samples/loopback/init.c
@@ -8,8 +8,12 @@
 #include "config.h"
 #endif
 #include <bsp.h>
+const char rtems_test_name[] = "LOOPBACK";
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
@@ -33,6 +37,8 @@
@@ -241,6 +247,8 @@ Init (rtems_task_argument ignored)
     rtems_status_code sc;
     sc = rtems_semaphore_create(rtems_build_name('P','m','t','x'),
                 1,
                 RTEMS_PRIORITY|RTEMS_BINARY_SEMAPHORE|RTEMS_INHERIT_PRIORITY|
@@ -275,7 +283,7 @@ Init (rtems_task_argument ignored)
     spawnTask(clientTask, 120, 6);
     rtems_task_wake_after(500);
-    puts( "*** END OF LOOPBACK TEST ***" );
+    rtems_test_end();
     exit( 0 );
 #else
diff --git a/testsuites/samples/nsecs/init.c b/testsuites/samples/nsecs/init.c
index fe5390d..e9fff63 100644
--- a/testsuites/samples/nsecs/init.c
+++ b/testsuites/samples/nsecs/init.c
@@ -34,6 +34,8 @@
 #include "pritime.h"
+const char rtems_test_name[] = "NANOSECOND CLOCK";
 static char *my_ctime( time_t t )
   static char b[32];
@@ -62,7 +64,7 @@ rtems_task Init(
   rtems_time_of_day time;
   int index;
-  puts( "\n\n*** NANOSECOND CLOCK TEST ***" );
+  TEST_BEGIN();
   time.year   = 2007;
   time.month  = 03;
@@ -137,7 +139,7 @@ rtems_task Init(
   sleep(1);
-  puts( "*** END OF NANOSECOND CLOCK TEST ***" );
+  TEST_END();
   exit(0);
diff --git a/testsuites/samples/nsecs/system.h b/testsuites/samples/nsecs/system.h
index a9d2ac6..25f7d31 100644
--- a/testsuites/samples/nsecs/system.h
+++ b/testsuites/samples/nsecs/system.h
@@ -1,6 +1,8 @@
 #ifndef SYSTEM_H
 #define SYSTEM_H
 extern void dummy_function_empty_body_to_force_call(void);
@@ -12,5 +14,7 @@ extern void dummy_function_empty_body_to_force_call(void);
 #define CONFIGURE_MAXIMUM_TASKS            1
 #endif
diff --git a/testsuites/samples/paranoia/init.c b/testsuites/samples/paranoia/init.c
index bd23c33..9a2f65e 100644
--- a/testsuites/samples/paranoia/init.c
+++ b/testsuites/samples/paranoia/init.c
@@ -18,6 +18,8 @@
 extern int paranoia(int, char **);
+const char rtems_test_name[] = "PARANOIA";
 char *args[2] = { "paranoia", 0 };
 rtems_task Init(
@@ -37,9 +39,9 @@ rtems_task Init(
   M68KFPSPInstallExceptionHandlers ();
 #endif
-  printf( "\n\n*** PARANOIA TEST ***\n" );
   paranoia(1, args);
-  printf( "*** END OF PARANOIA TEST ***\n" );
+  rtems_test_end();
 #endif /* BSP_SMALL_MEMORY */
   exit( 0 );
diff --git a/testsuites/samples/paranoia/system.h b/testsuites/samples/paranoia/system.h
index 3b522d1..aaadb35 100644
--- a/testsuites/samples/paranoia/system.h
+++ b/testsuites/samples/paranoia/system.h
@@ -12,6 +12,7 @@
 /* functions */
@@ -34,6 +35,8 @@ rtems_task Init(
 #define CONFIGURE_EXTRA_TASK_STACKS       (1 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/samples/pppd/init.c b/testsuites/samples/pppd/init.c
index 4519ad6..44b2760 100644
--- a/testsuites/samples/pppd/init.c
+++ b/testsuites/samples/pppd/init.c
@@ -24,11 +24,15 @@
 #include "netconfig.h"
 #endif
+const char rtems_test_name[] = "PPPD";
   printf("NO NETWORKING. MEMORY TOO SMALL");
 #else
   /* initialize network */
   rtems_bsdnet_initialize_network();
   rtems_pppd_initialize();
diff --git a/testsuites/samples/pppd/system.h b/testsuites/samples/pppd/system.h
index 5e70ddb..a2282ac 100644
--- a/testsuites/samples/pppd/system.h
+++ b/testsuites/samples/pppd/system.h
@@ -2,6 +2,7 @@
 #define SYSTEM_H
 #include <rtems/console.h>
 #include <rtems/clockdrv.h>
@@ -40,6 +41,8 @@ extern int pppdapp_initialize(void);
                                            RTEMS_NO_ASR | \
                                            RTEMS_INTERRUPT_LEVEL(0))
 #endif
diff --git a/testsuites/samples/ticker/init.c b/testsuites/samples/ticker/init.c
index d9366f8..3df984c 100644
--- a/testsuites/samples/ticker/init.c
+++ b/testsuites/samples/ticker/init.c
@@ -14,6 +14,8 @@
 #include "system.h"
+const char rtems_test_name[] = "CLOCK TICK";
  *  Keep the names and IDs in global variables so another task can use them.
@@ -28,7 +30,7 @@ rtems_task Init(
-  puts( "\n\n*** CLOCK TICK TEST ***" );
+  TEST_BEGIN();
   time.year   = 1988;
   time.month  = 12;
diff --git a/testsuites/samples/ticker/system.h b/testsuites/samples/ticker/system.h
index f5ac4d8..98add53 100644
--- a/testsuites/samples/ticker/system.h
+++ b/testsuites/samples/ticker/system.h
@@ -12,6 +12,7 @@
 #include <inttypes.h>
@@ -48,6 +49,8 @@ extern rtems_name Task_name[ 4 ];       /* array of task names */
 #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/samples/ticker/tasks.c b/testsuites/samples/ticker/tasks.c
index bdff3a3..146a80b 100644
--- a/testsuites/samples/ticker/tasks.c
+++ b/testsuites/samples/ticker/tasks.c
@@ -37,7 +37,7 @@ rtems_task Test_task(
   for ( ; ; ) {
     status = rtems_clock_get_tod( &time );
     if ( time.second >= 35 ) {
-      puts( "*** END OF CLOCK TICK TEST ***" );
+      TEST_END();
     put_name( Task_name[ task_index ], FALSE );
diff --git a/testsuites/samples/unlimited/init.c b/testsuites/samples/unlimited/init.c
index a4eb167..3b79af2 100644
--- a/testsuites/samples/unlimited/init.c
+++ b/testsuites/samples/unlimited/init.c
@@ -18,6 +18,8 @@
+const char rtems_test_name[] = "UNLIMITED TASK";
 rtems_id task_id[MAX_TASKS];
 rtems_task Init(
@@ -28,14 +30,14 @@ rtems_task Init(
   uint32_t            task;
+  TEST_BEGIN();
   /* lower the task priority to allow created tasks to execute */
   rtems_task_set_priority(
     RTEMS_SELF, RTEMS_MAXIMUM_PRIORITY - 1, &old_priority);
   rtems_task_mode(RTEMS_PREEMPT,  RTEMS_PREEMPT_MASK, &old_mode);
-  printf( "\n*** UNLIMITED TASK TEST ***\n" );
    * Invalid state if the task id is 0
@@ -47,7 +49,7 @@ rtems_task Init(
   test2();
   test3();
-  printf( "\n*** END OF UNLIMITED TASK TEST ***\n" );
+  TEST_END();
   exit( 0 );
1.7.7
