Documentation
Thu Mar 13 11:44:18 UTC 2014
Hello,
I tried to find a good place for the user-level profiling documentation and I
struggled again with the Doxygen vs. Texinfo duplication.  I raised this issue
several times over the last years, but we cannot carry on with this parallel
structure forever.  I think it is quite hard to navigate through the HTML
version of the user guide
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/index.html
and the visual appearance is not state of the art.  So we should convert the
user guide in the long run to a modern documentation system.  I don't care if
this is Doxygen or something else, but it must support API documentation
generation from the sources.  You have for example
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Event-Manager-Sending-an-Event-Set.html#Event-Manager-Sending-an-Event-Set
and on another page
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Event-Manager-EVENT_005fSEND-_002d-Send-event-set-to-a-task.html#Event-Manager-EVENT_005fSEND-_002d-Send-event-set-to-a-task
also in Doxygen
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicEvent.html#ga2d31674c165127bc530178d06d557b94
A lot of copy and paste is involved here and writing stuff for the Texinfo is
always a pleasure.
My proposal is still to use Doxygen simply because we already spent a huge
amount of work for it and it has from my point of view all features we require
(in source documentation, book style parts, graphs, formulas, message diagrams,
HTML and PDF output), e.g.
http://www.stack.nl/~dimitri/doxygen/manual/commands.html#cmdpage
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicEventTransient.html
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__bdbuf.html#details
I am open for alternatives, but we should really stop using two systems for the
documentation.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
