[PATCH 4/7] smc91111: Move driver attach prototype to header file.
Daniel Cederman cederman at gaisler.com
Thu Mar 13 14:19:32 UTC 2014
 .../lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c |    5 -----
 .../sparc/leon2/leon_smc91111/leon_smc91111.c      |    5 -----
 .../sparc/leon3/leon_smc91111/leon_smc91111.c      |    3 ---
 c/src/libchip/network/smc91111.c                   |    7 ++++---
 c/src/libchip/network/smc91111exp.h                |    3 +++
 5 files changed, 7 insertions(+), 16 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
index 026a56c..995bf0b 100644
--- a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
+++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
@@ -64,11 +64,6 @@ scmv91111_configuration_t mpc5554_scmv91111_configuration = {
   (void *)0
-int _rtems_smc91111_driver_attach(
-  struct rtems_bsdnet_ifconfig *config,
-  scmv91111_configuration_t    *scm_config
  * Attach an SMC91111 driver to the system
diff --git a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
index ad74c9a..abf1efc 100644
--- a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
+++ b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
@@ -40,11 +40,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
   1                   /* autoneg */
diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
index 9b9961d..a57de8f 100644
--- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
+++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
@@ -23,9 +23,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
   1                                   /* autoneg */
-int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
-				   scmv91111_configuration_t * scm_config);
diff --git a/c/src/libchip/network/smc91111.c b/c/src/libchip/network/smc91111.c
index 2332688..6628ad5 100644
--- a/c/src/libchip/network/smc91111.c
+++ b/c/src/libchip/network/smc91111.c
@@ -82,7 +82,7 @@ static void lan91cxx_phy_configure(struct lan91cxx_priv_data *cpd);
 #define max(l,r) ((l) > (r) ? (l) : (r))
 /* \ ------------- Interrupt ------------- \ */
-void lan91cxx_interrupt_handler(void *arg)
+static void lan91cxx_interrupt_handler(void *arg)
 	struct lan91cxx_priv_data *cpd = arg;
 	unsigned short irq, event;
@@ -247,7 +247,8 @@ static void lan91cxx_recv(struct lan91cxx_priv_data *cpd, struct mbuf *m)
 		db64_printf(" \n");
+#else
+		(void)start;
 #endif
 	val = get_data(cpd);	/* Read control word (and potential data) unconditionally */
@@ -657,7 +658,7 @@ static void sendpacket(struct ifnet *ifp, struct mbuf *m)
 	dbg_prefix = "";
-void smc91111_txDaemon(void *arg)
+static void smc91111_txDaemon(void *arg)
 	struct ifnet *ifp = &cpd->arpcom.ac_if;
diff --git a/c/src/libchip/network/smc91111exp.h b/c/src/libchip/network/smc91111exp.h
index 11feaab..08e086d 100644
--- a/c/src/libchip/network/smc91111exp.h
+++ b/c/src/libchip/network/smc91111exp.h
@@ -18,6 +18,9 @@ typedef struct scmv91111_configuration {
 #endif
 } scmv91111_configuration_t;
+int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
+				   scmv91111_configuration_t * scm_config);
 #endif  /* _SMC_91111_EXP_H_ */
1.7.9.5
