[PATCH 4/7] smc91111: Move driver attach prototype to header file.
Thu Mar 13 14:30:15 UTC 2014
One comment below which doesn't match your description.
On 3/13/2014 9:19 AM, Daniel Cederman wrote:
>  .../lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c |    5 -----
>  .../sparc/leon2/leon_smc91111/leon_smc91111.c      |    5 -----
>  .../sparc/leon3/leon_smc91111/leon_smc91111.c      |    3 ---
>  c/src/libchip/network/smc91111.c                   |    7 ++++---
>  c/src/libchip/network/smc91111exp.h                |    3 +++
>  5 files changed, 7 insertions(+), 16 deletions(-)
> diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
> index 026a56c..995bf0b 100644
> --- a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
> +++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
> @@ -64,11 +64,6 @@ scmv91111_configuration_t mpc5554_scmv91111_configuration = {
>    (void *)0
> -int _rtems_smc91111_driver_attach(
> -  struct rtems_bsdnet_ifconfig *config,
> -  scmv91111_configuration_t    *scm_config
>   * Attach an SMC91111 driver to the system
> diff --git a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
> index ad74c9a..abf1efc 100644
> --- a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
> +++ b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
> @@ -40,11 +40,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
>    1                   /* autoneg */
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> index 9b9961d..a57de8f 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> @@ -23,9 +23,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
>    1                                   /* autoneg */
> -int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
> -				   scmv91111_configuration_t * scm_config);
> diff --git a/c/src/libchip/network/smc91111.c b/c/src/libchip/network/smc91111.c
> index 2332688..6628ad5 100644
> --- a/c/src/libchip/network/smc91111.c
> +++ b/c/src/libchip/network/smc91111.c
> @@ -82,7 +82,7 @@ static void lan91cxx_phy_configure(struct lan91cxx_priv_data *cpd);
>  #define max(l,r) ((l) > (r) ? (l) : (r))
>  /* \ ------------- Interrupt ------------- \ */
> -void lan91cxx_interrupt_handler(void *arg)
> +static void lan91cxx_interrupt_handler(void *arg)
>  	struct lan91cxx_priv_data *cpd = arg;
>  	unsigned short irq, event;
> @@ -247,7 +247,8 @@ static void lan91cxx_recv(struct lan91cxx_priv_data *cpd, struct mbuf *m)
>  		db64_printf(" \n");
> +#else
> +		(void)start;
>  #endif
Why this change?
>  	val = get_data(cpd);	/* Read control word (and potential data) unconditionally */
> @@ -657,7 +658,7 @@ static void sendpacket(struct ifnet *ifp, struct mbuf *m)
>  	dbg_prefix = "";
> -void smc91111_txDaemon(void *arg)
> +static void smc91111_txDaemon(void *arg)
>  	struct ifnet *ifp = &cpd->arpcom.ac_if;
> diff --git a/c/src/libchip/network/smc91111exp.h b/c/src/libchip/network/smc91111exp.h
> index 11feaab..08e086d 100644
> --- a/c/src/libchip/network/smc91111exp.h
> +++ b/c/src/libchip/network/smc91111exp.h
> @@ -18,6 +18,9 @@ typedef struct scmv91111_configuration {
>  #endif
>  } scmv91111_configuration_t;
> +int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
> +				   scmv91111_configuration_t * scm_config);
>  #endif  /* _SMC_91111_EXP_H_ */
