[PATCH 4/7] smc91111: Move driver attach prototype to header file.
Daniel Cederman cederman at gaisler.com
Fri Mar 14 08:59:44 UTC 2014
On 2014-03-13 15:30, Joel Sherrill wrote:
> One comment below which doesn't match your description.
> On 3/13/2014 9:19 AM, Daniel Cederman wrote:
>>   .../lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c |    5 -----
>>   .../sparc/leon2/leon_smc91111/leon_smc91111.c      |    5 -----
>>   .../sparc/leon3/leon_smc91111/leon_smc91111.c      |    3 ---
>>   c/src/libchip/network/smc91111.c                   |    7 ++++---
>>   c/src/libchip/network/smc91111exp.h                |    3 +++
>>   5 files changed, 7 insertions(+), 16 deletions(-)
>> diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
>> index 026a56c..995bf0b 100644
>> --- a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
>> +++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
>> @@ -64,11 +64,6 @@ scmv91111_configuration_t mpc5554_scmv91111_configuration = {
>>     (void *)0
>> -int _rtems_smc91111_driver_attach(
>> -  struct rtems_bsdnet_ifconfig *config,
>> -  scmv91111_configuration_t    *scm_config
>>    * Attach an SMC91111 driver to the system
>> diff --git a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
>> index ad74c9a..abf1efc 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
>> +++ b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
>> @@ -40,11 +40,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
>>     1                   /* autoneg */
>> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>> index 9b9961d..a57de8f 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>> @@ -23,9 +23,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
>>     1                                   /* autoneg */
>> -int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
>> -				   scmv91111_configuration_t * scm_config);
>> diff --git a/c/src/libchip/network/smc91111.c b/c/src/libchip/network/smc91111.c
>> index 2332688..6628ad5 100644
>> --- a/c/src/libchip/network/smc91111.c
>> +++ b/c/src/libchip/network/smc91111.c
>> @@ -82,7 +82,7 @@ static void lan91cxx_phy_configure(struct lan91cxx_priv_data *cpd);
>>   #define max(l,r) ((l) > (r) ? (l) : (r))
>>   /* \ ------------- Interrupt ------------- \ */
>> -void lan91cxx_interrupt_handler(void *arg)
>> +static void lan91cxx_interrupt_handler(void *arg)
>>   	struct lan91cxx_priv_data *cpd = arg;
>>   	unsigned short irq, event;
>> @@ -247,7 +247,8 @@ static void lan91cxx_recv(struct lan91cxx_priv_data *cpd, struct mbuf *m)
>>   		db64_printf(" \n");
>> +#else
>> +		(void)start;
>>   #endif
> Why this change?
start is set in multiple places but only used when debugging is enabled.
So to remove the warning when debugging is not enabled I added the ifdef
to signal to the compiler that start is not used. Should I update the
description or make a new patch?
>>   	val = get_data(cpd);	/* Read control word (and potential data) unconditionally */
>> @@ -657,7 +658,7 @@ static void sendpacket(struct ifnet *ifp, struct mbuf *m)
>>   	dbg_prefix = "";
>> -void smc91111_txDaemon(void *arg)
>> +static void smc91111_txDaemon(void *arg)
>>   	struct ifnet *ifp = &cpd->arpcom.ac_if;
>> diff --git a/c/src/libchip/network/smc91111exp.h b/c/src/libchip/network/smc91111exp.h
>> index 11feaab..08e086d 100644
>> --- a/c/src/libchip/network/smc91111exp.h
>> +++ b/c/src/libchip/network/smc91111exp.h
>> @@ -18,6 +18,9 @@ typedef struct scmv91111_configuration {
>>   #endif
>>   } scmv91111_configuration_t;
>> +int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
>> +				   scmv91111_configuration_t * scm_config);
>>   #endif  /* _SMC_91111_EXP_H_ */
