SMC91111 performance and copyright
Peter Dufault
dufault at hda.com
Sat Mar 15 18:40:07 UTC 2014
I'm including you directly, Daniel, since you've done some recent patches for the SMC91111 driver on the Sparc. That's the only place I think it's used other than on the Phytec MPC5554. If anyone else is using it then I'd love to know.
The SMC91111 performance on the Phytec Phycore board is horrible. I haven't worried about it since I use it to boot, store some log files and accept remote commands (that don't happen that often), but I would like to fully use it and I'm trying to figure out why the performance is so bad.
My initial results using the ttcp benchmark were 133 KB/sec linux->RTEMS and 134 RTEMS->Linux. I managed to get it quite a bit better using 16 bit transfers instead of 32 bit, and by using wireless instead of wired (obviously it's falling down under loading).
Looking at Wireshark I see that everything runs great for a short amount of time and then there are lots of retransmissions and "out-of-order bytes received". I don't understand this enough to know what's going on, but I think once traffic is flowing the driver breaks down. So as long as things are very lightly loaded it works OK, as soon as it is busy it will fall down. It does work reliably, but very slowly.
I looked what I think are later versions of this driver from eCOS. They are GPL and also have changes where I think they check for activity in places that the RTEMS driver doesn't, that is, poll for input during output, etc. I have at least three questions:
- The RTEMS driver has no copyright. Is this because it pre-dates a copyright from eCOS?
- Is this driver in active use and works just fine on SPARC?
- There's a FreeBSD driver for this. Am I better trying to port that than fix the existing driver?
Here's what comes out of the ttcp test. As I said, I don't know much about this, but all those "out-of-order bytes" are odd.
************ IP Statistics ************
total packets received 19050
packets rcvd for unreachable dest 1931
datagrams delivered to upper level 17119
total ip packets generated here 9546
************ TCP Statistics ************
connections accepted 1
connections established 1
conn. closed (includes drops) 1
segs where we tried to get rtt 2
times we succeeded 2
delayed acks sent 109
total packets sent 9540
ack-only packets sent 6034
window update-only packets sent 3505
control (SYN|FIN|RST) packets sent 1
total packets received 11636
packets received in sequence 5709
bytes received in sequence 8260600
duplicate-only packets received 38
duplicate-only bytes received 53576
out-of-order packets received 5885
out-of-order bytes received 8516616
rcvd duplicate acks 34
rcvd ack packets 2
bytes acked by rcvd acks 2
times hdr predict ok for data pkts 5707
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
