null
James Fitzsimons james.fitzsimons at gmail.com
Sat Mar 15 22:50:15 UTC 2014
Hi Joel,
There should have been two patches, although it looks like git send-email
sent three separate emails for some reason. It's my first go at using git
send-email and I was trying to follow the instructions here
http://wiki.rtems.org/wiki/index.php/Git_Users#Sending_Email - although
clearly I got something wrong.
I've attached the patches to this email.
I changed the compiler optimization flag to -Os, and I also tried using
KEEP with --gc-sections but I still couldn't build with --enable-tests as I
kept getting the linker overflow error building the utf8proc01 test due to
the code size being to large for the target. Seems like ideally you'd be
able to configure which tests should be
built for a given bsp to avoid that sort of problem.
Cheers,
James
On 16 March 2014 05:24, Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
>  Were there supposed to be patches attached?
> I only see one email with the patch to change to -Os. How much difference
> did that make?
> On Mar 14, 2014 9:33 PM, James Fitzsimons <james.fitzsimons at gmail.com>
> wrote:
> These patches contain the changes required to get the mrm332 bsp working
> again.
> Has been tested against HEAD and ticker and hello samples work correclty.
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140316/df71a9db/attachment-0001.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140316/df71a9db/attachment-0002.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140316/df71a9db/attachment-0003.bin>
