[PATCH] score: Unify pthread and gxx_wrapper once and move to score.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Mar 20 07:44:05 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 cpukit/libcsupport/src/gxx_wrappers.c       | 15 +-------
 cpukit/posix/src/pthreadonce.c              | 37 +-----------------
 cpukit/score/Makefile.am                    |  2 +
 cpukit/score/include/rtems/score/onceimpl.h | 50 ++++++++++++++++++++++++
 cpukit/score/preinstall.am                  | 10 +++--
 cpukit/score/src/once.c                     | 60 +++++++++++++++++++++++++++++
 6 files changed, 123 insertions(+), 51 deletions(-)
 create mode 100644 cpukit/score/include/rtems/score/onceimpl.h
 create mode 100644 cpukit/score/src/once.c
diff --git a/cpukit/libcsupport/src/gxx_wrappers.c b/cpukit/libcsupport/src/gxx_wrappers.c
index 31f6254..711daa4 100644
--- a/cpukit/libcsupport/src/gxx_wrappers.c
+++ b/cpukit/libcsupport/src/gxx_wrappers.c
@@ -29,6 +29,7 @@
 #endif
 #include <rtems/gxx_wrappers.h>
+#include <rtems/score/onceimpl.h>
@@ -43,19 +44,7 @@ int rtems_gxx_once(__gthread_once_t *once, void (*func) (void))
     printk( "gxx_wrappers: once=%x, func=%x\n", *once, func );
   #endif
-  if ( *(volatile __gthread_once_t *)once == 0 ) {
-    rtems_mode saveMode;
-    __gthread_once_t o;
-    rtems_task_mode(RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &saveMode);
-    if ( (o = *(volatile __gthread_once_t *)once) == 0 ) {
-      *(volatile __gthread_once_t *)once = 1;
-    rtems_task_mode(saveMode, RTEMS_PREEMPT_MASK, &saveMode);
-    if ( o == 0 )
-      (*func)();
-  return 0;
+  return _Once( once, func );
 int rtems_gxx_key_create (__gthread_key_t *key, void (*dtor) (void *))
diff --git a/cpukit/posix/src/pthreadonce.c b/cpukit/posix/src/pthreadonce.c
index 6b8274d..295bc57 100644
--- a/cpukit/posix/src/pthreadonce.c
+++ b/cpukit/posix/src/pthreadonce.c
@@ -23,51 +23,18 @@
 #include <pthread.h>
-#include <rtems/score/apimutex.h>
-#define PTHREAD_ONCE_INIT_NOT_RUN  0
-#define PTHREAD_ONCE_INIT_RUNNING  1
-#define PTHREAD_ONCE_INIT_COMPLETE 2
 int pthread_once(
   pthread_once_t  *once_control,
   void           (*init_routine)(void)
-  int r = 0;
   if ( !once_control || !init_routine )
     return EINVAL;
   if ( once_control->is_initialized != 1 )
     return EINVAL;
-  if ( once_control->init_executed != PTHREAD_ONCE_INIT_COMPLETE ) {
-    _Once_Lock();
-     * Getting to here means the once_control is locked so we have:
-     *  1. The init has not run and the state is PTHREAD_ONCE_INIT_NOT_RUN.
-     *  2. The init has finished and the state is PTHREAD_ONCE_INIT_RUN.
-     *  3. The init is being run by this thread and the state
-     *     PTHREAD_ONCE_INIT_RUNNING so we are nesting. This is an error.
-    switch ( once_control->init_executed ) {
-      case PTHREAD_ONCE_INIT_NOT_RUN:
-        once_control->init_executed = PTHREAD_ONCE_INIT_RUNNING;
-        (*init_routine)();
-        once_control->init_executed = PTHREAD_ONCE_INIT_COMPLETE;
-        break;
-      case PTHREAD_ONCE_INIT_RUNNING:
-        r = EINVAL;
-        break;
-      default:
-        break;
-    _Once_Unlock();
-  return r;
+  return _Once( &once_control->init_executed, init_routine );
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 6c4293a..aeee4b6 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -41,6 +41,7 @@ include_rtems_score_HEADERS += include/rtems/score/isrlock.h
 include_rtems_score_HEADERS += include/rtems/score/freechain.h
 include_rtems_score_HEADERS += include/rtems/score/object.h
 include_rtems_score_HEADERS += include/rtems/score/objectimpl.h
+include_rtems_score_HEADERS += include/rtems/score/onceimpl.h
 include_rtems_score_HEADERS += include/rtems/score/percpu.h
 include_rtems_score_HEADERS += include/rtems/score/priority.h
 include_rtems_score_HEADERS += include/rtems/score/prioritybitmap.h
@@ -335,6 +336,7 @@ libscore_a_SOURCES += src/apiext.c src/chain.c src/chainappend.c \
     src/interr.c src/isr.c src/wkspace.c src/wkstringduplicate.c
 libscore_a_SOURCES += src/debugisownerofallocator.c
 libscore_a_SOURCES += src/profilingisrentryexit.c
+libscore_a_SOURCES += src/once.c
 EXTRA_DIST = src/Unlimited.txt
diff --git a/cpukit/score/include/rtems/score/onceimpl.h b/cpukit/score/include/rtems/score/onceimpl.h
new file mode 100644
index 0000000..ac4a394
--- /dev/null
+++ b/cpukit/score/include/rtems/score/onceimpl.h
@@ -0,0 +1,50 @@
+ * @file
+ * @ingroup ScoreOnce
+ * @brief Once API.
+ * Functions used by posix once as well as gxx_wrappers.
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_ONCE_H
+#define _RTEMS_ONCE_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup ScoreOnce Once Functions.
+ * @ingroup Score
+ * @brief Once functions.
+int _Once( int *once_state, void (*init_routine)(void) );
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_TLS_H */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index bb6508c..31853d5 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -5,14 +5,14 @@ $(srcdir)/preinstall.am: Makefile.am
 	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
 endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
 all-am: $(PREINSTALL_FILES)
 PREINSTALL_FILES =
 CLEANFILES = $(PREINSTALL_FILES)
+PREINSTALL_DIRS =
+DISTCLEANFILES += $(PREINSTALL_DIRS)
 $(PROJECT_INCLUDE)/rtems/$(dirstamp):
 	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
 	@: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
@@ -147,6 +147,10 @@ $(PROJECT_INCLUDE)/rtems/score/objectimpl.h: include/rtems/score/objectimpl.h $(
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/objectimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/objectimpl.h
+$(PROJECT_INCLUDE)/rtems/score/onceimpl.h: include/rtems/score/onceimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/onceimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/onceimpl.h
 $(PROJECT_INCLUDE)/rtems/score/percpu.h: include/rtems/score/percpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/percpu.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/percpu.h
diff --git a/cpukit/score/src/once.c b/cpukit/score/src/once.c
index 0000000..bfeca2a
--- /dev/null
+++ b/cpukit/score/src/once.c
@@ -0,0 +1,60 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <errno.h>
+#include <rtems/score/apimutex.h>
+#define ONCE_STATE_NOT_RUN  0
+#define ONCE_STATE_RUNNING  1
+#define ONCE_STATE_COMPLETE 2
+  int r = 0;
+  if ( *once_state != ONCE_STATE_COMPLETE ) {
+    _Once_Lock();
+     * Getting to here means the once_control is locked so we have:
+     *  1. The init has not run and the state is ONCE_STATE_NOT_RUN.
+     *  2. The init has finished and the state is ONCE_STATE_COMPLETE (already
+     *     caught by the previous if).
+     *  3. The init is being run by this thread and the state
+     *     ONCE_STATE_RUNNING so we are nesting. This is an error.
+    switch ( *once_state ) {
+      case ONCE_STATE_NOT_RUN:
+        *once_state = ONCE_STATE_RUNNING;
+        (*init_routine)();
+        *once_state = ONCE_STATE_COMPLETE;
+        break;
+      case ONCE_STATE_RUNNING:
+          r = EINVAL;
+        break;
+      default:
+        break;
+    _Once_Unlock();
+  return r;
1.8.4.5
