[PATCH 20/25] ods68302/include/bsp.h: Remove rtems_bsp_delay()
Thu Mar 20 18:29:16 UTC 2014
 c/src/lib/libbsp/m68k/ods68302/include/bsp.h |   20 +++-----------------
 1 files changed, 3 insertions(+), 17 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/ods68302/include/bsp.h b/c/src/lib/libbsp/m68k/ods68302/include/bsp.h
index f7c37e7..f7154c3 100644
--- a/c/src/lib/libbsp/m68k/ods68302/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/ods68302/include/bsp.h
@@ -1,7 +1,9 @@
 /*  bsp.h
  *  This include file contains all board IO definitions.
  *  COPYRIGHT (c) 1989-2010.
  *  On-Line Applications Research Corporation (OAR).
@@ -36,22 +38,6 @@ extern "C" {
 #undef HQUOTE
 #endif
- *  Simple spin delay in microsecond units for device drivers.
- *  This is very dependent on the clock speed of the target.
-#define rtems_bsp_delay( microseconds ) \
-  { register uint32_t         _delay=(microseconds); \
-    register uint32_t         _tmp=123; \
-    __asm__ volatile( "0: \
-                     nbcd      %0 ; \
-                     nbcd      %0 ; \
-                     dbf       %1,0b" \
-                  : "=d" (_tmp), "=d" (_delay) \
-                  : "0"  (_tmp), "1"  (_delay) ); \
 /* Constants */
 #define RAM_START RAM_BASE
1.7.1
