[PATCH 21/25] sim68000/include/bsp.h: Remove rtems_bsp_delay()
Thu Mar 20 18:29:17 UTC 2014
 c/src/lib/libbsp/m68k/sim68000/include/bsp.h |   17 -----------------
 1 files changed, 0 insertions(+), 17 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/sim68000/include/bsp.h b/c/src/lib/libbsp/m68k/sim68000/include/bsp.h
index f4e45a6..ec9130a 100644
--- a/c/src/lib/libbsp/m68k/sim68000/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/sim68000/include/bsp.h
@@ -30,23 +30,6 @@ extern "C" {
  *  Define some hardware constants here
- *  Simple spin delay in microsecond units for device drivers.
- *  This is very dependent on the clock speed of the target.
-#define rtems_bsp_delay( microseconds ) \
-  { register uint32_t         _delay=(microseconds); \
-    register uint32_t         _tmp = 0; /* initialized to avoid warning */ \
-    __asm__ volatile( "0: \
-                     remo      3,31,%0 ; \
-                     cmpo      0,%0 ; \
-                     subo      1,%1,%1 ; \
-                     cmpobne.t 0,%1,0b " \
-                  : "=d" (_tmp), "=d" (_delay) \
-                  : "0"  (_tmp), "1"  (_delay) ); \
 /* functions */
 rtems_isr_entry set_vector( rtems_isr_entry, rtems_vector_number, int );
1.7.1
