Philipp Eppelt
philipp.eppelt at mailbox.tu-dresden.de
Fri Mar 21 08:53:44 UTC 2014
Hi Youren,
git apply $attached_patch$
I have a meeting to attend to, so I don't have the time to test it right
now; will do it later. I hope it works.
Cheers,
Philipp
On 03/21/2014 09:30 AM, Philipp Eppelt wrote:
> Hi Youren,
> I just looked at a fresh RTEMS clone. I thought the patch eliminating
> sensitive instructions from the x86 paravirt target was merged, but it
> looks like it wasn't.
> I am working on an up to date patch. The old one, doesn't work anymore.
> Cheers,
> Philipp
> On 03/21/2014 03:27 AM, Youren Shen wrote:
>> Hi,Gedare:
>> Thank you for your suggestion.
>> In the function bootcart() in the file
>> c/src/lib/libbsp/shared/bootcard.c, there is a
>> function rtems_interrupt_disable which will be compiled to be
>> instruction "cli" in x86 platform. And the cli is also the reason why I
>> failed to startup POK partitions [1].
>> Now I consider there are two ways to solve the problem.One I called
>> functional solution, The other I called instruction solution. That is
>> say , we replace some functions with sensitive instructions or replace
>> every instructions. The first approach seems to be easy to
>> implementation, however maybe not easy to transplant to other platform.
>> I'm more familiar with the second approach, but to implement the whole
>> project will spent more time. And once we finish this project, we can
>> easily implement paravirtualization to other platform. And if design
>> properly, will also easily to transplant RTEMS to other hypervisor.
>> Or we have to mix this two solutions, This needs more discussion and
>> should be thoughtful and deliberate.
>> By the way, I'm going to post a blog about the POK initiation and
>> interrupt system this weekend.
>> [1].
>> http://listengine.tuxfamily.org/lists.tuxfamily.org/pok/2014/03/msg00003.html
>> Best Regards.
>> Youren Shen.
>> On Thu, Mar 20, 2014 at 10:04 PM, Gedare Bloom <gedare at rtems.org
>> <mailto:gedare at rtems.org>> wrote:
>> Youren Shen,
>> It looks like the problem you are having is that RTEMS "hello world"
>> executes a sensitive instruction? There should not be any such
>> instruction when you use the --enable-paravirt option, so you need to
>> determine where this instruction gets executed. The best way to do
>> this is to hook gdb up to an executing qemu. You can start qemu with
>> some -S option to prevent the boot sequence from starting to give you
>> some time to load gdb and connect it to qemu's gdbserver socket. once
>> you have done this, you should be able to set some breakpoints in the
>> pok/hello application to step through the program, or you might be
>> able to catch exceptions before they get raised to pok. The other
>> option should be that inside pok there should be some information
>> about the source of the exception that you might investigate.
>> Please keep us informed about your progress on this problem,
>> Thanks,
>> Gedare
>> On Thu, Mar 20, 2014 at 9:16 AM, Youren Shen <shenyouren at gmail.com
>> <mailto:shenyouren at gmail.com>> wrote:
>> > Hi,Gedare
>> > Maybe it's because my qemu version is low or POK has change the
>> kernel, I
>> > can't run the RTEMS Hello world on my computer anymore.
>> > The problem has spent me a few days to find. More details see this
>> mails.
>> > [1].
>> http://listengine.tuxfamily.org/lists.tuxfamily.org/pok/2014/03/msg00000.html
>> > Best Regards.
>> > Youren Shen.
>> > On Thu, Mar 20, 2014 at 8:03 PM, Philipp Eppelt
>> > <philipp.eppelt at mailbox.tu-dresden.de
>> <mailto:philipp.eppelt at mailbox.tu-dresden.de>> wrote:
>> >> On 03/16/2014 01:01 PM, Youren Shen wrote:
>> >> > Hi, every one:
>> >> > I have write a blog about how to build the RTEMS on POK.
>> However, the
>> >> > RTEMS can't run on POK now. Here is my blog[1].
>> >> > [1].
>> http://huaiyusched.github.io/rtems/2014/03/15/how-to-run-rtems-on-pok/
>> >> > Best Regards.
>> >> > Youren Shen.
>> >> Hi Youren,
>> >> great!
>> >> A screenshot of RTEMS HelloWorld sample running on POK would be even
>> >> better :).
>> >> Cheers,
>> >> Philipp
>> > Best Regards.
>> > Youren Shen.
>> Best Regards.
>> Youren Shen.
> rtems-devel mailing list
> rtems-devel at rtems.org
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140321/098adc90/attachment.bin>
