[PATCH] score: Delete _Watchdog_Report()
Sebastian Huber
Mon Mar 24 07:54:04 UTC 2014
Delete _Watchdog_Report_chain(). These two functions use printk() with
thread dispatching and interrupts disabled. So they are pretty useless
in real applications. They are not part of the application APIs. They
are only used in one test and do nothing useful in this test.
cpukit/score/Makefile.am | 2 +-
cpukit/score/include/rtems/score/watchdogimpl.h | 39 -----------------
cpukit/score/src/watchdogreport.c | 41 ------------------
cpukit/score/src/watchdogreportchain.c | 51 -----------------------
testsuites/sptests/spwatchdog/init.c | 8 +---
testsuites/sptests/spwatchdog/spwatchdog.doc | 4 --
testsuites/sptests/spwatchdog/spwatchdog.scn | 15 -------
testsuites/sptests/spwatchdog/task1.c | 12 -----
8 files changed, 2 insertions(+), 170 deletions(-)
delete mode 100644 cpukit/score/src/watchdogreport.c
delete mode 100644 cpukit/score/src/watchdogreportchain.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 77c0c89..e2d23a4 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -321,7 +321,7 @@ libscore_a_SOURCES += src/coretod.c src/coretodset.c src/coretodget.c \
## WATCHDOG_C_FILES
libscore_a_SOURCES += src/watchdog.c src/watchdogadjust.c \
src/watchdogadjusttochain.c src/watchdoginsert.c src/watchdogremove.c \
- src/watchdogtickle.c src/watchdogreport.c src/watchdogreportchain.c
+ src/watchdogtickle.c
## USEREXT_C_FILES
libscore_a_SOURCES += src/userextaddset.c \
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index 2709805..72b6b3b 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -197,45 +197,6 @@ void _Watchdog_Tickle (
- * @brief Report information on a single watchdog instance.
- * This method prints a one line report on the watchdog instance
- * provided. The @a name may be used to identify the watchdog and
- * a space will be printed after @a name if it is not NULL.
- * @param[in] name is a string to prefix the line with. If NULL,
- * nothing is printed.
- * @param[in] watch is the watchdog instance to be printed.
- * @note This is a debug routine. It uses printk() and prudence should
- * exercised when using it.
-void _Watchdog_Report(
- const char *name,
- Watchdog_Control *watch
- * @brief Report information on a watchdog chain.
- * This method prints report on the watchdog chain provided.
- * The @a name may be used to identify the watchdog chain and
- * @param[in] header is the watchdog chain to be printed.
- * exercised when using it. It also disables interrupts so the
- * chain can be traversed in a single atomic pass.
-void _Watchdog_Report_chain(
- const char *name,
- Chain_Control *header
* This routine initializes the specified watchdog. The watchdog is
* made inactive, the watchdog id and handler routine are set to the
* specified values.
diff --git a/cpukit/score/src/watchdogreport.c b/cpukit/score/src/watchdogreport.c
deleted file mode 100644
index 550be49..0000000
--- a/cpukit/score/src/watchdogreport.c
+++ /dev/null
@@ -1,41 +0,0 @@
- * @file watchdogreport.c
- * @brief Report Information on a Single Watchdog Instance
- * @ingroup ScoreWatchdog
- * COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/watchdogimpl.h>
-#include <rtems/bspIo.h>
- const char *name,
- printk(
- "%s%s%4d %5d %p %p 0x%08x %p\n",
- ((name) ? name : ""),
- ((name) ? " " : ""),
- watch->delta_interval,
- watch->initial,
- watch,
- watch->routine,
- watch->id,
- watch->user_data
diff --git a/cpukit/score/src/watchdogreportchain.c b/cpukit/score/src/watchdogreportchain.c
index edbc781..0000000
--- a/cpukit/score/src/watchdogreportchain.c
+++ /dev/null
@@ -1,51 +0,0 @@
- * @file
- * @brief Report Information on a Watchdog Chain
-/* COPYRIGHT (c) 1989-2008.
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/isr.h>
-#include <rtems/score/threaddispatch.h>
- const char *name,
- ISR_Level level;
- Chain_Node *node;
- _Thread_Disable_dispatch();
- _ISR_Disable( level );
- printk( "Watchdog Chain: %s %p\n", name, header );
- if ( !_Chain_Is_empty( header ) ) {
- for ( node = _Chain_First( header ) ;
- node != _Chain_Tail(header) ;
- node = node->next )
- Watchdog_Control *watch = (Watchdog_Control *) node;
- _Watchdog_Report( NULL, watch );
- printk( "== end of %s \n", name );
- } else {
- printk( "Chain is empty\n" );
- _ISR_Enable( level );
- _Thread_Enable_dispatch();
diff --git a/testsuites/sptests/spwatchdog/init.c b/testsuites/sptests/spwatchdog/init.c
index 2e952b6..3caa612 100644
--- a/testsuites/sptests/spwatchdog/init.c
+++ b/testsuites/sptests/spwatchdog/init.c
@@ -51,17 +51,11 @@ rtems_task Init(
rtems_time_of_day time;
rtems_status_code status;
- Chain_Control empty;
- puts( "\n*** RTEMS WATCHDOG ***" );
- puts( "INIT - report on empty watchdog chain" );
+ puts( "\n*** RTEMS WATCHDOG ***" );
test_watchdog_static_init();
- _Chain_Initialize_empty( &empty );
- _Watchdog_Report_chain( "Empty Chain", &empty );
build_time( &time, 12, 31, 1988, 9, 0, 0, 0 );
status = rtems_clock_set( &time );
diff --git a/testsuites/sptests/spwatchdog/spwatchdog.doc b/testsuites/sptests/spwatchdog/spwatchdog.doc
index b5dd6cf..b8080b2 100644
--- a/testsuites/sptests/spwatchdog/spwatchdog.doc
+++ b/testsuites/sptests/spwatchdog/spwatchdog.doc
@@ -12,12 +12,8 @@ test set name: spwatchdog
directives:
- SCORE _Watchdog_Report
- SCORE _Watchdog_Report_chain
various timer, delay, and clock services
concepts:
+ Ensure that the SCORE Watchdog routines operate properly.
-+ Ensure that the SCORE Watchdog reporting routines operate properly.
diff --git a/testsuites/sptests/spwatchdog/spwatchdog.scn b/testsuites/sptests/spwatchdog/spwatchdog.scn
index 622e99e..15f85b5 100644
--- a/testsuites/sptests/spwatchdog/spwatchdog.scn
+++ b/testsuites/sptests/spwatchdog/spwatchdog.scn
@@ -1,7 +1,4 @@
-INIT - report on empty watchdog chain
-Watchdog Chain: Empty Chain 203753
-Chain is empt
INIT - rtems_timer_create - creating timer 1
INIT - timer 1 has id (0x12010001)
TA1 - rtems_timer_ident - identing timer 1
@@ -14,17 +11,5 @@ TA1 - rtems_timer_fire_after - timer 1 in 3 seconds
TA1 - rtems_task_wake_after - 1 second
TA1 - rtems_clock_get_tod - 09:00:04 12/31/1988
TA1 - rtems_timer_reset - timer 1
-TA1 - _Watchdog_Report_chain - with name
-Watchdog Chain: _Watchdog_Ticks_chain 2030F1
- 300 300 2033B40 201391C 0x12010001
-== end of _Watchdog_Ticks_chain
-TA1 - _Watchdog_Report_chain - no name
-Watchdog Chain: 2030F1
-== end of
-TA1 - _Watchdog_Report - with name
-first 300 300 2033B40 201391C 0x12010001
-TA1 - _Watchdog_Report - no name
- 299 300 2033B40 201391C 0x12010001
TA1 - timer_deleting - timer 1
*** END OF RTEMS WATCHDOG PROGRAM ***
diff --git a/testsuites/sptests/spwatchdog/task1.c b/testsuites/sptests/spwatchdog/task1.c
index 708cc7b..59a261b 100644
--- a/testsuites/sptests/spwatchdog/task1.c
+++ b/testsuites/sptests/spwatchdog/task1.c
@@ -77,18 +77,6 @@ rtems_task Task_1(
status = rtems_timer_reset( tmid );
directive_failed( status, "rtems_timer_reset" );
- puts( "TA1 - _Watchdog_Report_chain - with name" );
- _Watchdog_Report_chain( "_Watchdog_Ticks_chain", & _Watchdog_Ticks_chain );
- puts( "TA1 - _Watchdog_Report_chain - no name" );
- _Watchdog_Report_chain( NULL, & _Watchdog_Ticks_chain);
- puts( "TA1 - _Watchdog_Report - with name" );
- _Watchdog_Report("first", (Watchdog_Control *)_Chain_First(&_Watchdog_Ticks_chain));
- puts( "TA1 - _Watchdog_Report - no name" );
- _Watchdog_Report( NULL, (Watchdog_Control *)_Chain_First(&_Watchdog_Ticks_chain) );
puts( "TA1 - timer_deleting - timer 1" );
status = rtems_timer_delete( tmid );
directive_failed( status, "rtems_timer_delete" );
1.7.7
