[PATCH] This patch contains the changes required to get the mrm332 bsp working again.
James Fitzsimons
james.fitzsimons at gmail.com
Mon Mar 24 09:32:10 UTC 2014
Changed console driver to use interrupts instead of polling.
Change to avoid overwriting CPU32Bug interrupt vector when setting up the Sci interrupt handler.
Fixed type for boolean flag in bsp.h.
Changed mrm332.h to use 25Mhz clock.
Fixes to mrm332.cfg to use correct mcpu32 value for RTEMS_CPU_MODEL instead of m68332 which is no longer supported.
Added -mcpu=cpu32 to compiler options.
Removed broken ROM linker script and replaced broken RAM linker script with working ROM linker script.
Removed no longer required file except_vect_332_ROM.S.
Enabled 0xbeefbeef magic string in start.S to allow MRM version of CPU32Bug to auto run RTEMS.
Removed old code from start.S
Changed compiler optimization flag to optimize for size.
c/src/lib/libbsp/m68k/mrm332/Makefile.am | 5 +-
c/src/lib/libbsp/m68k/mrm332/console/console.c | 2 +-
c/src/lib/libbsp/m68k/mrm332/console/sci.c | 19 +-
c/src/lib/libbsp/m68k/mrm332/include/bsp.h | 2 +-
c/src/lib/libbsp/m68k/mrm332/include/mrm332.h | 7 +-
.../lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg | 34 +--
c/src/lib/libbsp/m68k/mrm332/preinstall.am | 3 -
c/src/lib/libbsp/m68k/mrm332/start/start.S | 125 ++-------
.../m68k/mrm332/startup/except_vect_332_ROM.S | 289 --------------------
c/src/lib/libbsp/m68k/mrm332/startup/linkcmds | 302 +++++++++++----------
c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM | 212 ---------------
c/src/lib/libbsp/m68k/mrm332/startup/start_c.c | 185 ++++++-------
12 files changed, 296 insertions(+), 889 deletions(-)
delete mode 100644 c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S
delete mode 100644 c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM
diff --git a/c/src/lib/libbsp/m68k/mrm332/Makefile.am b/c/src/lib/libbsp/m68k/mrm332/Makefile.am
index 29b9b4a..9de7cee 100644
--- a/c/src/lib/libbsp/m68k/mrm332/Makefile.am
+++ b/c/src/lib/libbsp/m68k/mrm332/Makefile.am
@@ -22,7 +22,7 @@ noinst_LIBRARIES = libbspstart.a
libbspstart_a_SOURCES = start/start.S
project_lib_DATA = start.$(OBJEXT)
-dist_project_lib_DATA += startup/linkcmds startup/linkcmds_ROM
+dist_project_lib_DATA += startup/linkcmds
noinst_LIBRARIES += libbsp.a
libbsp_a_SOURCES =
@@ -33,8 +33,7 @@ libbsp_a_SOURCES += startup/start_c.c ../../shared/bsplibc.c \
../../shared/bootcard.c ../../shared/sbrk.c \
../../shared/bspclean.c \
../../shared/setvec.c ../../shared/bsppretaskinghook.c \
- ../../shared/bspgetworkarea.c ../../shared/gnatinstallhandler.c \
- startup/except_vect_332_ROM.S
+ ../../shared/bspgetworkarea.c ../../shared/gnatinstallhandler.c
# clock
libbsp_a_SOURCES += clock/ckinit.c
# console
diff --git a/c/src/lib/libbsp/m68k/mrm332/console/console.c b/c/src/lib/libbsp/m68k/mrm332/console/console.c
index ce1547e..94fb803 100644
--- a/c/src/lib/libbsp/m68k/mrm332/console/console.c
+++ b/c/src/lib/libbsp/m68k/mrm332/console/console.c
@@ -42,7 +42,7 @@ rtems_device_driver console_open(
/* SCI internal uart */
- status = rtems_termios_open( major, minor, arg, SciGetTermiosHandlers( TRUE ) );
+ status = rtems_termios_open( major, minor, arg, SciGetTermiosHandlers( FALSE ) );
return status;
diff --git a/c/src/lib/libbsp/m68k/mrm332/console/sci.c b/c/src/lib/libbsp/m68k/mrm332/console/sci.c
index 4b67c33..a671fb0 100644
--- a/c/src/lib/libbsp/m68k/mrm332/console/sci.c
+++ b/c/src/lib/libbsp/m68k/mrm332/console/sci.c
@@ -351,8 +351,8 @@ rtems_isr SciIsr( rtems_vector_number vector )
if ( (*SCSR) & SCI_ERROR_OVERRUN ) SciErrorsOverrun ++;
/* see if it was a transmit interrupt */
- if ( (*SCSR) & SCI_XMTR_AVAILABLE ) /* data reg empty, xmt complete */
+ /* data reg empty, xmt complete */
+ if ( ( *SCCR1 & SCI_ENABLE_INT_TX ) && ( (*SCSR) & SCI_XMTR_AVAILABLE ) )
SciDisableTransmitInterrupts();
@@ -554,12 +554,17 @@ int SciInterruptOpen(
SciSetDataBits(SCI_8_DATA_BITS); /* set data bits to 8 */
- /* Install our interrupt handler into RTEMS, where does 66 come from? */
+ /* Install our interrupt handler into RTEMS. */
+ /* 68 is an unused user-defined vector. Note that the vector must be */
+ /* even - it sets the low bit for SPI interrupts, and clears it for */
+ /* SCI interrupts. Also note that vector 66 is used by CPU32bug on */
+ /* the mrm332. */
- rtems_interrupt_catch( SciIsr, 66, &old_vector );
+ rtems_interrupt_catch( SciIsr, 68, &old_vector );
- *QIVR = 66;
- *QIVR &= 0xf8;
+ *QSMCR = (*QSMCR & ~IARB) | 1; // Is 1 a good value for qsm iarb?
+ *QIVR = 68;
+ *QILR &= 0xf8;
*QILR |= 0x06 & 0x07;
SciEnableTransmitter(); /* enable the transmitter */
@@ -1382,7 +1387,7 @@ void SciWriteCharWait(uint8_t c)
/* poll the fifo, waiting for room for another character */
- while ( ( *SCSR & SCI_XMTR_AVAILABLE ) == 0 )
+ while ( ( *SCSR & SCI_XMTR_AVAILABLE ) != SCI_XMTR_AVAILABLE )
/* Either we are writing to the fifo faster than
* the uart can clock bytes out onto the cable,
diff --git a/c/src/lib/libbsp/m68k/mrm332/include/bsp.h b/c/src/lib/libbsp/m68k/mrm332/include/bsp.h
index 456b315..8f2c7cf 100644
--- a/c/src/lib/libbsp/m68k/mrm332/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/mrm332/include/bsp.h
@@ -42,7 +42,7 @@ extern char _copy_start[];
extern char _edata[];
extern char _clear_start[];
extern char end[];
-extern char _copy_data_from_rom[];
+extern bool _copy_data_from_rom;
/* constants */
diff --git a/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h b/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h
index 58e5b20..1b86727 100644
--- a/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h
+++ b/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h
@@ -27,6 +27,8 @@
/* System Clock definitions */
#define XTAL 32768.0 /* crystal frequency in Hz */
+/* Specify the CPU frequency. Do not specify a faster clock than your */
+/* CPU is rated for! */
#if 0
/* Default MRM clock rate (8.388688 MHz) set by CPU32: */
#define MRM_W 0 /* system clock parameters */
@@ -34,18 +36,19 @@
#define MRM_Y 0x3f
#endif
-#if 1
+#if 0
/* 16.77722 MHz: */
#define MRM_W 1 /* system clock parameters */
#define MRM_X 1
#define MRM_Y 0x0f
#endif
-#if 0
+#if 1
/* 25.16582 MHz: */
#define MRM_X 1
#define MRM_Y 0x17
+#define SET_EDIV
#endif
#define SYS_CLOCK (XTAL*4.0*(MRM_Y+1)*(1 << (2*MRM_W+MRM_X)))
diff --git a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
index bf55e4f..de07e73 100644
--- a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
+++ b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
@@ -5,41 +5,15 @@
include $(RTEMS_ROOT)/make/custom/default.cfg
RTEMS_CPU=m68k
-RTEMS_CPU_MODEL=m68332
+RTEMS_CPU_MODEL=mcpu32
# This contains the compiler options necessary to select the CPU model
# and (hopefully) optimize for it.
CPU_CFLAGS = -mcpu=cpu32
-# optimize flag: typically -O2
-CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
+# using optimise for size due to small memory on target board.
+CFLAGS_OPTIMIZE_V = -Os -g -fomit-frame-pointer
-ifeq ($(MRM_IN_ROM),yes)
-# Build a rommable image - move the .data section after the .text section
-# in the image.
-CPU_CFLAGS += -qnolinkcmds -T $(exec_prefix)/mrm332/lib/linkcmds_ROM
-endif
-define bsp-post-link
- $(OBJCOPY) --adjust-section-vma \
- .data=`m68k-rtems-objdump --section-headers $(basename $@).pxe | \
- awk 'function h2d(x) { x=toupper(x); digits=length(x); s=0 ; \
- for (p=digits; p>0; p--) \
- s += (16^(p-1)) * ( index("0123456789ABCDEF",\
- substr(x,1+digits-p,1)) -1 );\
- return s } ;\
- /\.text/ { base = $$4 ; size = $$3 };\
- END { printf("0x%x", h2d(base) + h2d(size)) }'\
- ` $(basename $@).pxe $(basename $@)$(EXEEXT)
- $(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@).srec
- sed -e 's/.$$//' -e '/^S0/d' $(basename $@).srec | \
- $(PACKHEX) > $(basename $@)$(DOWNEXT)
- $(NM) -g -n $(basename $@).pxe > $(basename $@).pnum
- rm -f $(basename $@).srec $(basename $@).srec
- $(default-bsp-post-link)
-endef
-else
@@ -47,4 +21,4 @@ define bsp-post-link
endef
-endif
diff --git a/c/src/lib/libbsp/m68k/mrm332/preinstall.am b/c/src/lib/libbsp/m68k/mrm332/preinstall.am
index 4a71e7d..19e184f 100644
--- a/c/src/lib/libbsp/m68k/mrm332/preinstall.am
+++ b/c/src/lib/libbsp/m68k/mrm332/preinstall.am
@@ -69,7 +69,4 @@ $(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
-$(PROJECT_LIB)/linkcmds_ROM: startup/linkcmds_ROM $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds_ROM
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds_ROM
diff --git a/c/src/lib/libbsp/m68k/mrm332/start/start.S b/c/src/lib/libbsp/m68k/mrm332/start/start.S
index e8f7514..5e2bbeb 100644
--- a/c/src/lib/libbsp/m68k/mrm332/start/start.S
+++ b/c/src/lib/libbsp/m68k/mrm332/start/start.S
@@ -22,7 +22,7 @@ BEGIN_CODE
/* Put the header necessary for the modified CPU32bug to automatically
start up rtems: */
-#if 0
+#if 1
.long 0xbeefbeef ;
#endif
.long 0 ;
@@ -31,11 +31,16 @@ BEGIN_CODE
.global start
start:
- oriw #0x0700,sr
- movel #end, d0
- addl #_StackSize,d0
+ oriw #0x0700,sr /* Mask off interupts */
+ // Set VBR to CPU32Bug vector table address
+ movel #0x0,d0 /* Use the initial vectors until we get going */
+ movecl d0,vbr
+ movel #end, d0 /* Next 3 instructions set stack pointer */
+ addl #_StackSize,d0 /* sp = end + _StackSize from linker script */
movel d0,sp
- movel d0,a6
+ movel d0,a6
/* include in ram_init.S */
@@ -46,6 +51,13 @@ BEGIN_CODE
/* Module Configuration Register */
/* see section(s) 3.1.3-3.1.6 of the SIM Reference Manual */
+ /* SIMCR etc and SAM macro all defined in sim.h found at */
+ /* /cpukit/score/cpu/m68k/rtems/m68k/sim.h */
+ /* The code below does the following: */
+ /* - Sets Freeze Software Enable */
+ /* - Turns off Show Cycle Enable */
+ /* - Sets the location of SIM module mapping */
+ /* - Sets the SIM Interrupt Arbitration Field */
lea SIMCR, a0
movew #FRZSW,d0
oriw #SAM(0,8,SHEN),d0
@@ -57,106 +69,3 @@ BEGIN_CODE
END_CODE
-#if 0
- /* Synthesizer Control Register */
- /* see section(s) 4.8 */
- /* end include in ram_init.S */
- *SYNCR = (unsigned short int)
- ( SAM(MRM_W,15,VCO) | SAM(0x0,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
- while (! (*SYNCR & SLOCK)); /* protect from clock overshoot */
- /* include in ram_init.S */
- ( SAM(MRM_W,15,VCO) | SAM(MRM_X,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
- /* System Protection Control Register */
- /* !!! can only write to once after reset !!! */
- /* see section 3.8.4 of the SIM Reference Manual */
- *SYPCR = (unsigned char)( HME | BME );
- /* Periodic Interrupr Control Register */
- /* see section 3.8.2 of the SIM Reference Manual */
- *PICR = (unsigned short int)
- ( SAM(0,8,PIRQL) | SAM(MRM_PIV,0,PIV) );
- /* ^^^ zero disables interrupt, don't enable here or ram_init will
- be wrong. It's enabled below. */
- /* Periodic Interrupt Timer Register */
- /* see section 3.8.3 of the SIM Reference Manual */
- *PITR = (unsigned short int)( SAM(0x09,0,PITM) );
- /* 1.098mS interrupt, assuming 32.768 KHz input clock */
- /* Port C Data */
- /* load values before enabled */
- *PORTC = (unsigned char) 0x0;
- /* Port E and F Data Register */
- /* see section 9 of the SIM Reference Manual */
- *PORTE0 = (unsigned char) 0;
- *PORTF0 = (unsigned char) 0;
- /* Port E and F Data Direction Register */
- *DDRE = (unsigned char) 0xff;
- *DDRF = (unsigned char) 0xfd;
- /* Port E and F Pin Assignment Register */
- *PEPAR = (unsigned char) 0;
- *PFPAR = (unsigned char) 0;
- /* end of SIM initalization code */
- * Initialize RAM by copying the .data section out of ROM (if
- * needed) and "zero-ing" the .bss section.
- register char *src = _etext;
- register char *dst = _copy_start;
- if (_copy_data_from_rom)
- /* ROM has data at end of text; copy it. */
- while (dst < _edata)
- *dst++ = *src++;
- /* Zero bss */
- for (dst = _clear_start; dst< end; dst++)
- *dst = 0;
- * Initialize vector table.
- rtems_isr_entry *monitors_vector_table;
- m68k_get_vbr(monitors_vector_table);
- M68Kvec[ 4 ] = monitors_vector_table[ 4 ]; /* breakpoints vector */
- M68Kvec[ 9 ] = monitors_vector_table[ 9 ]; /* trace vector */
- M68Kvec[ 31 ] = monitors_vector_table[ 31 ]; /* level 7 interrupt */
- M68Kvec[ 47 ] = monitors_vector_table[ 47 ]; /* system call vector */
- M68Kvec[ 66 ] = monitors_vector_table[ 66 ]; /* user defined */
- m68k_set_vbr(&M68Kvec);
- * Initalize the board.
- Spurious_Initialize();
- console_init();
- * Execute main with arguments argc and agrv.
- boot_card((void*)0);
- reboot();
-#endif
diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S b/c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S
deleted file mode 100644
index 6a2e679..0000000
--- a/c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S
+++ /dev/null
@@ -1,289 +0,0 @@
-/* Exception Vector definitions follow */
- /* !!! Warning !!! This table is not tested, and
- the user must make sure it is complete. */
- /* If we use TRAP #15 for reboot, note that group 0 and 1 exceptions
- will have priority. */
- /* This is the "magic word" that CPU32bug uses to indicate that
- there is a bootable image here. */
- .long 0xBEEFBEEF
- /* Vector 0: RESET: Initial SSP */
- .long _RamEnd
- /* Vector 1: RESET: Initial PC */
- .long start
- /* default action for undefined vectors is to re-boot */
- /* Note group 0 and 1 exception (like trace) have priority
- over other exceptions (like trap #15) that may call this. */
- /* Vectors 2-255 */
- .long reboot /* exception vector: 2 */
- .long reboot /* exception vector: 3 */
- .long reboot /* exception vector: 4 */
- .long reboot /* exception vector: 5 */
- .long reboot /* exception vector: 6 */
- .long reboot /* exception vector: 7 */
- .long reboot /* exception vector: 8 */
- .long reboot /* exception vector: 9 */
- .long reboot /* exception vector: 10 */
- .long reboot /* exception vector: 11 */
- .long reboot /* exception vector: 12 */
- .long reboot /* exception vector: 13 */
- .long reboot /* exception vector: 14 */
- .long reboot /* exception vector: 15 */
- .long reboot /* exception vector: 16 */
- .long reboot /* exception vector: 17 */
- .long reboot /* exception vector: 18 */
- .long reboot /* exception vector: 19 */
- .long reboot /* exception vector: 20 */
- .long reboot /* exception vector: 21 */
- .long reboot /* exception vector: 22 */
- .long reboot /* exception vector: 23 */
- .long reboot /* exception vector: 24 */
- .long reboot /* exception vector: 25 */
- .long reboot /* exception vector: 26 */
- .long reboot /* exception vector: 27 */
- .long reboot /* exception vector: 28 */
- .long reboot /* exception vector: 29 */
- .long reboot /* exception vector: 30 */
- .long reboot /* exception vector: 31 */
- .long reboot /* exception vector: 32 */
- .long reboot /* exception vector: 33 */
- .long reboot /* exception vector: 34 */
- .long reboot /* exception vector: 35 */
- .long reboot /* exception vector: 36 */
- .long reboot /* exception vector: 37 */
- .long reboot /* exception vector: 38 */
- .long reboot /* exception vector: 39 */
- .long reboot /* exception vector: 40 */
- .long reboot /* exception vector: 41 */
- .long reboot /* exception vector: 42 */
- .long reboot /* exception vector: 43 */
- .long reboot /* exception vector: 44 */
- .long reboot /* exception vector: 45 */
- .long reboot /* exception vector: 46 */
- .long _reboot /* the reboot trap: 47 */
- .long reboot /* exception vector: 48 */
- .long reboot /* exception vector: 49 */
- .long reboot /* exception vector: 50 */
- .long reboot /* exception vector: 51 */
- .long reboot /* exception vector: 52 */
- .long reboot /* exception vector: 53 */
- .long reboot /* exception vector: 54 */
- .long reboot /* exception vector: 55 */
- .long reboot /* exception vector: 56 */
- .long reboot /* exception vector: 57 */
- .long reboot /* exception vector: 58 */
- .long reboot /* exception vector: 59 */
- .long reboot /* exception vector: 60 */
- .long reboot /* exception vector: 61 */
- .long reboot /* exception vector: 62 */
- .long reboot /* exception vector: 63 */
- .long reboot /* exception vector: 64 */
- .long reboot /* exception vector: 65 */
- .long reboot /* exception vector: 66 */
- .long reboot /* exception vector: 67 */
- .long reboot /* exception vector: 68 */
- .long reboot /* exception vector: 69 */
- .long reboot /* exception vector: 70 */
- .long reboot /* exception vector: 71 */
- .long reboot /* exception vector: 72 */
- .long reboot /* exception vector: 73 */
- .long reboot /* exception vector: 74 */
- .long reboot /* exception vector: 75 */
- .long reboot /* exception vector: 76 */
- .long reboot /* exception vector: 77 */
- .long reboot /* exception vector: 78 */
- .long reboot /* exception vector: 79 */
- .long reboot /* exception vector: 80 */
- .long reboot /* exception vector: 81 */
- .long reboot /* exception vector: 82 */
- .long reboot /* exception vector: 83 */
- .long reboot /* exception vector: 84 */
- .long reboot /* exception vector: 85 */
- .long reboot /* exception vector: 86 */
- .long reboot /* exception vector: 87 */
- .long reboot /* exception vector: 88 */
- .long reboot /* exception vector: 89 */
- .long reboot /* exception vector: 90 */
- .long reboot /* exception vector: 91 */
- .long reboot /* exception vector: 92 */
- .long reboot /* exception vector: 93 */
- .long reboot /* exception vector: 94 */
- .long reboot /* exception vector: 95 */
- .long reboot /* exception vector: 96 */
- .long reboot /* exception vector: 97 */
- .long reboot /* exception vector: 98 */
- .long reboot /* exception vector: 99 */
- .long reboot /* exception vector: 100 */
- .long reboot /* exception vector: 101 */
- .long reboot /* exception vector: 102 */
- .long reboot /* exception vector: 103 */
- .long reboot /* exception vector: 104 */
- .long reboot /* exception vector: 105 */
- .long reboot /* exception vector: 106 */
- .long reboot /* exception vector: 107 */
- .long reboot /* exception vector: 108 */
- .long reboot /* exception vector: 109 */
- .long reboot /* exception vector: 110 */
- .long reboot /* exception vector: 111 */
- .long reboot /* exception vector: 112 */
- .long reboot /* exception vector: 113 */
- .long reboot /* exception vector: 114 */
- .long reboot /* exception vector: 115 */
- .long reboot /* exception vector: 116 */
- .long reboot /* exception vector: 117 */
- .long reboot /* exception vector: 118 */
- .long reboot /* exception vector: 119 */
- .long reboot /* exception vector: 120 */
- .long reboot /* exception vector: 121 */
- .long reboot /* exception vector: 122 */
- .long reboot /* exception vector: 123 */
- .long reboot /* exception vector: 124 */
- .long reboot /* exception vector: 125 */
- .long reboot /* exception vector: 126 */
- .long reboot /* exception vector: 127 */
- .long reboot /* exception vector: 128 */
- .long reboot /* exception vector: 129 */
- .long reboot /* exception vector: 130 */
- .long reboot /* exception vector: 131 */
- .long reboot /* exception vector: 132 */
- .long reboot /* exception vector: 133 */
- .long reboot /* exception vector: 134 */
- .long reboot /* exception vector: 135 */
- .long reboot /* exception vector: 136 */
- .long reboot /* exception vector: 137 */
- .long reboot /* exception vector: 138 */
- .long reboot /* exception vector: 139 */
- .long reboot /* exception vector: 140 */
- .long reboot /* exception vector: 141 */
- .long reboot /* exception vector: 142 */
- .long reboot /* exception vector: 143 */
- .long reboot /* exception vector: 144 */
- .long reboot /* exception vector: 145 */
- .long reboot /* exception vector: 146 */
- .long reboot /* exception vector: 147 */
- .long reboot /* exception vector: 148 */
- .long reboot /* exception vector: 149 */
- .long reboot /* exception vector: 150 */
- .long reboot /* exception vector: 151 */
- .long reboot /* exception vector: 152 */
- .long reboot /* exception vector: 153 */
- .long reboot /* exception vector: 154 */
- .long reboot /* exception vector: 155 */
- .long reboot /* exception vector: 156 */
- .long reboot /* exception vector: 157 */
- .long reboot /* exception vector: 158 */
- .long reboot /* exception vector: 159 */
- .long reboot /* exception vector: 160 */
- .long reboot /* exception vector: 161 */
- .long reboot /* exception vector: 162 */
- .long reboot /* exception vector: 163 */
- .long reboot /* exception vector: 164 */
- .long reboot /* exception vector: 165 */
- .long reboot /* exception vector: 166 */
- .long reboot /* exception vector: 167 */
- .long reboot /* exception vector: 168 */
- .long reboot /* exception vector: 169 */
- .long reboot /* exception vector: 170 */
- .long reboot /* exception vector: 171 */
- .long reboot /* exception vector: 172 */
- .long reboot /* exception vector: 173 */
- .long reboot /* exception vector: 174 */
- .long reboot /* exception vector: 175 */
- .long reboot /* exception vector: 176 */
- .long reboot /* exception vector: 177 */
- .long reboot /* exception vector: 178 */
- .long reboot /* exception vector: 179 */
- .long reboot /* exception vector: 180 */
- .long reboot /* exception vector: 181 */
- .long reboot /* exception vector: 182 */
- .long reboot /* exception vector: 183 */
- .long reboot /* exception vector: 184 */
- .long reboot /* exception vector: 185 */
- .long reboot /* exception vector: 186 */
- .long reboot /* exception vector: 187 */
- .long reboot /* exception vector: 188 */
- .long reboot /* exception vector: 189 */
- .long reboot /* exception vector: 190 */
- .long reboot /* exception vector: 191 */
- .long reboot /* exception vector: 192 */
- .long reboot /* exception vector: 193 */
- .long reboot /* exception vector: 194 */
- .long reboot /* exception vector: 195 */
- .long reboot /* exception vector: 196 */
- .long reboot /* exception vector: 197 */
- .long reboot /* exception vector: 198 */
- .long reboot /* exception vector: 199 */
- .long reboot /* exception vector: 200 */
- .long reboot /* exception vector: 201 */
- .long reboot /* exception vector: 202 */
- .long reboot /* exception vector: 203 */
- .long reboot /* exception vector: 204 */
- .long reboot /* exception vector: 205 */
- .long reboot /* exception vector: 206 */
- .long reboot /* exception vector: 207 */
- .long reboot /* exception vector: 208 */
- .long reboot /* exception vector: 209 */
- .long reboot /* exception vector: 210 */
- .long reboot /* exception vector: 211 */
- .long reboot /* exception vector: 212 */
- .long reboot /* exception vector: 213 */
- .long reboot /* exception vector: 214 */
- .long reboot /* exception vector: 215 */
- .long reboot /* exception vector: 216 */
- .long reboot /* exception vector: 217 */
- .long reboot /* exception vector: 218 */
- .long reboot /* exception vector: 219 */
- .long reboot /* exception vector: 220 */
- .long reboot /* exception vector: 221 */
- .long reboot /* exception vector: 222 */
- .long reboot /* exception vector: 223 */
- .long reboot /* exception vector: 224 */
- .long reboot /* exception vector: 225 */
- .long reboot /* exception vector: 226 */
- .long reboot /* exception vector: 227 */
- .long reboot /* exception vector: 228 */
- .long reboot /* exception vector: 229 */
- .long reboot /* exception vector: 230 */
- .long reboot /* exception vector: 231 */
- .long reboot /* exception vector: 232 */
- .long reboot /* exception vector: 233 */
- .long reboot /* exception vector: 234 */
- .long reboot /* exception vector: 235 */
- .long reboot /* exception vector: 236 */
- .long reboot /* exception vector: 237 */
- .long reboot /* exception vector: 238 */
- .long reboot /* exception vector: 239 */
- .long reboot /* exception vector: 240 */
- .long reboot /* exception vector: 241 */
- .long reboot /* exception vector: 242 */
- .long reboot /* exception vector: 243 */
- .long reboot /* exception vector: 244 */
- .long reboot /* exception vector: 245 */
- .long reboot /* exception vector: 246 */
- .long reboot /* exception vector: 247 */
- .long reboot /* exception vector: 248 */
- .long reboot /* exception vector: 249 */
- .long reboot /* exception vector: 250 */
- .long reboot /* exception vector: 251 */
- .long reboot /* exception vector: 252 */
- .long reboot /* exception vector: 253 */
- .long reboot /* exception vector: 254 */
- .long reboot /* exception vector: 255 */
-_reboot:
- move #0x2700,%sr /* mask interrupts */
- movea.l (0x0).w,%a7 /* load stack */
- movea.l (0x4).w,%a0 /* jmp to location of reset vector */
- jmp (%a0)
-reboot:
- trap #15 /* use trap exception to enter supervisor
- state. Trace mode ( and other group 0
- and 1 exceptions) *could* screw this up if
- not vectored to reboot or did not return. */
diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds b/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds
index 651fc9f..378559c 100644
--- a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds
+++ b/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds
@@ -5,20 +5,26 @@ OUTPUT_ARCH(m68k)
__DYNAMIC = 0;
- * The memory map looks like this:
+ * ROM:
* +--------------------+ <- low memory
* | .text |
* | etext |
* | ctor list | the ctor and dtor lists are for
* | dtor list | C++ support
* | _endtext |
+ * | temporary .data | .data is moved to RAM by crt0
+ * +--------------------+ <- high memory
+ * RAM:
+ * +--------------------+ <- low memory
* | .data | initialized data goes here
* | _sdata |
* | _edata |
* | .bss |
- * | _clear_start| start of bss, cleared by crt0
+ * | __bss_start | start of bss, cleared by crt0
* | _end | start of heap, used by sbrk()
* | heap space |
@@ -31,150 +37,170 @@ __DYNAMIC = 0;
* Declare some sizes.
-RamBase = DEFINED(RamBase) ? RamBase : 0x10000;
-RamSize = DEFINED(RamSize) ? RamSize : 0x70000;
+RomBase = DEFINED(RomBase) ? RomBase : 0x90000;
+RamBase = DEFINED(RamBase) ? RamBase : 0x03000;
+RamSize = DEFINED(RamSize) ? RamSize : 0x7d000;
_RamEnd = RamBase + RamSize;
-HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x2000;
MEMORY
- ram : ORIGIN = 0x10000, LENGTH = 0x70000
+ rom : ORIGIN = 0x90000, LENGTH = 0x70000
+ ram : ORIGIN = 0x03000, LENGTH = 0x7d000
-_copy_data_from_rom = 0;
+_copy_data_from_rom = 1;
+HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
+_StackSize = DEFINED(_StackSize) ? _StackSize : 0x2000;
- * stick everything in ram (of course)
SECTIONS
- ram : {
- } >ram
- * Text, data and bss segments
- .text : {
- *(.text*)
- * C++ constructors/destructors
- *(.gnu.linkonce.t.*)
- * Initialization and finalization code.
- * Various files can provide initialization and finalization
- * functions. crtbegin.o and crtend.o are two instances. The
- * body of these functions are in .init and .fini sections. We
- * accumulate the bodies here, and prepend function prologues
- * from crti.o and function epilogues from crtn.o. crti.o must
- * be linked first; crtn.o must be linked last. Because these
- * are wildcards, it doesn't matter if the user does not
- * actually link against crti.o and crtn.o; the linker won't
- * look for a file to match a wildcard. The wildcard also
- * means that it doesn't matter which directory crti.o and
- * crtn.o are in.
- PROVIDE (_init = .);
- *crti.o(.init)
- *(.init)
- *crtn.o(.init)
- PROVIDE (_fini = .);
- *crti.o(.fini)
- *(.fini)
- *crtn.o(.fini)
- * Special FreeBSD sysctl sections.
- . = ALIGN (16);
- __start_set_sysctl_set = .;
- *(set_sysctl_*);
- __stop_set_sysctl_set = ABSOLUTE(.);
- *(set_domain_*);
- *(set_pseudo_*);
- * gcc uses crtbegin.o to find the start of the constructors
- * and destructors so we make sure it is first. Because this
- * is a wildcard, it doesn't matter if the user does not
- * actually link against crtbegin.o; the linker won't look for
- * a file to match a wildcard. The wildcard also means that
- * it doesn't matter which directory crtbegin.o is in. The
- * constructor and destructor list are terminated in
- * crtend.o. The same comments apply to it.
- . = ALIGN (16);
- *crtbegin.o(.ctors)
- *(.ctors)
- *crtend.o(.ctors)
- *crtbegin.o(.dtors)
- *(.dtors)
- *crtend.o(.dtors)
- * Exception frame info
- . = ALIGN (16);
- *(.eh_frame)
- * Read-only data
- . = ALIGN (16);
- _rodata_start = .;
- *(.rodata*)
- *(.gnu.linkonce.r*)
- . = ALIGN (16);
- PROVIDE (_etext = .);
- } >ram
- .tdata : {
- _TLS_Data_begin = .;
- *(.tdata .tdata.* .gnu.linkonce.td.*)
- _TLS_Data_end = .;
- } >ram
- .tbss : {
- _TLS_BSS_begin = .;
- *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
- _TLS_BSS_end = .;
- } >ram
- _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
- _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
- _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
- _TLS_Alignment = ALIGNOF (.tdata);
- .data : {
- PROVIDE (_copy_start = .);
- *(.data*)
- *(.gnu.linkonce.d*)
- *(.gcc_except_table*)
- *(.jcr)
- . = ALIGN (16);
- PROVIDE (_edata = .);
- PROVIDE (_copy_end = .);
- } >ram
- .bss : {
- _clear_start = .;
- *(.dynbss)
- *(.bss* .gnu.linkonce.b.*)
- *(COMMON)
- . = ALIGN (16);
- PROVIDE (end = .);
- . += _StackSize;
- . = ALIGN (16);
- _stack_init = .;
- _clear_end = .;
- WorkAreaBase = .;
- } >ram
+ .text :
+ text_start = .;
+ _text_start = .;
+ *(.text*)
+ . = ALIGN (16);
+ * C++ constructors/destructors
+ *(.gnu.linkonce.t.*)
+ * Initialization and finalization code.
+ * Various files can provide initialization and finalization
+ * functions. crtbegin.o and crtend.o are two instances. The
+ * body of these functions are in .init and .fini sections. We
+ * accumulate the bodies here, and prepend function prologues
+ * from crti.o and function epilogues from crtn.o. crti.o must
+ * be linked first; crtn.o must be linked last. Because these
+ * are wildcards, it doesn't matter if the user does not
+ * actually link against crti.o and crtn.o; the linker won't
+ * look for a file to match a wildcard. The wildcard also
+ * means that it doesn't matter which directory crti.o and
+ * crtn.o are in.
+ PROVIDE (_init = .);
+ *crti.o(.init)
+ *(.init)
+ *crtn.o(.init)
+ PROVIDE (_fini = .);
+ *crti.o(.fini)
+ *(.fini)
+ *crtn.o(.fini)
+ * Special FreeBSD sysctl sections.
+ . = ALIGN (16);
+ __start_set_sysctl_set = .;
+ *(set_sysctl_*);
+ __stop_set_sysctl_set = ABSOLUTE(.);
+ *(set_domain_*);
+ *(set_pseudo_*);
+ * gcc uses crtbegin.o to find the start of the constructors
+ * and destructors so we make sure it is first. Because this
+ * is a wildcard, it doesn't matter if the user does not
+ * actually link against crtbegin.o; the linker won't look for
+ * a file to match a wildcard. The wildcard also means that
+ * it doesn't matter which directory crtbegin.o is in. The
+ * constructor and destructor list are terminated in
+ * crtend.o. The same comments apply to it.
+ . = ALIGN (16);
+ *crtbegin.o(.ctors)
+ *(.ctors)
+ *crtend.o(.ctors)
+ *crtbegin.o(.dtors)
+ *(.dtors)
+ *crtend.o(.dtors)
+ * Exception frame info
+ . = ALIGN (16);
+ *(.eh_frame)
+ * Read-only data
+ . = ALIGN (16);
+ _rodata_start = . ;
+ *(.rodata*)
+ *(.gnu.linkonce.r*)
+ . = ALIGN (16);
+ PROVIDE (_etext = .);
+ _endtext = .;
+ __data_start_rom = .;
+ } > rom
+ .tdata : {
+ _TLS_Data_begin = .;
+ *(.tdata .tdata.* .gnu.linkonce.td.*)
+ _TLS_Data_end = .;
+ } > rom
+ .tbss : {
+ _TLS_BSS_begin = .;
+ *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
+ _TLS_BSS_end = .;
+ } > rom
+ _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
+ _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
+ _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
+ _TLS_Alignment = ALIGNOF (.tdata);
+ .gcc_exc :
+ AT ( ADDR(.tdata) + SIZEOF( .tdata ) )
+ *(.gcc_exc)
+ } > ram
+ .data : AT(__data_start_rom)
+ PROVIDE (_copy_start = .);
+ *(.data*)
+ *(.gnu.linkonce.d*)
+ *(.gcc_except_table*)
+ *(.jcr)
+ . = ALIGN (16);
+ PROVIDE (_edata = .);
+ PROVIDE (_copy_end = .);
+ } > ram
+ .shbss :
+ *(.shbss)
+ } > ram
+ .bss :
+ M68Kvec = .;
+ . += (256 * 4);
+ _clear_start = .;
+ *(.dynbss)
+ *(.bss* .gnu.linkonce.b.*)
+ *(COMMON)
+ . = ALIGN (16);
+ PROVIDE (end = .);
+ . += _StackSize;
+ . = ALIGN (16);
+ _stack_init = .;
+ _clear_end = .;
+ WorkAreaBase = .;
+ } > ram
+ .stab . (NOLOAD) :
+ [ .stab ]
+ .stabstr . (NOLOAD) :
+ [ .stabstr ]
diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM b/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM
index 48b2f3f..0000000
--- a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM
+++ /dev/null
@@ -1,212 +0,0 @@
-/* linkcmds
-OUTPUT_ARCH(m68k)
-STARTUP(except_vect_332_ROM.o)
-__DYNAMIC = 0;
- * ROM:
- * +--------------------+ <- low memory
- * | .text |
- * | etext |
- * | ctor list | the ctor and dtor lists are for
- * | dtor list | C++ support
- * | _endtext |
- * | temporary .data | .data is moved to RAM by crt0
- * +--------------------+ <- high memory
- * RAM:
- * | .data | initialized data goes here
- * | _sdata |
- * | _edata |
- * | .bss |
- * | __bss_start | start of bss, cleared by crt0
- * | _end | start of heap, used by sbrk()
- * | heap space |
- * | _ENDHEAP |
- * | stack space |
- * | __stack | top of stack
-MEMORY
- rom : ORIGIN = 0x90000, LENGTH = 0x70000
- ram : ORIGIN = 0x03000, LENGTH = 0x7d000
-RamBase = DEFINED(RamBase) ? RamBase : 0x003000;
-RamSize = DEFINED(RamSize) ? RamSize : 0x7d000;
-_RamEnd = RamBase + RamSize;
-__end_of_ram = 0x080000;
-_copy_data_from_rom = 1;
-SECTIONS
- .text :
- CREATE_OBJECT_SYMBOLS
- text_start = .;
- _text_start = .;
- *(.text*)
- . = ALIGN (16);
- * crtn.o are in.
- *crti.o(.init)
- *(.init)
- *crtn.o(.init)
- *crti.o(.fini)
- *(.fini)
- *crtn.o(.fini)
- . = ALIGN (16);
- *(set_sysctl_*);
- *(set_domain_*);
- *(set_pseudo_*);
- . = ALIGN (16);
- *(.ctors)
- *crtend.o(.ctors)
- *(.dtors)
- *crtend.o(.dtors)
- *(.eh_frame)
- . = ALIGN (16);
- * Read-only data
- . = ALIGN (16);
- _rodata_start = . ;
- *(.rodata*)
- etext = ALIGN(0x10);
- __CTOR_LIST__ = .;
- LONG((__CTOR_END__ - __CTOR_LIST__) / 4 - 2)
- *(.ctors)
- LONG(0)
- __CTOR_END__ = .;
- __DTOR_LIST__ = .;
- LONG((__DTOR_END__ - __DTOR_LIST__) / 4 - 2)
- *(.dtors)
- LONG(0)
- __DTOR_END__ = .;
- *(.lit)
- *(.shdata)
- _etext = .;
- _endtext = .;
- } > rom
- .tdata : {
- } > rom
- .tbss : {
- _TLS_BSS_end = .;
- } > rom
- .gcc_exc :
- AT ( ADDR(.tdata) + SIZEOF( .tdata ) )
- *(.gcc_exc)
- } > ram
- .data :
- data_start = .;
- _data_start = .;
- _copy_start = .;
- _sdata = . ;
- *(.data)
- *(.jcr)
- CONSTRUCTORS
- edata = ALIGN(0x10);
- _edata = .;
- } > ram
- .shbss :
- *(.shbss)
- } > ram
- .bss :
- __bss_start = ALIGN(0x8);
- bss_start = .;
- _bss_start = .;
- _clear_start = .;
- *(.shbss)
- *(.dynbss)
- *(COMMON)
- . = ALIGN (16);
- end = .;
- _end = ALIGN(0x8);
- __end = ALIGN(0x8);
- WorkAreaBase = . + _StackSize;
- } > ram
- .stab . (NOLOAD) :
- [ .stab ]
- .stabstr . (NOLOAD) :
- [ .stabstr ]
diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c b/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c
index 5c3c38c..060c96b 100644
--- a/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c
+++ b/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c
@@ -14,14 +14,11 @@
+#include <bsp.h>
+#include <bsp/bootcard.h>
#include <mrm332.h>
#include <rtems/m68k/sim.h>
#define __START_C__
-#include "bsp.h"
-#include <bsp/bootcard.h>
-rtems_isr_entry M68Kvec[256];
-rtems_isr_entry vectors[256];
* This prototype really should have the noreturn attribute but
@@ -32,99 +29,97 @@ void start_c(void);
void start_c(void) {
+#ifdef SET_EDIV
+#define OPTIONAL_EDIV EDIV
+#else
+#define OPTIONAL_EDIV 0
+#endif
+ /* Synthesizer Control Register */
+ /* see section(s) 4.8 */
+ /* end include in ram_init.S */
+ *SYNCR = (unsigned short int) (SAM(MRM_W, 15, VCO) | SAM(0x0, 14, PRESCALE)
+ | SAM(MRM_Y, 8, COUNTER) | OPTIONAL_EDIV);
+ while (!(*SYNCR & SLOCK))
+ ; /* protect from clock overshoot */
+ /* include in ram_init.S */
+ *SYNCR = (unsigned short int) (SAM(MRM_W, 15, VCO) | SAM(MRM_X, 14,
+ PRESCALE) | SAM(MRM_Y, 8, COUNTER) | OPTIONAL_EDIV);
+ /* System Protection Control Register */
+ /* !!! can only write to once after reset !!! */
+ /* see section 3.8.4 of the SIM Reference Manual */
+ *SYPCR = (unsigned char) (HME | BME);
+ /* Periodic Interrupr Control Register */
+ /* see section 3.8.2 of the SIM Reference Manual */
+ *PICR = (unsigned short int) (SAM(0, 8, PIRQL) | SAM(MRM_PIV, 0, PIV));
+ /* ^^^ zero disables interrupt, don't enable here or ram_init will
- /* Port C Data */
- *dst++ = *src++;
- /* Zero bss */
- *dst = 0;
+ /* Periodic Interrupt Timer Register */
+ /* see section 3.8.3 of the SIM Reference Manual */
+ *PITR = (unsigned short int) (SAM(0x09, 0, PITM));
+ /* 1.098mS interrupt, assuming 32.768 KHz input clock */
+ /* Port C Data */
+ /* load values before enabled */
+ *PORTC = (unsigned char) 0x0;
+ /* Port E and F Data Register */
+ /* see section 9 of the SIM Reference Manual */
+ *PORTE0 = (unsigned char) 0;
+ *PORTF0 = (unsigned char) 0;
+ /* Port E and F Data Direction Register */
+ *DDRE = (unsigned char) 0xff;
+ *DDRF = (unsigned char) 0xfd;
+ /* Port E and F Pin Assignment Register. Set up Port E and F as I/O */
+ *PEPAR = (unsigned char) 0;
+ *PFPAR = (unsigned char) 0;
+ /* end of SIM initalization code */
+ * Initialize RAM by copying the .data section out of ROM (if
+ * needed) and "zero-ing" the .bss section.
+ register char *src = _etext;
+ register char *dst = _copy_start;
+ if (_copy_data_from_rom) {
+ /* ROM has data at end of text; copy it. */
+ while (dst < _edata)
+ *dst++ = *src++;
+ /* Zero bss */
+ for (dst = _clear_start; dst < end; dst++) {
+ *dst = 0;
+ * Initialize vector table.
+ rtems_isr_entry *monitors_vector_table;
+ m68k_get_vbr(monitors_vector_table);
+ M68Kvec[4] = monitors_vector_table[4]; /* breakpoints vector */
+ M68Kvec[9] = monitors_vector_table[9]; /* trace vector */
+ M68Kvec[31] = monitors_vector_table[31]; /* level 7 interrupt */
+ M68Kvec[47] = monitors_vector_table[47]; /* system call vector */
+ M68Kvec[66] = monitors_vector_table[66]; /* user defined */
+ m68k_set_vbr(&M68Kvec);
- /* Spurious should be called in the predriver hook */
- /* Spurious_Initialize(); */
- /*console_init(); */
1.8.3.2
