[PATCH 01/10] score: Add get/set affinity to Scheduler Framework.
Jennifer
jennifer.averett at oarcorp.com
Mon Mar 24 18:39:32 UTC 2014
From: Jennifer Averett <jennifer.averett at oarcorp.com>
cpukit/score/Makefile.am | 2 +
cpukit/score/include/rtems/score/scheduler.h | 58 ++++++++++++++++++++++
cpukit/score/include/rtems/score/schedulerimpl.h | 32 ++++++++++++
.../score/include/rtems/score/schedulerpriority.h | 11 +++-
.../include/rtems/score/schedulerprioritysmp.h | 6 ++-
.../score/include/rtems/score/schedulersimplesmp.h | 4 +-
cpukit/score/src/schedulerdefaultgetaffinity.c | 41 +++++++++++++++
cpukit/score/src/schedulerdefaultsetaffinity.c | 32 ++++++++++++
8 files changed, 182 insertions(+), 4 deletions(-)
create mode 100644 cpukit/score/src/schedulerdefaultgetaffinity.c
create mode 100644 cpukit/score/src/schedulerdefaultsetaffinity.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index aeee4b6..67cc802 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -131,6 +131,8 @@ libscore_a_SOURCES += src/schedulersmpstartidle.c
libscore_a_SOURCES += src/smp.c
libscore_a_SOURCES += src/cpuset.c
libscore_a_SOURCES += src/cpusetprintsupport.c
+libscore_a_SOURCES += src/schedulerdefaultgetaffinity.c
+libscore_a_SOURCES += src/schedulerdefaultsetaffinity.c
endif
## CORE_APIMUTEX_C_FILES
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index ced3c00..a0e36f3 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -22,6 +22,9 @@
#include <rtems/score/priority.h>
+#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) && defined(RTEMS_SMP)
+ #include <sys/cpuset.h>
+#endif
#ifdef __cplusplus
extern "C" {
@@ -98,6 +101,24 @@ typedef struct {
* @see _Scheduler_Start_idle().
void ( *start_idle )( Thread_Control *thread, Per_CPU_Control *processor );
+ * @brief Obtain the processor affinity for a thread.
+ * @see _Scheduler_Get_affinity().
+ int ( *get_affinity )( Thread_Control *thread, size_t cpusetsize, cpu_set_t *cpuset );
+ * @brief Set the processor affinity for a thread.
+ * @see _Scheduler_Set_affinity().
+ int ( *set_affinity )( Thread_Control *thread, size_t cpusetsize, cpu_set_t *cpuset );
+#endif
} Scheduler_Operations;
@@ -184,6 +205,43 @@ void _Scheduler_default_Start_idle(
+ * @brief Get affinity for the default scheduler.
+ * @param[in] thread The associated thread.
+ * @param[in] cpusetsize The size of the cpuset.
+ * @param[out] cpuset Affinity set containing all CPUs.
+ * @retval 0 Successfully got cpuset
+ * @retval -1 The cpusetsize is invalid for the system
+ int _Scheduler_default_Get_affinity(
+ Thread_Control *thread,
+ size_t cpusetsize,
+ cpu_set_t *cpuset
+ * @brief Set affinity for the default scheduler.
+ * @param[in] cpuset Affinity new affinity set.
+ * This method always returns successful and does not save
+ * the cpuset.
+ int _Scheduler_default_Set_affinity(
+ cpu_set_t *cpuset
+#endif
#ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 7fbaf54..021b50f 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -240,6 +240,38 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Start_idle(
( *_Scheduler.Operations.start_idle )( thread, processor );
+ * @param[in,out] thread The idle thread for the processor.
+ * @parma[out] cpuset The processor affinity for this thread
+ RTEMS_INLINE_ROUTINE int _Scheduler_Get_affinity(
+ cpu_set_t *cpuset
+ return (*_Scheduler.Operations.get_affinity)( thread, cpusetsize, cpuset );
+ * @parma[in] cpuset The processor affinity for this thread
+ RTEMS_INLINE_ROUTINE int _Scheduler_Set_affinity(
+ cpu_set_t *cpuset
+ return (*_Scheduler.Operations.set_affinity)( thread, cpusetsize, cpuset );
+#endif
RTEMS_INLINE_ROUTINE void _Scheduler_Update_heir(
Thread_Control *heir,
bool force_dispatch
diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
index 605ab39..a9a46e9 100644
--- a/cpukit/score/include/rtems/score/schedulerpriority.h
+++ b/cpukit/score/include/rtems/score/schedulerpriority.h
@@ -34,6 +34,14 @@ extern "C" {
+ #define SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
+ _Scheduler_default_Get_affinity, /* get affinity entry point */ \
+ _Scheduler_default_Set_affinity /* set affinity entry point */
+#else
+#endif
* Entry points for the Deterministic Priority Based Scheduler.
@@ -53,7 +61,8 @@ extern "C" {
_Scheduler_priority_Priority_compare, /* compares two priorities */ \
_Scheduler_default_Release_job, /* new period of task */ \
_Scheduler_default_Tick, /* tick entry point */ \
- _Scheduler_default_Start_idle /* start idle entry point */ \
+ _Scheduler_default_Start_idle, /* start idle entry point */ \
+ SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index b0e5fad..bee4232 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -48,7 +48,7 @@ extern "C" {
- * @brief Entry points for the Simple SMP Scheduler.
+ * @brief Entry points for the Priority SMP Scheduler.
#define SCHEDULER_PRIORITY_SMP_ENTRY_POINTS \
@@ -66,7 +66,9 @@ extern "C" {
_Scheduler_priority_Priority_compare, \
_Scheduler_default_Release_job, \
_Scheduler_default_Tick, \
- _Scheduler_SMP_Start_idle \
+ _Scheduler_SMP_Start_idle, \
+ _Scheduler_default_Get_affinity, \
+ _Scheduler_default_Set_affinity \
void _Scheduler_priority_SMP_Initialize( void );
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index 1a69358..e8cd54b 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -68,7 +68,9 @@ extern "C" {
void _Scheduler_simple_smp_Initialize( void );
diff --git a/cpukit/score/src/schedulerdefaultgetaffinity.c b/cpukit/score/src/schedulerdefaultgetaffinity.c
new file mode 100644
index 0000000..fde9b01
--- /dev/null
+++ b/cpukit/score/src/schedulerdefaultgetaffinity.c
@@ -0,0 +1,41 @@
+ * @file
+ * @brief Scheduler Default Get Affinity Operation
+ * @ingroup ScoreScheduler
+ * COPYRIGHT (c) 2014.
+ * On-Line Applications Research Corporation (OAR).
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/schedulerimpl.h>
+#include <rtems/score/cpusetimpl.h>
+int _Scheduler_default_Get_affinity(
+ cpu_set_t *cpuset
+ const CPU_set_Control *ctl;
+ ctl = _CPU_set_Default();
+ if ( cpusetsize == ctl->setsize ) {
+ return -1;
+ CPU_COPY( cpuset, ctl->set );
+ return 0;
diff --git a/cpukit/score/src/schedulerdefaultsetaffinity.c b/cpukit/score/src/schedulerdefaultsetaffinity.c
index 0000000..9c1eef0
--- /dev/null
+++ b/cpukit/score/src/schedulerdefaultsetaffinity.c
@@ -0,0 +1,32 @@
+ * @file
+ * @brief Scheduler Default Set Affinity Operation
+#if HAVE_CONFIG_H
+#endif
+int _Scheduler_default_Set_affinity(
+ cpu_set_t *cpuset
+ return 0;
1.8.1.4
