[PATCH 02/10] score: Add priority affinity smp scheduler.
Jennifer
jennifer.averett at oarcorp.com
Mon Mar 24 18:39:33 UTC 2014
From: Jennifer Averett <jennifer.averett at oarcorp.com>
cpukit/score/Makefile.am | 2 +
.../rtems/score/schedulerpriorityaffinitysmp.h | 144 +++++++++++++++++++++
cpukit/score/preinstall.am | 4 +
cpukit/score/src/schedulerpriorityaffinitysmp.c | 95 ++++++++++++++
4 files changed, 245 insertions(+)
create mode 100644 cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
create mode 100644 cpukit/score/src/schedulerpriorityaffinitysmp.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 67cc802..95406d9 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -109,6 +109,7 @@ endif
if HAS_SMP
include_rtems_score_HEADERS += include/rtems/score/atomic.h
include_rtems_score_HEADERS += include/rtems/score/cpustdatomic.h
+include_rtems_score_HEADERS += include/rtems/score/schedulerpriorityaffinitysmp.h
include_rtems_score_HEADERS += include/rtems/score/schedulersimplesmp.h
endif
@@ -125,6 +126,7 @@ endif
if HAS_SMP
libscore_a_SOURCES += src/profilingsmplock.c
+libscore_a_SOURCES += src/schedulerpriorityaffinitysmp.c
libscore_a_SOURCES += src/schedulerprioritysmp.c
libscore_a_SOURCES += src/schedulersimplesmp.c
libscore_a_SOURCES += src/schedulersmpstartidle.c
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
new file mode 100644
index 0000000..b64f54d
--- /dev/null
+++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
@@ -0,0 +1,144 @@
+ * @file
+ * @ingroup ScoreSchedulerPriorityAffinitySMP
+ * @brief Deterministic Priority Affinity SMP Scheduler API
+ * COPYRIGHT (c) 2014.
+ * On-Line Applications Research Corporation (OAR).
+#ifndef _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
+#define _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
+#include <rtems/score/scheduler.h>
+#include <rtems/score/schedulerpriority.h>
+#include <rtems/score/schedulersmp.h>
+#include <rtems/score/schedulerprioritysmp.h>
+#include <rtems/score/cpuset.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup ScoreSchedulerPriorityAffinitySMP Deterministic Priority Affinity SMP Scheduler
+ * This is an extension of the Deterministic Priority SMP Scheduler. which
+ * is an implementation of the global fixed priority scheduler (G-FP).
+ * It adds thread to core affinity support.
+ * @note This is the first iteration of this scheduler. It currently tracks
+ * the requested affinity to exercise the Scheduler Framework but it
+ * does not honor that affinity in assigning threads to cores. This
+ * will be added in a subsequent revision.
+ * @brief Entry points for the Simple SMP Scheduler w/ Affinity.
+#define SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS \
+ _Scheduler_priority_SMP_Initialize, \
+ _Scheduler_priority_SMP_Schedule, \
+ _Scheduler_priority_SMP_Yield, \
+ _Scheduler_priority_SMP_Block, \
+ _Scheduler_priority_SMP_Enqueue_fifo, \
+ _Scheduler_priority_affinity_SMP_Allocate, \
+ _Scheduler_priority_Free, \
+ _Scheduler_priority_SMP_Update, \
+ _Scheduler_priority_SMP_Enqueue_lifo, \
+ _Scheduler_priority_SMP_Extract, \
+ _Scheduler_priority_Priority_compare, \
+ _Scheduler_default_Release_job, \
+ _Scheduler_default_Tick, \
+ _Scheduler_SMP_Start_idle, \
+ _Scheduler_priority_affinity_SMP_Get_affinity, \
+ _Scheduler_priority_affinity_SMP_Set_affinity \
+ * @brief Allocates @a the_thread->scheduler.
+ * This routine allocates @a the_thread->scheduler.
+ * @param[in] the_thread is the thread the scheduler is allocating
+ * management memory for
+void * _Scheduler_priority_affinity_SMP_Allocate( Thread_Control *the_thread );
+ * @brief Get affinity for the priority affinity smp scheduler.
+ * @param[in] thread The associated thread.
+ * @param[in] cpusetsize The size of the cpuset.
+ * @param[in,out] cpuset The associated affinity set.
+ * @retval 0 Successfully got cpuset
+ * @retval -1 The cpusetsize is invalid for the system
+int _Scheduler_priority_affinity_SMP_Get_affinity(
+ Thread_Control *thread,
+ size_t cpusetsize,
+ cpu_set_t *cpuset
+ * @brief Set affinity for the priority affinity smp scheduler.
+ * @param[in] cpuset Affinity new affinity set.
+int _Scheduler_priority_affinity_SMP_Set_affinity(
+ cpu_set_t *cpuset
+ * This structure handles affinity specific data of a thread.
+ * @note The attribute priority_sched_info must remain
+ * the first element in the structure so that the
+ * Scheduler_priority_XXX methods will continue to
+ * function.
+typedef struct {
+ * Data for the Priority Scheduler.
+ Scheduler_priority_Per_thread priority_sched_info;
+ * Pointer to corresponding Thread Control Block.
+ Thread_Control *thread;
+ * Structure containing affinity set data and size
+ CPU_set_Control affinity;
+} Scheduler_priority_affinity_SMP_Per_thread;
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_SCHEDULERPRIORITYSMP_H */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 68ded43..efbe37d 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -386,6 +386,10 @@ $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h: include/rtems/score/cpustdatomic.
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
+$(PROJECT_INCLUDE)/rtems/score/schedulerpriorityaffinitysmp.h: include/rtems/score/schedulerpriorityaffinitysmp.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulerpriorityaffinitysmp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerpriorityaffinitysmp.h
$(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h: include/rtems/score/schedulersimplesmp.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h
diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
index 0000000..aa77d8d
--- /dev/null
+++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
@@ -0,0 +1,95 @@
+ * @file
+ * @brief Deterministic Priority Affinity SMP Scheduler Implementation
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/schedulerpriorityaffinitysmp.h>
+#include <rtems/score/schedulerpriorityimpl.h>
+#include <rtems/score/schedulersmpimpl.h>
+#include <rtems/score/wkspace.h>
+#include <rtems/score/cpusetimpl.h>
+RTEMS_INLINE_ROUTINE Scheduler_priority_affinity_SMP_Per_thread *
+_Scheduler_priority_affinity_Get_scheduler_info( Thread_Control *thread )
+ return ( Scheduler_priority_affinity_SMP_Per_thread * ) thread->scheduler_info;
+void _Scheduler_priority_affinity_SMP_Initialize( void )
+ Scheduler_SMP_Control *self = _Workspace_Allocate_or_fatal_error(
+ sizeof( *self ) + PRIORITY_MAXIMUM * sizeof( Chain_Control )
+ _Chain_Initialize_empty( &self->scheduled );
+ _Scheduler_priority_Ready_queue_initialize( &self->ready[ 0 ] );
+ _Scheduler.information = self;
+ Scheduler_priority_affinity_SMP_Per_thread *sched_info_of_thread =
+ _Workspace_Allocate( sizeof( *sched_info_of_thread ) );
+ sched_info_of_thread->affinity = *_CPU_set_Default();
+ sched_info_of_thread->affinity.set =
+ &sched_info_of_thread->affinity.preallocated;
+ the_thread->scheduler_info = sched_info_of_thread;
+ return sched_info_of_thread;
+ cpu_set_t *cpuset
+ _Scheduler_priority_affinity_Get_scheduler_info(thread);
+ if ( sched_info_of_thread->affinity.setsize != cpusetsize ) {
+ return -1;
+ CPU_COPY( cpuset, sched_info_of_thread->affinity.set );
+ return 0;
+ cpu_set_t *cpuset
+ return -1;
+ CPU_COPY( sched_info_of_thread->affinity.set, cpuset );
+ return 0;
1.8.1.4
