[PATCH 1/2] privateenv: Remove sharing of user environment between threads.
Wed Mar 26 15:15:16 UTC 2014
Quick glance looks OK, but I leave it up to Sebastian or Chris to approve.
On Wed, Mar 26, 2014 at 8:29 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>  cpukit/include/rtems/userenv.h                 | 20 ---------
>  cpukit/libcsupport/src/privateenv.c            | 60 ++------------------------
>  testsuites/fstests/fsnofs01/fsnofs01.doc       |  1 -
>  testsuites/fstests/fsnofs01/init.c             | 12 ------
>  testsuites/sptests/spprivenv01/init.c          | 40 +++++++----------
>  testsuites/sptests/spprivenv01/spprivenv01.doc |  5 +--
>  testsuites/sptests/spprivenv01/spprivenv01.scn | 15 +++----
>  7 files changed, 27 insertions(+), 126 deletions(-)
> diff --git a/cpukit/include/rtems/userenv.h b/cpukit/include/rtems/userenv.h
> index 7d874d3..8a9a4fc 100644
> --- a/cpukit/include/rtems/userenv.h
> +++ b/cpukit/include/rtems/userenv.h
> @@ -64,9 +64,6 @@ typedef struct {
>    gid_t                            egid;
>    char      login_buffer[LOGIN_NAME_MAX];
>    pid_t                            pgrp; /* process group id */
> -  /* User environment maintenance */
> -  rtems_id                         task_id;
> -  int                              reference_count;
>  } rtems_user_env_t;
>  extern rtems_user_env_t * rtems_current_user_env;
> @@ -97,23 +94,6 @@ extern rtems_user_env_t   rtems_global_user_env;
>  rtems_status_code rtems_libio_set_private_env(void);
> - * @brief Creates a private environment shared with another task.
> - * An attempt to share the environment with itself has no effect.  This
> - * function must be called from normal thread context and may block on a mutex.
> - * Thread dispatching is disabled to protect some critical sections.
> - * @param[in] task_id The private environment is shared with the task specified
> - * by this identifier.
> - * @retval RTEMS_SUCCESSFUL Successful operation.
> - * @retval RTEMS_UNSATISFIED No shared environment is available for this task
> - * @retval RTEMS_TOO_MANY Cannot register the shared environment.
> - * identifier.
> -rtems_status_code rtems_libio_share_private_env(rtems_id task_id) ;
>   * @brief Use the global environment.
>   * A private environment will be released.  This function may be called from
> diff --git a/cpukit/libcsupport/src/privateenv.c b/cpukit/libcsupport/src/privateenv.c
> index c7a65a5..bee94c1 100644
> --- a/cpukit/libcsupport/src/privateenv.c
> +++ b/cpukit/libcsupport/src/privateenv.c
> @@ -35,13 +35,9 @@ static void free_user_env(void *arg)
>    bool uses_global_env = env == &rtems_global_user_env;
>    if (!uses_global_env) {
> -    if (env->reference_count == 1) {
> -      rtems_filesystem_global_location_release(env->current_directory);
> -      rtems_filesystem_global_location_release(env->root_directory);
> -      free(env);
> -    } else {
> -      --env->reference_count;
> +    rtems_filesystem_global_location_release(env->current_directory);
> +    rtems_filesystem_global_location_release(env->root_directory);
> +    free(env);
> @@ -55,18 +51,14 @@ static void free_user_env_protected(rtems_user_env_t *env)
>    rtems_status_code sc = RTEMS_SUCCESSFUL;
> -  rtems_id self_task_id = rtems_task_self();
>    rtems_user_env_t *old_env = rtems_current_user_env;
>    bool uses_global_env = old_env == &rtems_global_user_env;
> -  bool uses_shared_env = old_env->task_id != self_task_id;
> -  if (uses_global_env || uses_shared_env) {
> +  if (uses_global_env) {
>      rtems_user_env_t *new_env = calloc(1, sizeof(*new_env));
>      if (new_env != NULL) {
>        *new_env = *old_env;
> -      new_env->reference_count = 1;
> -      new_env->task_id = self_task_id;
>        new_env->root_directory =
>          rtems_filesystem_global_location_obtain(&old_env->root_directory);
>        new_env->current_directory =
> @@ -102,50 +94,6 @@ rtems_status_code rtems_libio_set_private_env(void)
>    return sc;
> -  rtems_status_code sc = RTEMS_SUCCESSFUL;
> -  if (task_id != RTEMS_SELF && self_task_id != task_id) {
> -    rtems_user_env_t *env;
> -     * We have to disable the thread dispatching to prevent deletion of the
> -     * environment in the meantime.
> -    _Thread_Disable_dispatch();
> -    sc = rtems_task_variable_get(
> -      task_id,
> -      (void *) &rtems_current_user_env,
> -      (void *) &env
> -    if (sc == RTEMS_SUCCESSFUL) {
> -      ++env->reference_count;
> -    } else {
> -      sc = RTEMS_UNSATISFIED;
> -    _Thread_Enable_dispatch();
> -      sc = rtems_task_variable_add(
> -        RTEMS_SELF,
> -        (void **) &rtems_current_user_env,
> -        free_user_env
> -        free_user_env_protected(rtems_current_user_env);
> -        rtems_current_user_env = env;
> -      } else {
> -        free_user_env_protected(env);
> -        sc = RTEMS_TOO_MANY;
> -  return sc;
>  void rtems_libio_use_global_env(void)
> diff --git a/testsuites/fstests/fsnofs01/fsnofs01.doc b/testsuites/fstests/fsnofs01/fsnofs01.doc
> index 5980be8..3a47c46 100644
> --- a/testsuites/fstests/fsnofs01/fsnofs01.doc
> +++ b/testsuites/fstests/fsnofs01/fsnofs01.doc
> @@ -35,7 +35,6 @@ directives:
>    + rtems_filesystem_location_free
>    + rtems_filesystem_global_location_obtain_null
>    + rtems_libio_set_private_env
> -  + rtems_libio_share_private_env
>    + rtems_libio_use_global_env
>    + rmdir
>    + stat
> diff --git a/testsuites/fstests/fsnofs01/init.c b/testsuites/fstests/fsnofs01/init.c
> index fdcf959..13cd709 100644
> --- a/testsuites/fstests/fsnofs01/init.c
> +++ b/testsuites/fstests/fsnofs01/init.c
> @@ -315,18 +315,6 @@ static void test_user_env(void)
>    rtems_test_assert(node_count(loc_chain) == 1);
>    rtems_test_assert(null_loc->reference_count == 4);
> -  sc = rtems_libio_share_private_env(RTEMS_SELF);
> -  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> -  rtems_test_assert(node_count(loc_chain) == 1);
> -  rtems_test_assert(null_loc->reference_count == 4);
> -  sc = rtems_libio_share_private_env(rtems_task_self());
>    rtems_libio_use_global_env();
> diff --git a/testsuites/sptests/spprivenv01/init.c b/testsuites/sptests/spprivenv01/init.c
> index f60bcef..a670085 100644
> --- a/testsuites/sptests/spprivenv01/init.c
> +++ b/testsuites/sptests/spprivenv01/init.c
> @@ -31,6 +31,9 @@ rtems_task task_routine(rtems_task_argument not_used)
>    sc = rtems_libio_set_private_env();
>    directive_failed( sc, "set private env" );
> +  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
> +  rtems_test_assert( rtems_current_user_env != &rtems_global_user_env );
>    sleep( 1 );
>    rtems_task_delete( RTEMS_SELF );
> @@ -42,9 +45,9 @@ rtems_task Init(
>    rtems_status_code       sc;
>    void                   *opaque;
> -  rtems_id                current_task_id;
>    rtems_id                task_id;
>    rtems_name              another_task_name;
> +  rtems_user_env_t       *current_env;
>    TEST_BEGIN();
> @@ -68,6 +71,12 @@ rtems_task Init(
>    puts( "Init - freeing the workspace memory" );
>    rtems_workspace_greedy_free( opaque );
> +  puts( "Init - Attempt to get a private environment" );
> +  sc = rtems_libio_set_private_env();
> +  current_env = rtems_current_user_env;
> +  rtems_test_assert( current_env != &rtems_global_user_env );
>    puts( "Init - creating a task name and a task -- OK" );
>    another_task_name =
> @@ -85,33 +94,14 @@ rtems_task Init(
>    sc = rtems_task_start( task_id, task_routine, 0);
> -  puts( "Init - attempt to share the env with another task -- Expect error" );
> -  sc = rtems_libio_share_private_env( task_id );
> -  rtems_test_assert( sc == RTEMS_UNSATISFIED );
>    sleep( 1 );
> -  puts( "Init - attempt to share the env with another task -- OK" );
> -  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
> -  rtems_test_assert( rtems_current_user_env->task_id == task_id );
> -  puts( "Init - Get current task id" );
> -  current_task_id = rtems_task_self();
> +  puts( "Init - Check current private environment. Should be same as before." );
> +  rtems_test_assert( rtems_current_user_env == current_env );
> -  puts( "Init - Attempt to reset current task's environment" );
> -  sc = rtems_libio_set_private_env();
> -  rtems_test_assert( rtems_current_user_env->task_id == current_task_id );
> -  puts( "Init - attempt to share with self -- OK" );
> +  puts( "Init - Reset to global environment" );
> +  rtems_libio_use_global_env();
> +  rtems_test_assert( rtems_current_user_env == &rtems_global_user_env );
>    TEST_END();
> diff --git a/testsuites/sptests/spprivenv01/spprivenv01.doc b/testsuites/sptests/spprivenv01/spprivenv01.doc
> index cb5c1bc..71ed426 100644
> --- a/testsuites/sptests/spprivenv01/spprivenv01.doc
> +++ b/testsuites/sptests/spprivenv01/spprivenv01.doc
> @@ -13,10 +13,9 @@ test set name:  spprivenv01
>  directives:
>  concepts:
> -+ Exercise the routines at privateenv.c, which reset/share a task's
> -private environment
> ++ Exercise the routines at privateenv.c, which reset a task's private
> +environment
> diff --git a/testsuites/sptests/spprivenv01/spprivenv01.scn b/testsuites/sptests/spprivenv01/spprivenv01.scn
> index b95832c..1b71be1 100644
> --- a/testsuites/sptests/spprivenv01/spprivenv01.scn
> +++ b/testsuites/sptests/spprivenv01/spprivenv01.scn
> @@ -1,17 +1,14 @@
> -*** TEST USER ENVIRONMENT ROUTINE - 01 ***
> +*** BEGIN OF TEST SPPRIVENV 1 ***
>  Init - allocating most of heap -- OK
>  Init - attempt to reset env - expect RTEMS_NO_MEMORY
>  Init - freeing the allocated memory
>  Init - allocating most of workspace memory
> -Init - attempt to reset env - expect RTEMS_NO_MEMORY
> +Init - attempt to reset env - expect RTEMS_TOO_MANY
> +Init - Attempt to get a private environment
>  Init - starting the task_routine, to set its private environment
> -Init - attempt to share the env with another task -- Expect error
>  task_routine - setting up a private environment
> -Init - attempt to share the env with another task -- OK
> -Init - Get current task id
> -Init - Attempt to reset current task's environment
> -Init - attempt to share with self -- OK
> -*** END OF TEST USER ENVIRONMENT ROUTINE - 01 ***
> +Init - Check current private environment. Should be same as before.
> +Init - Reset to global environment
> +*** END OF TEST SPPRIVENV 1 ***
> 1.8.4.5
> rtems-devel mailing list
> rtems-devel at rtems.org
