[PATCH 2/2] privateenv: Use POSIX keys instead of task variables.
Thu Mar 27 12:15:33 UTC 2014
On Thu, Mar 27, 2014 at 2:23 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
>> OK. I think it would be good to write this down somewhere for future
>> reference. possibly in the same spot you documented the note about
>> needing to configure the system with the key-value.
>> -Gedare
> I've extended the documentation for the set_private_env function. I hope that it
> is clear now.
Yes it is better now, but I still think the solution is fragile. My
opinion is that there should be some option for the user to set how
many threads use private environment, and that will feed into the
number of configured key-value pairs. But my opinion is not strong on
this subject.
> rtems-devel mailing list
> rtems-devel at rtems.org
