[PATCH 2/2] privateenv: Use POSIX keys instead of task variables.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Mar 27 06:23:53 UTC 2014
> OK. I think it would be good to write this down somewhere for future
> reference. possibly in the same spot you documented the note about
> needing to configure the system with the key-value.
> -Gedare
I've extended the documentation for the set_private_env function. I hope that it
is clear now.
