[PATCH 2/2] privateenv: Use POSIX keys instead of task variables.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Mar 27 06:23:54 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 cpukit/include/rtems/userenv.h                 | 21 +++++++++++++--
 cpukit/libcsupport/include/rtems/libio_.h      |  2 ++
 cpukit/libcsupport/src/__usrenv.c              |  2 +-
 cpukit/libcsupport/src/libio_init.c            | 12 +++++++++
 cpukit/libcsupport/src/privateenv.c            | 37 +++++++++++++-------------
 cpukit/sapi/include/confdefs.h                 | 29 ++++++++++++--------
 doc/shell/file.t                               |  4 ++-
 testsuites/fstests/imfs_support/fs_support.c   |  1 +
 testsuites/fstests/jffs2_support/fs_support.c  |  2 ++
 testsuites/fstests/mdosfs_support/fs_support.c |  1 +
 testsuites/fstests/mimfs_support/fs_support.c  |  1 +
 testsuites/fstests/mrfs_support/fs_support.c   |  1 +
 testsuites/libtests/ftp01/init.c               |  2 ++
 testsuites/psxtests/psxchroot01/main.c         |  2 ++
 testsuites/psxtests/psxmount/main.c            |  2 ++
 testsuites/sptests/Makefile.am                 |  2 +-
 testsuites/sptests/configure.ac                |  1 +
 testsuites/sptests/spfatal27/Makefile.am       | 21 +++++++++++++++
 testsuites/sptests/spfatal27/spfatal27.doc     | 23 ++++++++++++++++
 testsuites/sptests/spfatal27/spfatal27.scn     |  3 +++
 testsuites/sptests/spfatal27/testcase.h        | 27 +++++++++++++++++++
 testsuites/sptests/spprivenv01/init.c          | 14 +++++++---
 22 files changed, 173 insertions(+), 37 deletions(-)
 create mode 100644 testsuites/sptests/spfatal27/Makefile.am
 create mode 100644 testsuites/sptests/spfatal27/spfatal27.doc
 create mode 100644 testsuites/sptests/spfatal27/spfatal27.scn
 create mode 100644 testsuites/sptests/spfatal27/testcase.h
diff --git a/cpukit/include/rtems/userenv.h b/cpukit/include/rtems/userenv.h
index 8a9a4fc..e0c712e 100644
--- a/cpukit/include/rtems/userenv.h
+++ b/cpukit/include/rtems/userenv.h
@@ -27,6 +27,8 @@
 #include <limits.h>
+#include <pthread.h>
 #include <rtems/fs.h>
@@ -66,8 +68,18 @@ typedef struct {
   pid_t                            pgrp; /* process group id */
 } rtems_user_env_t;
-extern rtems_user_env_t * rtems_current_user_env;
-extern rtems_user_env_t   rtems_global_user_env;
+extern rtems_user_env_t rtems_global_user_env;
+extern pthread_key_t rtems_current_user_env_key;
+ * @brief Fetch the pointer to the current user environment.
+ * If the task has a private user environment the pointer to it will be
+ * returned. Otherwise the pointer to rtems_global_user_env will be returned.
+rtems_user_env_t * rtems_current_user_env_get(void);
+#define rtems_current_user_env rtems_current_user_env_get()
 #define rtems_filesystem_current     (rtems_current_user_env->current_directory)
 #define rtems_filesystem_root        (rtems_current_user_env->root_directory)
@@ -86,6 +98,11 @@ extern rtems_user_env_t   rtems_global_user_env;
  * function must be called from normal thread context and may block on a mutex.
  * Thread dispatching is disabled to protect some critical sections.
+ * The private environment internally uses a POSIX key. The key is added to the
+ * configuration implicitly. But for each thread that uses a private environment
+ * a key value pair has to be configured by the application. If only the global
+ * environment is used there is no need to configure a key value pair.
  * @retval RTEMS_SUCCESSFUL Successful operation.
  * @retval RTEMS_NO_MEMORY Not enough memory.
  * @retval RTEMS_UNSATISFIED Cloning of the current environment failed.
diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
index 9960288..0347c5b 100644
--- a/cpukit/libcsupport/include/rtems/libio_.h
+++ b/cpukit/libcsupport/include/rtems/libio_.h
@@ -238,6 +238,8 @@ void rtems_filesystem_location_free( rtems_filesystem_location_info_t *loc );
 #include <rtems/userenv.h>
+void rtems_libio_free_user_env( void *env );
 static inline void rtems_libio_lock( void )
   rtems_semaphore_obtain( rtems_libio_semaphore, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
index 3ce6a2d..71efda9 100644
--- a/cpukit/libcsupport/src/__usrenv.c
+++ b/cpukit/libcsupport/src/__usrenv.c
@@ -257,4 +257,4 @@ rtems_user_env_t rtems_global_user_env = {
   .umask = S_IWGRP | S_IWOTH
-rtems_user_env_t *rtems_current_user_env = &rtems_global_user_env;
+pthread_key_t rtems_current_user_env_key;
diff --git a/cpukit/libcsupport/src/libio_init.c b/cpukit/libcsupport/src/libio_init.c
index 4d705fb..e64ddd6 100644
--- a/cpukit/libcsupport/src/libio_init.c
+++ b/cpukit/libcsupport/src/libio_init.c
@@ -46,6 +46,7 @@ void rtems_libio_init( void )
     rtems_status_code rc;
     uint32_t i;
     rtems_libio_t *iop;
+    int eno;
     if (rtems_libio_number_iops > 0)
@@ -61,6 +62,17 @@ void rtems_libio_init( void )
+   *  Create the posix key for user environment.
+  eno = pthread_key_create(
+    &rtems_current_user_env_key,
+    rtems_libio_free_user_env
+  if (eno != 0) {
+    rtems_fatal_error_occurred( RTEMS_UNSATISFIED );
    *  Create the binary semaphore used to provide mutual exclusion
    *  on the IOP Table.
diff --git a/cpukit/libcsupport/src/privateenv.c b/cpukit/libcsupport/src/privateenv.c
index bee94c1..60207b0 100644
--- a/cpukit/libcsupport/src/privateenv.c
+++ b/cpukit/libcsupport/src/privateenv.c
@@ -29,7 +29,16 @@
  *  Instantiate a private user environment for the calling thread.
-static void free_user_env(void *arg)
+  void *ptr = pthread_getspecific(rtems_current_user_env_key);
+  if (ptr == NULL) {
+    ptr = &rtems_global_user_env;
+  return (rtems_user_env_t *) ptr;
+void rtems_libio_free_user_env(void *arg)
   rtems_user_env_t *env = arg;
   bool uses_global_env = env == &rtems_global_user_env;
@@ -44,7 +53,7 @@ static void free_user_env(void *arg)
 static void free_user_env_protected(rtems_user_env_t *env)
   _Thread_Disable_dispatch();
-  free_user_env(env);
+  rtems_libio_free_user_env(env);
   _Thread_Enable_dispatch();
@@ -68,14 +77,13 @@ rtems_status_code rtems_libio_set_private_env(void)
         !rtems_filesystem_global_location_is_null(new_env->root_directory)
           && !rtems_filesystem_global_location_is_null(new_env->current_directory)
-        sc = rtems_task_variable_add(
-          RTEMS_SELF,
-          (void **) &rtems_current_user_env,
-          free_user_env
+        int eno = pthread_setspecific(
+          rtems_current_user_env_key,
+          new_env
-        if (sc == RTEMS_SUCCESSFUL) {
+        if (eno == 0) {
           free_user_env_protected(old_env);
-          rtems_current_user_env = new_env;
         } else {
           sc = RTEMS_TOO_MANY;
@@ -84,7 +92,7 @@ rtems_status_code rtems_libio_set_private_env(void)
       if (sc != RTEMS_SUCCESSFUL) {
-        free_user_env(new_env);
+        rtems_libio_free_user_env(new_env);
     } else {
       sc = RTEMS_NO_MEMORY;
@@ -101,14 +109,7 @@ void rtems_libio_use_global_env(void)
   bool uses_private_env = env != &rtems_global_user_env;
   if (uses_private_env) {
-    sc = rtems_task_variable_delete(
-      RTEMS_SELF,
-    if (sc != RTEMS_SUCCESSFUL) {
-      rtems_fatal_error_occurred(0xdeadbeef);
-    rtems_current_user_env = &rtems_global_user_env;
+    free_user_env_protected(env);
+    pthread_setspecific(rtems_current_user_env_key, NULL);
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index b731743..d8cf2af 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -148,6 +148,11 @@ const rtems_libio_helper rtems_fs_init_helper =
 #define CONFIGURE_LIBIO_SEMAPHORES 1
+ * POSIX key count used by the IO library.
+#define CONFIGURE_LIBIO_POSIX_KEYS 1
 #ifdef CONFIGURE_INIT
    * When instantiating the configuration tables, this variable is
@@ -1734,16 +1739,18 @@ const rtems_libio_helper rtems_fs_init_helper =
 #include <rtems/posix/key.h>
 #ifndef CONFIGURE_MAXIMUM_POSIX_KEYS
-  #define CONFIGURE_MAXIMUM_POSIX_KEYS            0
-  #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 0
-#else
-  #ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
-    #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
-      (CONFIGURE_MAXIMUM_POSIX_KEYS * \
-       (CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS))
-  #endif
+  #define CONFIGURE_MAXIMUM_POSIX_KEYS 0
+#endif
+#ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+  #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
+    (CONFIGURE_MAXIMUM_POSIX_KEYS * \
+     (CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS))
 #endif
+#define CONFIGURE_POSIX_KEYS \
+  (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS)
 #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs) \
    (_Configure_Object_RAM(_keys, sizeof(POSIX_Keys_Control) ) \
     + _Configure_From_workspace( \
@@ -2222,7 +2229,7 @@ const rtems_libio_helper rtems_fs_init_helper =
      CONFIGURE_TOTAL_TASKS_AND_THREADS, CONFIGURE_TOTAL_TASKS_AND_THREADS) + \
    CONFIGURE_MEMORY_FOR_CLASSIC + \
    CONFIGURE_MEMORY_FOR_POSIX_KEYS( \
-      CONFIGURE_MAXIMUM_POSIX_KEYS, \
+      CONFIGURE_POSIX_KEYS, \
       CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ) + \
    CONFIGURE_MEMORY_FOR_POSIX + \
    CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \
@@ -2397,7 +2404,7 @@ const rtems_libio_helper rtems_fs_init_helper =
     CONFIGURE_EXECUTIVE_RAM_SIZE,             /* required RTEMS workspace */
     CONFIGURE_STACK_SPACE_SIZE,               /* required stack space */
     CONFIGURE_MAXIMUM_USER_EXTENSIONS,        /* maximum dynamic extensions */
-    CONFIGURE_MAXIMUM_POSIX_KEYS,             /* POSIX keys are always */
+    CONFIGURE_POSIX_KEYS,                     /* POSIX keys are always */
     CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS,  /*   enabled */
     CONFIGURE_MICROSECONDS_PER_TICK,          /* microseconds per clock tick */
     1000 * CONFIGURE_MICROSECONDS_PER_TICK,   /* nanoseconds per clock tick */
@@ -2592,7 +2599,7 @@ const rtems_libio_helper rtems_fs_init_helper =
     CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS),
     CONFIGURE_MEMORY_FOR_BARRIERS(CONFIGURE_BARRIERS),
     CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS),
-    CONFIGURE_MEMORY_FOR_POSIX_KEYS( CONFIGURE_MAXIMUM_POSIX_KEYS, \
+    CONFIGURE_MEMORY_FOR_POSIX_KEYS( CONFIGURE_POSIX_KEYS, \
                                      CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ),
 #ifdef RTEMS_POSIX_API
diff --git a/doc/shell/file.t b/doc/shell/file.t
index 01a3b28..eb38fe3 100644
--- a/doc/shell/file.t
+++ b/doc/shell/file.t
@@ -1148,7 +1148,9 @@ cat: /etc/passwd: No such file or directory
 This command is included in the default shell command set.
 When building a custom command set, define
 @code{CONFIGURE_SHELL_COMMAND_CHROOT} to have this
-command included.
+command included. Additional to that you have to add one
+POSIX key value pair for each thread where you want to use
+the command.
 This command can be excluded from the shell command set by
 defining @code{CONFIGURE_SHELL_NO_COMMAND_CHROOT} when all
diff --git a/testsuites/fstests/imfs_support/fs_support.c b/testsuites/fstests/imfs_support/fs_support.c
index 8eb9cca..e853690 100644
--- a/testsuites/fstests/imfs_support/fs_support.c
+++ b/testsuites/fstests/imfs_support/fs_support.c
@@ -41,6 +41,7 @@ test_shutdown_filesystem (void)
 #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 40
 #define CONFIGURE_INIT_TASK_STACK_SIZE (16 * 1024)
+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS  1
 #include <rtems/confdefs.h>
diff --git a/testsuites/fstests/jffs2_support/fs_support.c b/testsuites/fstests/jffs2_support/fs_support.c
index 2df6da3..1ff010d 100644
--- a/testsuites/fstests/jffs2_support/fs_support.c
+++ b/testsuites/fstests/jffs2_support/fs_support.c
@@ -157,6 +157,8 @@ void test_shutdown_filesystem(void)
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/fstests/mdosfs_support/fs_support.c b/testsuites/fstests/mdosfs_support/fs_support.c
index 8c5fef4..8d01e9c 100644
--- a/testsuites/fstests/mdosfs_support/fs_support.c
+++ b/testsuites/fstests/mdosfs_support/fs_support.c
@@ -91,6 +91,7 @@ void test_shutdown_filesystem(void)
 #define CONFIGURE_MAXIMUM_DRIVERS                   10
 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
diff --git a/testsuites/fstests/mimfs_support/fs_support.c b/testsuites/fstests/mimfs_support/fs_support.c
index 4b3c701..894d8f8 100644
--- a/testsuites/fstests/mimfs_support/fs_support.c
+++ b/testsuites/fstests/mimfs_support/fs_support.c
@@ -56,6 +56,7 @@ test_shutdown_filesystem (void)
diff --git a/testsuites/fstests/mrfs_support/fs_support.c b/testsuites/fstests/mrfs_support/fs_support.c
index 8c9989e..a1b9a87 100644
--- a/testsuites/fstests/mrfs_support/fs_support.c
+++ b/testsuites/fstests/mrfs_support/fs_support.c
@@ -70,6 +70,7 @@ test_shutdown_filesystem (void)
 #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
diff --git a/testsuites/libtests/ftp01/init.c b/testsuites/libtests/ftp01/init.c
index dcae4b1..b0c20a2 100644
--- a/testsuites/libtests/ftp01/init.c
+++ b/testsuites/libtests/ftp01/init.c
@@ -246,6 +246,8 @@ static rtems_task Init(rtems_task_argument argument)
+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 2
diff --git a/testsuites/psxtests/psxchroot01/main.c b/testsuites/psxtests/psxchroot01/main.c
index 0255724..5eeeebc 100644
--- a/testsuites/psxtests/psxchroot01/main.c
+++ b/testsuites/psxtests/psxchroot01/main.c
@@ -34,6 +34,8 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS 1
diff --git a/testsuites/psxtests/psxmount/main.c b/testsuites/psxtests/psxmount/main.c
index 92ddb3e..c6479cb 100644
--- a/testsuites/psxtests/psxmount/main.c
+++ b/testsuites/psxtests/psxmount/main.c
@@ -36,6 +36,8 @@ rtems_task Init(
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index d57ae69..3150694 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -18,7 +18,7 @@ SUBDIRS = \
     spfatal01 spfatal02 spfatal03 spfatal04 spfatal05 spfatal06 spfatal07 \
     spfatal08 spfatal09 spfatal10 spfatal11 spfatal12 spfatal13 spfatal14 \
     spfatal15 spfatal16 spfatal17 spfatal18 spfatal19 spfatal20 \
-    spfatal22 spfatal24 spfatal25 \
+    spfatal22 spfatal24 spfatal25 spfatal27\
     spfifo01 spfifo02 spfifo03 spfifo04 spfifo05 \
     spfreechain01 \
     spintrcritical01 spintrcritical02 spintrcritical03 spintrcritical04 \
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 5f98ba7..71f0c8d 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -166,6 +166,7 @@ spfatal20/Makefile
 spfatal22/Makefile
 spfatal24/Makefile
 spfatal25/Makefile
+spfatal27/Makefile
 spfifo01/Makefile
 spfifo02/Makefile
 spfifo03/Makefile
diff --git a/testsuites/sptests/spfatal27/Makefile.am b/testsuites/sptests/spfatal27/Makefile.am
new file mode 100644
index 0000000..744cef7
--- /dev/null
+++ b/testsuites/sptests/spfatal27/Makefile.am
@@ -0,0 +1,21 @@
+rtems_tests_PROGRAMS = spfatal27
+spfatal27_SOURCES = ../spfatal_support/init.c \
+    ../spfatal_support/system.h testcase.h
+dist_rtems_tests_DATA = spfatal27.scn
+dist_rtems_tests_DATA += spfatal27.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spfatal27_OBJECTS)
+LINK_LIBS = $(spfatal27_LDLIBS)
+spfatal27$(EXEEXT): $(spfatal27_OBJECTS) $(spfatal27_DEPENDENCIES)
+	@rm -f spfatal27$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spfatal27/spfatal27.doc b/testsuites/sptests/spfatal27/spfatal27.doc
index 0000000..f8da1bf
--- /dev/null
+++ b/testsuites/sptests/spfatal27/spfatal27.doc
@@ -0,0 +1,23 @@
+#  Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+#   embedded brains GmbH
+#   Dornierstrasse 4
+#   82178 Puchheim
+#   Germany
+#   <rtems at embedded-brains.de>
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name:  spfatal27
+directives:
+  rtems_libio_init
+concepts:
++ Force the fatal error when no POSIX key is left.
diff --git a/testsuites/sptests/spfatal27/spfatal27.scn b/testsuites/sptests/spfatal27/spfatal27.scn
index 0000000..41f6ae5
--- /dev/null
+++ b/testsuites/sptests/spfatal27/spfatal27.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST FATAL 27 ***
+Fatal error (libio init no posix key left) hit
+*** END OF TEST FATAL 27 ***
diff --git a/testsuites/sptests/spfatal27/testcase.h b/testsuites/sptests/spfatal27/testcase.h
index 0000000..4dc4f9d
--- /dev/null
+++ b/testsuites/sptests/spfatal27/testcase.h
@@ -0,0 +1,27 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstrasse 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#define FATAL_ERROR_TEST_NAME            "FATAL 27"
+#define FATAL_ERROR_DESCRIPTION          "libio init no posix key left"
+#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_RTEMS_API
+#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
+#define FATAL_ERROR_EXPECTED_ERROR       RTEMS_UNSATISFIED
+#define CONFIGURE_MAXIMUM_POSIX_KEYS (-1)
+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS (0)
+void force_error()
+  /* we should not reach this */
diff --git a/testsuites/sptests/spprivenv01/init.c b/testsuites/sptests/spprivenv01/init.c
index a670085..4f0660d 100644
--- a/testsuites/sptests/spprivenv01/init.c
+++ b/testsuites/sptests/spprivenv01/init.c
@@ -63,14 +63,19 @@ rtems_task Init(
   puts( "Init - allocating most of workspace memory" );
   opaque = rtems_workspace_greedy_allocate( NULL, 0 );
-  puts( "Init - attempt to reset env - expect RTEMS_TOO_MANY" );
+  puts( "Init - attempt to reset env - expect RTEMS_SUCCESSFUL" );
   sc = rtems_libio_set_private_env();
-  rtems_test_assert( sc == RTEMS_TOO_MANY );
+  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+  rtems_test_assert( rtems_current_user_env != &rtems_global_user_env );
   puts( "Init - freeing the workspace memory" );
   rtems_workspace_greedy_free( opaque );
+  puts( "Init - Reset to global environment" );
+  rtems_libio_use_global_env();
+  rtems_test_assert( rtems_current_user_env == &rtems_global_user_env );
   puts( "Init - Attempt to get a private environment" );
@@ -118,6 +123,9 @@ rtems_task Init(
+#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
1.8.4.5
