[PATCH 1/3] score: Delete CORE_mutex_Control::blocked_count
Sebastian Huber
Thu Mar 27 13:49:41 UTC 2014
cpukit/score/include/rtems/score/coremutex.h | 2 --
cpukit/score/src/coremutex.c | 1 -
cpukit/score/src/coremutexseize.c | 1 -
3 files changed, 0 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/include/rtems/score/coremutex.h b/cpukit/score/include/rtems/score/coremutex.h
index 04d2087..be11cb6 100644
--- a/cpukit/score/include/rtems/score/coremutex.h
+++ b/cpukit/score/include/rtems/score/coremutex.h
@@ -162,8 +162,6 @@ typedef struct {
* nested. This must be zero (0) before the mutex is actually unlocked.
uint32_t nest_count;
- /** This is the number of waiting threads. */
- uint32_t blocked_count;
/** This element points to the thread which is currently holding this mutex.
* The holder is the last thread to successfully lock the mutex and which
* has not unlocked it. If the thread is not locked, there is no holder.
diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
index 3b03fef..4cdc764 100644
--- a/cpukit/score/src/coremutex.c
+++ b/cpukit/score/src/coremutex.c
@@ -38,7 +38,6 @@ CORE_mutex_Status _CORE_mutex_Initialize(
the_mutex->Attributes = *the_mutex_attributes;
the_mutex->lock = initial_lock;
- the_mutex->blocked_count = 0;
if ( initial_lock == CORE_MUTEX_LOCKED ) {
the_mutex->nest_count = 1;
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index 5997293..cde4cc4 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -64,7 +64,6 @@ void _CORE_mutex_Seize_interrupt_blocking(
- the_mutex->blocked_count++;
_Thread_queue_Enqueue( &the_mutex->Wait_queue, executing, timeout );
_Thread_Enable_dispatch();
1.7.7
