[PATCH 4/4] score: PR2152: Use allocator mutex for objects
Thu Mar 27 16:20:54 UTC 2014
Sebastian,
On Thu, Mar 27, 2014 at 12:14 PM, Sebastian Huber
> On 2014-03-27 16:56, Gedare Bloom wrote:
>> Should/Will there be a heap allocator lock added similar to the
>> objects allocator lock?
> Sorry, I don't understand the question.  Isn't the heap allocator lock the
> _RTEMS_Lock_allocator()/_RTEMS_Unlock_allocator()?
Don't worry about it for now, it is not relevant to your current patch
set. Here is some clarification though:
The name does not tell me that it is used to lock the heap, but rather
implies it is a global lock used for all allocation with RTEMS. My
point is that the places where it is specifically the Heap being
protected should be made clear.
Thanks,
Gedare
