SuperCore Scheduler (GSOC 2014)
Sebastian Huber
Mon Mar 3 07:21:23 UTC 2014
On 2014-03-01 01:13, Andre Marques wrote:
> Hello,
> As stated in [1] I will be working with RTEMS for my undergraduate thesis, but
> I'm also looking to work with RTEMS through GSOC.
> For the last month I have been working on a test case to check rename() POSIX
> compliance. For GSOC, however, I would like to work on a SMP-aware scheduler,
> if possible.
Sorry, I still didn't have the time to review it.
> What I understood from the SuperCore Scheduler project page is that there is
> still some work to be done on global edf started last year by Sree harsha
> konduri. Is it enough or relevant for another GSOC project?
> If not, would it be interesting to implement a new scheduler, for instance
> pfair or llref?
The SMP support is work in progress, so it is hard to predict how things will
turn out in the next couple of months. Gedare did a great job with the
scheduler operations API so that the scheduler is now an application
configuration option. One goal is to leverage it to support
clustered/partitioned scheduling. I think RTEMS will be a good platform to
study real-time SMP systems in the future. Currently a lot of research is done
on Linux. RTEMS however is much simpler to understand (e.g. no virtual memory,
much smaller code base) and may be a good experimental platform.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
