RFC Eliminate Use of Task Variables in cpukit
    Sebastian Huber
    Fri Mar  7 06:08:54 UTC 2014
On 2014-03-06 20:27, Joel Sherrill wrote:
> + cpukit/libcsupport/src/privateenv.c
>    - Uses rtems_global_user_env. Switch to POSIX Keys?
We can use POSIX keys, or do some optimization:
Since applications using a file system will very likely also enable the Newlib
re-entrancy we can re-use the __getreent() function for the file system
environment.  In newlib_create_hook() we create a structure
struct S {
   struct _reent reent;
   rtems_user_env_t *env;
and assign it to thread->libc_reent;
The file system can then use
(struct S *) __getreent()
to get its file system environment.  This approach allows a slightly faster
lock-up compared to POSIX keys and uses less memory.
+ cpukit/score/include/rtems/score/threadimpl.h
  *  Self for the GNU Ada Run-Time
SCORE_EXTERN void *rtems_ada_self;
This should be replaced with a function:
   void *rtems_ada_self(void)
     return _Thread_Get_executing()->rtems_ada_self;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
