psxtests/psxkey08 failure
Mon Mar 10 17:29:06 UTC 2014
On 3/10/2014 10:00 AM, Sebastian Huber wrote:
> On 2014-03-10 15:54, Joel Sherrill wrote:
>> On Mar 10, 2014 9:32 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
>> wrote:
>>  > On 2014-03-10 15:23, Joel Sherrill wrote:
>>  > > On Mar 10, 2014 8:14 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
>>  > > wrote:
>>  > >  > On 2014-03-10 14:04, Joel Sherrill wrote:
>>  > >  > > On Mar 10, 2014 7:57 AM, Sebastian Huber
>>  > >  > > wrote:
>>  > >  > >  > Hello,
>>  > >  > >  > this test fails now on SIS with debugging enabled:
>>  > >  > >  > *** TEST KEY 08 ***
>>  > >  > >  > Init - Semaphore 1 create - OK
>>  > >  > >  > Init - Semaphore 2 create - OK
>>  > >  > >  > Init - pthread Key create - OK
>>  > > ../../../../../../../rtems/c/src/../../testsuites/psxtests/psxkey08/init.c: 93
>>  > >  > >  > task_id_p
>>  > >  > > Grrr.. I will try to look at it today. Any obvious code conversion
>> mistake?
>>  > >  > I fixed some obvious thread affinity bugs, but this one exceeded my
>> time limit
>>  > >  > for today.
>>  > > What configuration is this failing in? I tried with --enable-rtems-debug and
>>  > > POSIX enabled and disabled.  Both builds ran fine.
>>  > > My tree doesn't have any patches newer than the one where I enabled keys
>> in all
>>  > > configurations.
>>  > That is with --enable-rtems-debug --enable-smp?
>> Hmmm.. Maybe something broke since my last update. It still works for me. I am
>> at the doctor's office and testing while waiting. I couldn't update git.
>> I will try again when my tree is up to date but I am not seeing it.
> Ok, thanks for testing, I will have a look at it tomorrow.
I updated to the head and configured like this:
 ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
--prefix=/home/joel/rtems-4.11-work/bsp-install --disable-networking
--disable-posix --enable-smp --enable-rtems-debug --enable-tests
--enable-maintainer-mode
And none of the psxkey tests failed.
