psxtests/psxkey08 failure
Sebastian Huber
Tue Mar 11 11:03:08 UTC 2014
On 2014-03-10 18:29, Joel Sherrill wrote:
> On 3/10/2014 10:00 AM, Sebastian Huber wrote:
>> On 2014-03-10 15:54, Joel Sherrill wrote:
>>> On Mar 10, 2014 9:32 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
>>> wrote:
>>> > On 2014-03-10 15:23, Joel Sherrill wrote:
>>> > > On Mar 10, 2014 8:14 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
>>> > > wrote:
>>> > > > On 2014-03-10 14:04, Joel Sherrill wrote:
>>> > > > > On Mar 10, 2014 7:57 AM, Sebastian Huber
>>> > > > > wrote:
>>> > > > > > Hello,
>>> > > > > > this test fails now on SIS with debugging enabled:
>>> > > > > > *** TEST KEY 08 ***
>>> > > > > > Init - Semaphore 1 create - OK
>>> > > > > > Init - Semaphore 2 create - OK
>>> > > > > > Init - pthread Key create - OK
>>> > > ../../../../../../../rtems/c/src/../../testsuites/psxtests/psxkey08/init.c: 93
>>> > > > > > task_id_p
>>> > > > > Grrr.. I will try to look at it today. Any obvious code conversion
>>> mistake?
>>> > > > I fixed some obvious thread affinity bugs, but this one exceeded my
>>> time limit
>>> > > > for today.
>>> > > What configuration is this failing in? I tried with --enable-rtems-debug and
>>> > > POSIX enabled and disabled. Both builds ran fine.
>>> > > My tree doesn't have any patches newer than the one where I enabled keys
>>> in all
>>> > > configurations.
>>> > That is with --enable-rtems-debug --enable-smp?
>>> Hmmm.. Maybe something broke since my last update. It still works for me. I am
>>> at the doctor's office and testing while waiting. I couldn't update git.
>>> I will try again when my tree is up to date but I am not seeing it.
>> Ok, thanks for testing, I will have a look at it tomorrow.
> I updated to the head and configured like this:
> ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> --prefix=/home/joel/rtems-4.11-work/bsp-install --disable-networking
> --disable-posix --enable-smp --enable-rtems-debug --enable-tests
> --enable-maintainer-mode
> And none of the psxkey tests failed.
I run this test today after a restart of my development machine and now this
test passes. Sorry for the noise.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
