[GSoC 2014] Paravirtualization layer in RTEMS
Gedare Bloom
gedare at rtems.org
Tue Mar 11 00:28:58 UTC 2014
On Mon, Mar 10, 2014 at 6:48 PM, Philipp Eppelt
<philipp.eppelt at mailbox.tu-dresden.de> wrote:
> On 03/10/2014 04:24 PM, Youren Shen wrote:
>> What make me confused is the relation
>> between pok_arch_event_register and pok_meta_handler_init. It seems you
>> divided the irq vector to two parts in pok_arch_event_register, Less 32
>> or more than 32. It looks like you have already design some hypercall
>> interface. (just like pok_irq_prologue_0 for clock?) But what's
>> the meaning of pok_meta_handler_init? I still can't understand it very
>> clearly.Could you give me some outline about IRQ handlind in POK which
>> invoke this two functions?
>> If you can provide me a brief overview about the way how you consider
>> this Issues and a brief description about your design, it will be
>> really helpful to me.
> There are 16 (0 - 15) interrupt lines for hardware interrupts on x86.
> If a line is triggered, the PIC will send an interrupt to the CPU.
> If interrupts are enabled the CPU will ask for the interrupt number and
> looks up this number in the Interrupt Descriptor Table (IDT).
> The IDT for HW interrupts looks like this:
> 32 | clock ISR (Interrupt Service Routine)
> 33 | keyboard ISR
> 34 | ...
> 47 | ...
> INTEL reserved the first 32 (0-31) IRQ lines, so we start at 32 and go
> to 47. 32 corresponds to IRQ line 0, which is the clock interrupt. 33,
> is 1 is the keyboard (if I can trust my memory).
> Now the CPU never tells you which IRQ line fires. Therefore, we register
> the prologue functions with the IDT, which knows its line number, pushes
> it on the stack and calls a general ISR handler.
> This general ISR handler checks the line number and calls the handler
> registered for this line. Therefore the general ISR handler maintains
> its own IDT, a software IDT.
> This enables us to register more than one ISR handler function for one
> interrupt line. For example, to handle the clock tick in the kernel and
> tell the guest system(RTEMS) running in a partition, that a clock tick
> occurred (two handlers).
> But, we don't want the POK kernel to wait until the partition handled
> the interrupt. So we acknowledge the interrupt with the PIC and then
> send the partition the soft-interrupt. And here we go from kernel to
> user space and this is the point, where I left of.
> To be more specific in terms of source code.
> 'pok_arch_event_register' is called, if you want to register any kind of
> interrupt with the IDT. If this happens to be in the hardware interrupt
> range [32-47], it registers a prologue handler with the IDT.
> all pok_irq_prologue functions call _ISR_Handler, which in turn calls
> _C_isr_handler. This is the general handler, first the asm part and
> second the C part.
> The _C_isr_handler checks if the kernel has registered a handler for
> this IRQ number and calls it.
> Then it checks if the current partition has interrupts enabled, if yes,
> if there is a handler registered and if the partition isn't already
> servicing an earlier interrupt.
> If so, the registered handler is invoked.
> If I am talking about 'registered handler' I am talking about the
> software IDT the kernel is maintaining.
> The software IDT for hardware interrupts is a static table consisting of
> 16 entries of the type 'meta_handler'.
> 'meta_handler' is a struct consisting of a vector number, and two tables
> of the size "kernel + configured number of partitions".
> The first table is for function pointers pointing to the
> partition's/kernel's hander function, the
> what-to-do-if-IRQ-occurrs-function.
> The second table flags if the partition is ready for an interrupt.
> So for each interrupt entry in our software-IDT, we get a 'meta_handler'
> encapsulating a line number, atables with up to one handler per
> partition and a table if the partition is ready for interrupts.
> Next to this software IDT, there is a table 'partition_irq_enabled',
> which has one flag per partition and is the software replacement for
> CLI/STI.
> 'pok_meta_handler_init' sets up the software-IDT and fills all fields
> with start values (magic unused vector number, no handler present, but
> waiting)
> 'pok_partition_irq_init' sets up partition_irq_enabled table with the
> value for disabled (0), so initially no partition gets interrupts until
> it asks for them.
> How can partitions talk to the software-IDT?
> POK consists of kernel and partitions. Each partition has a libpok part.
> Libpok is the library that enables the partition to talk to other
> partitions and the kernel.
> An RTEMS guest has a POK partition part (libpart) and the RTEMS part.
> Libpart implements the communication with the POK kernel. So when RTEMS
> calls some virtualization layer function, the implementation present in
> libpart will emit a syscall to the pok kernel and pass along the IRQ
> callback function or it just tells to unregister, to
> enable/disable/acknowledge interrupts.
> Have a look at the virtualization layer functiosn in RTEMS's virtualpok
> BSP and examples/rtems-guest/ in POK.
> The syscall handling then forwards the request to the e.g.
> 'pok_bsp_irq_register_hw'.
> I hope that fits into your definition of 'briefly explain'. But it
> should give you enough background and explanation to follow the code and
> understand the design.
> The really nasty bit happens in the '_C_isr_handler' function in
> x86-qemu/bsp.c.
> This is explained in my RTLWS'13 paper.
Link to paper please.
> In short: Each IRQ entry builds a stack frame, which saves the registers
> values on the stack, when the interrupt occurs, so we can continue
> execution at the same point.
> To handle the IRQ in user space and to return to the point of
> interruption, the user space handler needs this data. So the interrupt
> frame is copied from the kernel stack to the user stack. Then 'iret'
> makes the kernel-space to user-space transition. And that's where we get
> a GeneralProtectionFault.
Can we just not use iret from the paravirtualized guest (RTEMS)? This
problem reminds me of https://lkml.org/lkml/2011/12/16/460
> Have also a look at the interrupt_middleman function in
> rtems-guest/hello.c. This is the user space recovery code of the stack
> frame.
> Cheers,
> Philipp
> p.s.
> This page has a couple of good tutorials for low level OS programming:
> http://www.brokenthorn.com/Resources/OSDev15.html
> rtems-devel mailing list
> rtems-devel at rtems.org
