[GSoC 2014] Paravirtualization layer in RTEMS
Philipp Eppelt
philipp.eppelt at mailbox.tu-dresden.de
Tue Mar 11 07:46:58 UTC 2014
On 03/11/2014 01:28 AM, Gedare Bloom wrote:
> On Mon, Mar 10, 2014 at 6:48 PM, Philipp Eppelt
> <philipp.eppelt at mailbox.tu-dresden.de> wrote:
>> On 03/10/2014 04:24 PM, Youren Shen wrote:
>>> What make me confused is the relation
>>> between pok_arch_event_register and pok_meta_handler_init. It seems you
>>> divided the irq vector to two parts in pok_arch_event_register, Less 32
>>> or more than 32. It looks like you have already design some hypercall
>>> interface. (just like pok_irq_prologue_0 for clock?) But what's
>>> the meaning of pok_meta_handler_init? I still can't understand it very
>>> clearly.Could you give me some outline about IRQ handlind in POK which
>>> invoke this two functions?
>>> If you can provide me a brief overview about the way how you consider
>>> this Issues and a brief description about your design, it will be
>>> really helpful to me.
>> There are 16 (0 - 15) interrupt lines for hardware interrupts on x86.
>> If a line is triggered, the PIC will send an interrupt to the CPU.
>> If interrupts are enabled the CPU will ask for the interrupt number and
>> looks up this number in the Interrupt Descriptor Table (IDT).
>> The IDT for HW interrupts looks like this:
>> 32 | clock ISR (Interrupt Service Routine)
>> 33 | keyboard ISR
>> 34 | ...
>> 47 | ...
>> INTEL reserved the first 32 (0-31) IRQ lines, so we start at 32 and go
>> to 47. 32 corresponds to IRQ line 0, which is the clock interrupt. 33,
>> is 1 is the keyboard (if I can trust my memory).
>> Now the CPU never tells you which IRQ line fires. Therefore, we register
>> the prologue functions with the IDT, which knows its line number, pushes
>> it on the stack and calls a general ISR handler.
>> This general ISR handler checks the line number and calls the handler
>> registered for this line. Therefore the general ISR handler maintains
>> its own IDT, a software IDT.
>> This enables us to register more than one ISR handler function for one
>> interrupt line. For example, to handle the clock tick in the kernel and
>> tell the guest system(RTEMS) running in a partition, that a clock tick
>> occurred (two handlers).
>> But, we don't want the POK kernel to wait until the partition handled
>> the interrupt. So we acknowledge the interrupt with the PIC and then
>> send the partition the soft-interrupt. And here we go from kernel to
>> user space and this is the point, where I left of.
>> To be more specific in terms of source code.
>> 'pok_arch_event_register' is called, if you want to register any kind of
>> interrupt with the IDT. If this happens to be in the hardware interrupt
>> range [32-47], it registers a prologue handler with the IDT.
>> all pok_irq_prologue functions call _ISR_Handler, which in turn calls
>> _C_isr_handler. This is the general handler, first the asm part and
>> second the C part.
>> The _C_isr_handler checks if the kernel has registered a handler for
>> this IRQ number and calls it.
>> Then it checks if the current partition has interrupts enabled, if yes,
>> if there is a handler registered and if the partition isn't already
>> servicing an earlier interrupt.
>> If so, the registered handler is invoked.
>> If I am talking about 'registered handler' I am talking about the
>> software IDT the kernel is maintaining.
>> The software IDT for hardware interrupts is a static table consisting of
>> 16 entries of the type 'meta_handler'.
>> 'meta_handler' is a struct consisting of a vector number, and two tables
>> of the size "kernel + configured number of partitions".
>> The first table is for function pointers pointing to the
>> partition's/kernel's hander function, the
>> what-to-do-if-IRQ-occurrs-function.
>> The second table flags if the partition is ready for an interrupt.
>> So for each interrupt entry in our software-IDT, we get a 'meta_handler'
>> encapsulating a line number, atables with up to one handler per
>> partition and a table if the partition is ready for interrupts.
>> Next to this software IDT, there is a table 'partition_irq_enabled',
>> which has one flag per partition and is the software replacement for
>> CLI/STI.
>> 'pok_meta_handler_init' sets up the software-IDT and fills all fields
>> with start values (magic unused vector number, no handler present, but
>> waiting)
>> 'pok_partition_irq_init' sets up partition_irq_enabled table with the
>> value for disabled (0), so initially no partition gets interrupts until
>> it asks for them.
>> How can partitions talk to the software-IDT?
>> POK consists of kernel and partitions. Each partition has a libpok part.
>> Libpok is the library that enables the partition to talk to other
>> partitions and the kernel.
>> An RTEMS guest has a POK partition part (libpart) and the RTEMS part.
>> Libpart implements the communication with the POK kernel. So when RTEMS
>> calls some virtualization layer function, the implementation present in
>> libpart will emit a syscall to the pok kernel and pass along the IRQ
>> callback function or it just tells to unregister, to
>> enable/disable/acknowledge interrupts.
>> Have a look at the virtualization layer functiosn in RTEMS's virtualpok
>> BSP and examples/rtems-guest/ in POK.
>> The syscall handling then forwards the request to the e.g.
>> 'pok_bsp_irq_register_hw'.
>> I hope that fits into your definition of 'briefly explain'. But it
>> should give you enough background and explanation to follow the code and
>> understand the design.
>> The really nasty bit happens in the '_C_isr_handler' function in
>> x86-qemu/bsp.c.
>> This is explained in my RTLWS'13 paper.
> Link to paper please.
https://wwwpub.zih.tu-dresden.de/~s8940405/rtlws13_rtems_in_pok_partitions.pdf
>> In short: Each IRQ entry builds a stack frame, which saves the registers
>> values on the stack, when the interrupt occurs, so we can continue
>> execution at the same point.
>> To handle the IRQ in user space and to return to the point of
>> interruption, the user space handler needs this data. So the interrupt
>> frame is copied from the kernel stack to the user stack. Then 'iret'
>> makes the kernel-space to user-space transition. And that's where we get
>> a GeneralProtectionFault.
> Can we just not use iret from the paravirtualized guest (RTEMS)?
With kernel-space and kernel stack, I mean the POK kernel-space and
stack. Sorry, I should have made that clear.
This
> problem reminds me of https://lkml.org/lkml/2011/12/16/460
Interesting, I'll have a look.
>> Have also a look at the interrupt_middleman function in
>> rtems-guest/hello.c. This is the user space recovery code of the stack
>> frame.
>> Cheers,
>> Philipp
>> p.s.
>> This page has a couple of good tutorials for low level OS programming:
>> http://www.brokenthorn.com/Resources/OSDev15.html
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
