[PATCH 1/2] sapi: Add <rtems/test.h>
    Sebastian Huber
    Tue Mar 11 07:33:47 UTC 2014
On 2014-03-10 20:10, Sebastian Huber wrote:
> On 03/10/2014 06:55 PM, Joel Sherrill wrote:
>> testsuites/support
> Ok, I would like to avoid the massive copy and paste in the Makefiles.
I would like to move away from the existing test support.  The problem is that
you have to add at least this in every test Makefile.am:
test_SOURCES += ../../support/src/test_support.c
AM_CPPFLAGS += -I$(top_srcdir)/../support/include
I consider ../ paths in Makefiles as hacks.
You have to compile test_support.c again for each tests which increases the
build times.
You have also hacks like this in a header file (buffer_test_io.h):
   #if defined(TEST_INIT) || defined(CONFIGURE_INIT)
     char _test_output_buffer[_TEST_OUTPUT_BUFFER_SIZE];
     int _test_output_buffer_index = 0;
     void _test_output_append(char *_buffer)
       char *p;
       for ( p=_buffer ; *p ; p++ ) {
         _test_output_buffer[_test_output_buffer_index++] = *p;
         _test_output_buffer[_test_output_buffer_index]   = '\0';
         #if 0
	  if ( *p == '\n' ) {
	    fprintf( stderr, "BUFFER -- %s", _test_output_buffer );
	   _test_output_buffer[0]   = '\0';
         #endif
	if ( _test_output_buffer_index >= (_TEST_OUTPUT_BUFFER_SIZE - 80) )
	  _test_output_flush();
     #include <termios.h>
     #include <unistd.h>
     void _test_output_flush(void)
       fprintf( stderr, "%s", _test_output_buffer );
       tcdrain( 2 );
     #endif
What is the disadvantage of moving this into a general purpose library?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
