[PATCH 1/2] sapi: Add <rtems/test.h>
Gedare Bloom
gedare at rtems.org
Tue Mar 11 12:48:29 UTC 2014
Sebastian,
On Tue, Mar 11, 2014 at 3:33 AM, Sebastian Huber
> On 2014-03-10 20:10, Sebastian Huber wrote:
>> On 03/10/2014 06:55 PM, Joel Sherrill wrote:
>>> testsuites/support
>> Ok, I would like to avoid the massive copy and paste in the Makefiles.
> I would like to move away from the existing test support. The problem is
> that you have to add at least this in every test Makefile.am:
> test_SOURCES += ../../support/src/test_support.c
> AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> I consider ../ paths in Makefiles as hacks.
> You have to compile test_support.c again for each tests which increases the
> build times.
> You have also hacks like this in a header file (buffer_test_io.h):
> #if defined(TEST_INIT) || defined(CONFIGURE_INIT)
> char _test_output_buffer[_TEST_OUTPUT_BUFFER_SIZE];
> int _test_output_buffer_index = 0;
> void _test_output_append(char *_buffer)
> char *p;
> for ( p=_buffer ; *p ; p++ ) {
> _test_output_buffer[_test_output_buffer_index++] = *p;
> _test_output_buffer[_test_output_buffer_index] = '\0';
> #if 0
> if ( *p == '\n' ) {
> fprintf( stderr, "BUFFER -- %s", _test_output_buffer );
> _test_output_buffer[0] = '\0';
> #endif
> if ( _test_output_buffer_index >= (_TEST_OUTPUT_BUFFER_SIZE - 80) )
> _test_output_flush();
> #include <termios.h>
> #include <unistd.h>
> void _test_output_flush(void)
> fprintf( stderr, "%s", _test_output_buffer );
> tcdrain( 2 );
> #endif
> What is the disadvantage of moving this into a general purpose library?
I'm on board with an RTEMS testing support library within the cpukit.
Please make a separate discussion describing how it would
work--obviously, this test.h shows most of it, but reading the code
will be less efficient than you describing the design to us. Then we
can make the enlightened decision.
Thanks,
Gedare
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-devel mailing list
> rtems-devel at rtems.org
