Fwd: Conflict when modifying newlib/openrisc to work for RTEMS
Hesham Moustafa heshamelmatary at gmail.com
Wed Mar 19 01:34:36 UTC 2014
On Tue, Mar 18, 2014 at 8:26 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> On 3/18/2014 1:07 PM, Hesham Moustafa wrote:
> Hi,
>  I am working on modifying or1k newlib port to be built for RTEMS.
> Building and installing
> newlib with --target=or1k-elf is done successfully, however, when I try to
> build newlib
> with --target=or1k-rtems4.11 I got conflict error.
>  part of this error is
> "sys/rtems/crt0.c:72:22: error: conflicting types for 'read'"
>   Hmmm... how old is there newlib?
> I think their toolchain depends on newlib-2.0.0, but I have generated
patches
 to work with newlib-2.1.0.
>  What's the prototype for read() versus unistd.h (or whereever it turns
> out to
> be prototyped)?
> in newlib/libc/include/sys/unistd.h
_READ_WRITE_RETURN_TYPE _EXFUN(read, (int __fd, void *__buf, size_t __nbyte
_READ_WRITE_RETURN_TYPE _EXFUN(write, (int __fd, const void *__buf, size_t
__nbyte ));
and write function which conflicts too.
>  It may also be possible that the or1k port doesn't have the underlying
> type
> definitions complete or correct.
> http://pubs.opengroup.org/onlinepubs/009695399/functions/read.html
> isn't the latest but read() requires ssize_t and size_t to be correctly and
> consistently defined for a target.
> You may end up having to reproduce the compile of crt0.c by hand and
> change the -c to a -E .. changing the output file.. and see what really
> is being preprocessed
> I did that exactly and I found out that both read and write are prototyped
as
int read (int __fd, void *__buf, size_t __nbyte );
int write (int __fd, const void *__buf, size_t __nbyte );
Also there is another syntax error at crt0.c
"../../../../../../../newlib-2.1.0-or1k/newlib/libc/sys/rtems/crt0.c:74:37:
error: expected ')' before '*' token
 RTEMS_STUB(int, sigfillset(sigset_t *set), { return -1; })"
When I checked the output of -E I found out the following prototype :
int rtems_stub_sigfillset(sigset_t *set) { return -1; }; int (*(sigset_t
*set) = ~(0), 0) { return -1; }
and
typedef unsigned long sigset_t;
is out there.
(I did not apply newlib-sys-signal-20130532.diff patch, yet, at the RSB
which
 do nothing with this error)
>  or1k/newlib port implements some stuff at libgloss (including
> or1k/crt0.S)
>   rtems uses nothing in libgloss.
>  I just use --target=or1k-xxx --prefix=xxx as configuration options for
> newlib.
>   The RTEMS builds take more. Check rtems-source-builder. Also if you are
> not building or1k-rtems tools including binutils and gcc+newlib together
> at the same time, it may be causing issues.
For RSB, I can only see that newlib is linked into gcc directory and then
gcc is built with
--with-newlib option (what am I missing ?)
binutils (or1k-rtems4.11-*) is installed
and exported at prefix location. The process which I make is
1- Build and install patched binutils-2.24 for RTEMS [successful]
2- Build and install bootstrap patched gcc-4.8.2 [successful]
3- Build and install patched newlib-2.1.0 [stuck here]
4- Build and install patched gcc-4.8.2 with newlib
Again, this process works fine with --target=or1k-elf and I am able to
compile simple
hello world program, it only conflicts at the previous 3rd point when
targeting
or1k-rtems4.11.
>  Thanks,
> Hesham
> Joel Sherrill, Ph.D.             Director of Research & Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140319/212f5511/attachment-0001.html>
