[PATCH 2/2] samples/fileio: Adaption for shell with posix keys.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Mar 19 15:15:05 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
Add necessary objects.
Add login function and custom device name for better testing of the shell.
 testsuites/samples/fileio/init.c   | 5 +++--
 testsuites/samples/fileio/system.h | 3 +++
 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
index 80da4ab..2a0f9db 100644
--- a/testsuites/samples/fileio/init.c
+++ b/testsuites/samples/fileio/init.c
@@ -708,10 +708,11 @@ static void fileio_start_shell(void)
     "SHLL",                          /* task_name */
     RTEMS_MINIMUM_STACK_SIZE * 4,    /* task_stacksize */
     100,                             /* task_priority */
-    "/dev/console",                  /* devname */
+    "/dev/foobar",                   /* devname */
+    /* device is currently ignored by the shell if it is not a pty */
     false,                           /* forever */
     true,                            /* wait */
-    NULL                             /* login */
+    rtems_shell_login_check          /* login */
 #endif /* USE_SHELL */
diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
index 726a507..654f727 100644
--- a/testsuites/samples/fileio/system.h
+++ b/testsuites/samples/fileio/system.h
@@ -47,6 +47,9 @@ rtems_task Init(
 #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY  14
 #endif
+#define CONFIGURE_MAXIMUM_POSIX_KEYS             1
+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS  1
 #if FILEIO_BUILD
   #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
   #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS  2
1.8.4.5
