[PATCH 2/2] samples/fileio: Adaption for shell with posix keys.
Wed Mar 19 15:33:25 UTC 2014
On Wed, Mar 19, 2014 at 11:15 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
> Add necessary objects.
> Add login function and custom device name for better testing of the shell.
>  testsuites/samples/fileio/init.c   | 5 +++--
>  testsuites/samples/fileio/system.h | 3 +++
>  2 files changed, 6 insertions(+), 2 deletions(-)
> diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
> index 80da4ab..2a0f9db 100644
> --- a/testsuites/samples/fileio/init.c
> +++ b/testsuites/samples/fileio/init.c
> @@ -708,10 +708,11 @@ static void fileio_start_shell(void)
>      "SHLL",                          /* task_name */
>      RTEMS_MINIMUM_STACK_SIZE * 4,    /* task_stacksize */
>      100,                             /* task_priority */
> -    "/dev/console",                  /* devname */
> +    "/dev/foobar",                   /* devname */
> +    /* device is currently ignored by the shell if it is not a pty */
>      false,                           /* forever */
>      true,                            /* wait */
> -    NULL                             /* login */
> +    rtems_shell_login_check          /* login */
>  #endif /* USE_SHELL */
> diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
> index 726a507..654f727 100644
> --- a/testsuites/samples/fileio/system.h
> +++ b/testsuites/samples/fileio/system.h
> @@ -47,6 +47,9 @@ rtems_task Init(
>  #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY  14
>  #endif
> +#define CONFIGURE_MAXIMUM_POSIX_KEYS             1
> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS  1
Should this CONFIGURE_KEYS be dealt with at confdefs.h?
>  #if FILEIO_BUILD
>    #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>    #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS  2
> 1.8.4.5
> rtems-devel mailing list
> rtems-devel at rtems.org
