[PATCH 2/2] samples/fileio: Adaption for shell with posix keys.
Gedare Bloom
gedare at rtems.org
Wed Mar 19 15:59:23 UTC 2014
On Wed, Mar 19, 2014 at 11:49 AM, Sebastian Huber
> On 2014-03-19 16:33, Gedare Bloom wrote:
>> On Wed, Mar 19, 2014 at 11:15 AM, Christian Mauderer
>> <christian.mauderer at embedded-brains.de> wrote:
>>> >From: Christian Mauderer<Christian.Mauderer at embedded-brains.de>
>>> >Add necessary objects.
>>> >Add login function and custom device name for better testing of the
>>> > shell.
>>> > testsuites/samples/fileio/init.c | 5 +++--
>>> > testsuites/samples/fileio/system.h | 3 +++
>>> > 2 files changed, 6 insertions(+), 2 deletions(-)
>>> >diff --git a/testsuites/samples/fileio/init.c
>>> > b/testsuites/samples/fileio/init.c
>>> >index 80da4ab..2a0f9db 100644
>>> >--- a/testsuites/samples/fileio/init.c
>>> >+++ b/testsuites/samples/fileio/init.c
>>> >@@ -708,10 +708,11 @@ static void fileio_start_shell(void)
>>> > "SHLL", /* task_name */
>>> > RTEMS_MINIMUM_STACK_SIZE * 4, /* task_stacksize */
>>> > 100, /* task_priority */
>>> >- "/dev/console", /* devname */
>>> >+ "/dev/foobar", /* devname */
>>> >+ /* device is currently ignored by the shell if it is not a pty */
>>> > false, /* forever */
>>> > true, /* wait */
>>> >- NULL /* login */
>>> >+ rtems_shell_login_check /* login */
>>> > #endif /* USE_SHELL */
>>> >diff --git a/testsuites/samples/fileio/system.h
>>> > b/testsuites/samples/fileio/system.h
>>> >index 726a507..654f727 100644
>>> >--- a/testsuites/samples/fileio/system.h
>>> >+++ b/testsuites/samples/fileio/system.h
>>> >@@ -47,6 +47,9 @@ rtems_task Init(
>>> > #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY 14
>>> > #endif
>>> >+#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
>>> >+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 1
>> Should this CONFIGURE_KEYS be dealt with at confdefs.h?
> This is the basic problem with the RTEMS configuration. You have this
> problem with device drivers, C++, library functions etc.
> If you don't know how many objects you need, then use unlimited objects and
> a unified work space.
Then the requirement for a posix key when using the shell must be
captured in the documentation somewhere.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-devel mailing list
> rtems-devel at rtems.org
