[PATCH 07/10] posix: Move affinity from thread to scheduler.
Jennifer jennifer.averett at oarcorp.com
Mon Mar 24 18:39:38 UTC 2014
From: Jennifer Averett <jennifer.averett at oarcorp.com>
 cpukit/posix/src/pthreadcreate.c        | 14 ++++++++++++--
 cpukit/posix/src/pthreadgetaffinitynp.c | 12 +++++-------
 cpukit/posix/src/pthreadsetaffinitynp.c |  8 ++++++--
 3 files changed, 23 insertions(+), 11 deletions(-)
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 5a6d929..075a092 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -32,6 +32,8 @@
 #include <rtems/score/apimutex.h>
 #include <rtems/score/stackimpl.h>
+#include <rtems/score/schedulerimpl.h>
 static inline size_t _POSIX_Threads_Ensure_minimum_stack (
   size_t size
@@ -196,8 +198,16 @@ int pthread_create(
 #if defined(RTEMS_SMP)
 #if __RTEMS_HAVE_SYS_CPUSET_H__
-   the_thread->affinity.setsize   = the_attr->affinitysetsize;
-   *the_thread->affinity.set      = *the_attr->affinityset;
+   rc = _Scheduler_Set_affinity(
+     the_thread,
+     attr->affinitysetsize,
+     attr->affinityset
+  if ( rc != 0 ) {
+    _POSIX_Threads_Free( the_thread );
+    _RTEMS_Unlock_allocator();
+    return EINVAL;
 #endif
 #endif
diff --git a/cpukit/posix/src/pthreadgetaffinitynp.c b/cpukit/posix/src/pthreadgetaffinitynp.c
index 082e41a..fd61af5 100644
--- a/cpukit/posix/src/pthreadgetaffinitynp.c
+++ b/cpukit/posix/src/pthreadgetaffinitynp.c
@@ -28,6 +28,7 @@
 int pthread_getaffinity_np(
   const pthread_t       id,
@@ -46,14 +47,11 @@ int pthread_getaffinity_np(
   switch ( location ) {
     case OBJECTS_LOCAL:
-      error = 0;
-      if ( cpusetsize != the_thread->affinity.setsize )
-        error = EINVAL;
-      else
-        CPU_COPY( cpuset, the_thread->affinity.set );
+      error = _Scheduler_Get_affinity( the_thread, cpusetsize, cpuset );
       _Objects_Put( &the_thread->Object );
-      return error;
+      if (error)
+        return EINVAL;
+      return 0;
       break;
 #if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/posix/src/pthreadsetaffinitynp.c b/cpukit/posix/src/pthreadsetaffinitynp.c
index fc2194d..51aaee9 100644
--- a/cpukit/posix/src/pthreadsetaffinitynp.c
+++ b/cpukit/posix/src/pthreadsetaffinitynp.c
@@ -28,6 +28,7 @@
 #include <rtems/score/cpusetimpl.h>
 int pthread_setaffinity_np(
   pthread_t          id,
@@ -51,9 +52,12 @@ int pthread_setaffinity_np(
     case OBJECTS_LOCAL:
       api = the_thread->API_Extensions[ THREAD_API_POSIX ];
-      CPU_COPY( the_thread->affinity.set, cpuset );
-      CPU_COPY( api->Attributes.affinityset, cpuset );
+      error = _Scheduler_Set_affinity( the_thread, cpusetsize, cpuset );
+      if (!error)
+        CPU_COPY( api->Attributes.affinityset, cpuset );
+      if (error)
+        return EINVAL;
       return 0;
       break;
1.8.1.4
