[PATCH 07/10] posix: Move affinity from thread to scheduler.
Mon Mar 24 20:29:00 UTC 2014
On Mon, Mar 24, 2014 at 2:39 PM, Jennifer <jennifer.averett at oarcorp.com> wrote:
> From: Jennifer Averett <jennifer.averett at oarcorp.com>
>  cpukit/posix/src/pthreadcreate.c        | 14 ++++++++++++--
>  cpukit/posix/src/pthreadgetaffinitynp.c | 12 +++++-------
>  cpukit/posix/src/pthreadsetaffinitynp.c |  8 ++++++--
>  3 files changed, 23 insertions(+), 11 deletions(-)
> diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
> index 5a6d929..075a092 100644
> --- a/cpukit/posix/src/pthreadcreate.c
> +++ b/cpukit/posix/src/pthreadcreate.c
> @@ -32,6 +32,8 @@
>  #include <rtems/score/apimutex.h>
>  #include <rtems/score/stackimpl.h>
>  #include <rtems/score/watchdogimpl.h>
> +#include <rtems/score/schedulerimpl.h>
>  static inline size_t _POSIX_Threads_Ensure_minimum_stack (
>    size_t size
> @@ -196,8 +198,16 @@ int pthread_create(
>  #if defined(RTEMS_SMP)
>  #if __RTEMS_HAVE_SYS_CPUSET_H__
> -   the_thread->affinity.setsize   = the_attr->affinitysetsize;
> -   *the_thread->affinity.set      = *the_attr->affinityset;
> +   rc = _Scheduler_Set_affinity(
> +     the_thread,
> +     attr->affinitysetsize,
> +     attr->affinityset
> +  if ( rc != 0 ) {
> +    _POSIX_Threads_Free( the_thread );
> +    _RTEMS_Unlock_allocator();
> +    return EINVAL;
What is the condition this rc != 0 may occur, sine CPU_set_Is_valid() passed?
>  #endif
>  #endif
> diff --git a/cpukit/posix/src/pthreadgetaffinitynp.c b/cpukit/posix/src/pthreadgetaffinitynp.c
> index 082e41a..fd61af5 100644
> --- a/cpukit/posix/src/pthreadgetaffinitynp.c
> +++ b/cpukit/posix/src/pthreadgetaffinitynp.c
> @@ -28,6 +28,7 @@
>  #include <rtems/posix/pthreadimpl.h>
>  #include <rtems/posix/priorityimpl.h>
>  #include <rtems/score/threadimpl.h>
>  int pthread_getaffinity_np(
>    const pthread_t       id,
> @@ -46,14 +47,11 @@ int pthread_getaffinity_np(
>    switch ( location ) {
>      case OBJECTS_LOCAL:
> -      error = 0;
> -      if ( cpusetsize != the_thread->affinity.setsize )
> -        error = EINVAL;
> -      else
> -        CPU_COPY( cpuset, the_thread->affinity.set );
> +      error = _Scheduler_Get_affinity( the_thread, cpusetsize, cpuset );
>        _Objects_Put( &the_thread->Object );
> -      return error;
> +      if (error)
> +        return EINVAL;
> +      return 0;
>        break;
>  #if defined(RTEMS_MULTIPROCESSING)
> diff --git a/cpukit/posix/src/pthreadsetaffinitynp.c b/cpukit/posix/src/pthreadsetaffinitynp.c
> index fc2194d..51aaee9 100644
> --- a/cpukit/posix/src/pthreadsetaffinitynp.c
> +++ b/cpukit/posix/src/pthreadsetaffinitynp.c
> @@ -28,6 +28,7 @@
>  #include <rtems/score/cpusetimpl.h>
>  int pthread_setaffinity_np(
>    pthread_t          id,
> @@ -51,9 +52,12 @@ int pthread_setaffinity_np(
>      case OBJECTS_LOCAL:
>        api = the_thread->API_Extensions[ THREAD_API_POSIX ];
> -      CPU_COPY( the_thread->affinity.set, cpuset );
> -      CPU_COPY( api->Attributes.affinityset, cpuset );
> +      error = _Scheduler_Set_affinity( the_thread, cpusetsize, cpuset );
> +      if (!error)
> +        CPU_COPY( api->Attributes.affinityset, cpuset );
> +      if (error)
> +        return EINVAL;
>        return 0;
>        break;
> 1.8.1.4
> rtems-devel mailing list
> rtems-devel at rtems.org
