[PATCH 06/17] posix: Use thread action for signals
Tue Mar 25 12:49:10 UTC 2014
 cpukit/posix/include/rtems/posix/psignalimpl.h |   12 ++++++------
 cpukit/posix/include/rtems/posix/threadsup.h   |    5 +++++
 cpukit/posix/src/killinfo.c                    |    2 --
 cpukit/posix/src/psignal.c                     |   23 ++++++++++-------------
 cpukit/posix/src/psignalunblockthread.c        |    2 ++
 cpukit/posix/src/pthread.c                     |    5 +++++
 cpukit/posix/src/pthreadkill.c                 |    2 --
 7 files changed, 28 insertions(+), 23 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/psignalimpl.h b/cpukit/posix/include/rtems/posix/psignalimpl.h
index 17ce19f..81561e2 100644
--- a/cpukit/posix/include/rtems/posix/psignalimpl.h
+++ b/cpukit/posix/include/rtems/posix/psignalimpl.h
@@ -69,8 +69,6 @@ extern Chain_Control _POSIX_signals_Inactive_siginfo;
 extern Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
-extern API_extensions_Post_switch_control _POSIX_signals_Post_switch;
  *  Internal routines
@@ -86,10 +84,12 @@ void _POSIX_signals_Manager_Initialization(void);
 #define _POSIX_signals_Release( lock_context ) \
   _ISR_lock_Release_and_ISR_enable( &_POSIX_signals_Lock, lock_context )
-static inline void _POSIX_signals_Add_post_switch_extension(void)
-  _API_extensions_Add_post_switch( &_POSIX_signals_Post_switch );
+void _POSIX_signals_Action_handler(
+  Thread_Control  *executing,
+  Thread_Action   *action,
+  Per_CPU_Control *cpu,
+  ISR_Level        level
  * @brief Unlock POSIX signals thread.
diff --git a/cpukit/posix/include/rtems/posix/threadsup.h b/cpukit/posix/include/rtems/posix/threadsup.h
index e0b9ff5..46903fe 100644
--- a/cpukit/posix/include/rtems/posix/threadsup.h
+++ b/cpukit/posix/include/rtems/posix/threadsup.h
@@ -68,6 +68,11 @@ typedef struct {
   /** This is the set of signals which are currently pending. */
   sigset_t                signals_pending;
+   * @brief Signal post-switch action in case signals are pending.
+  Thread_Action           Signal_action;
   /***************         POSIX Cancelability         ***************/
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index fa4857d..5d3dded 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -121,8 +121,6 @@ int killinfo(
   _Thread_Disable_dispatch();
-  _POSIX_signals_Add_post_switch_extension();
    *  Is the currently executing thread interested?  If so then it will
    *  get it an execute it as soon as the dispatcher executes.
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index 731a230..0e2a018 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -25,6 +25,7 @@
 #include <rtems/score/isrlevel.h>
+#include <rtems/score/threadimpl.h>
@@ -108,22 +109,22 @@ Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
     (STATES_WAITING_FOR_SIGNAL|STATES_INTERRUPTIBLE_BY_SIGNAL)) == \
- *  _POSIX_signals_Post_switch_extension
-static void _POSIX_signals_Post_switch_hook(
-  Thread_Control  *the_thread
+  ISR_Level        level
   POSIX_API_Control  *api;
   int                 signo;
   ISR_lock_Context    lock_context;
   int                 hold_errno;
-  Thread_Control     *executing;
-  executing = _Thread_Get_executing();
-  api = the_thread->API_Extensions[ THREAD_API_POSIX ];
+  (void) action;
+  _Thread_Action_release_and_ISR_enable( cpu, level );
+  api = executing->API_Extensions[ THREAD_API_POSIX ];
    *  We need to ensure that if the signal handler executes a call
@@ -169,10 +170,6 @@ static void _POSIX_signals_Post_switch_hook(
   executing->Wait.return_code = hold_errno;
-API_extensions_Post_switch_control _POSIX_signals_Post_switch = {
-  .hook = _POSIX_signals_Post_switch_hook
   uint32_t   signo;
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index 2d6063b..c93dcfc 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -47,6 +47,8 @@ bool _POSIX_signals_Unblock_thread(
+  _Thread_Add_post_switch_action( the_thread, &api->Signal_action );
   mask = signo_to_mask( signo );
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 7968f17..d2e6373 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -233,6 +233,11 @@ static bool _POSIX_Threads_Create_extension(
     api->signals_blocked = SIGNAL_ALL_MASK;
+  _Thread_Action_initialize(
+    &api->Signal_action,
+    _POSIX_signals_Action_handler
   _Thread_queue_Initialize(
     &api->Join_List,
     THREAD_QUEUE_DISCIPLINE_FIFO,
diff --git a/cpukit/posix/src/pthreadkill.c b/cpukit/posix/src/pthreadkill.c
index dce646b..2e44dc6 100644
--- a/cpukit/posix/src/pthreadkill.c
+++ b/cpukit/posix/src/pthreadkill.c
@@ -53,8 +53,6 @@ int pthread_kill(
        *  If sig == 0 then just validate arguments
       if ( sig ) {
1.7.7
