[PATCH 07/17] score: Delete post-switch API extensions
Sebastian Huber
Tue Mar 25 12:49:11 UTC 2014
Use thread post-switch actions instead.
cpukit/score/include/rtems/score/apiext.h | 64 -----------------------------
cpukit/score/src/apiext.c | 11 -----
cpukit/score/src/threaddispatch.c | 1 -
3 files changed, 0 insertions(+), 76 deletions(-)
diff --git a/cpukit/score/include/rtems/score/apiext.h b/cpukit/score/include/rtems/score/apiext.h
index f281ab8..8382673 100644
--- a/cpukit/score/include/rtems/score/apiext.h
+++ b/cpukit/score/include/rtems/score/apiext.h
@@ -52,13 +52,6 @@ extern "C" {
typedef void (*API_extensions_Postdriver_hook)(void);
- * This type defines the prototype of the Post Switch Hook.
-typedef void (*API_extensions_Post_switch_hook)(
- Thread_Control *
* The control structure which defines the points at which an API
* can add an extension to the system initialization thread.
@@ -86,31 +79,10 @@ typedef struct {
} API_extensions_Control;
- * @brief Control structure for post switch hooks.
-typedef struct {
- Chain_Node Node;
- * @brief The hook invoked during each context switch in the context of the
- * heir thread.
- * This hook must not be NULL.
- API_extensions_Post_switch_hook hook;
-} API_extensions_Post_switch_control;
* This is the list of API extensions to the system initialization.
SCORE_EXTERN Chain_Control _API_extensions_List;
- * @brief The API extensions post switch list.
-SCORE_EXTERN Chain_Control _API_extensions_Post_switch_list;
* @brief Initialize the API extensions handler.
@@ -129,23 +101,6 @@ void _API_extensions_Add(
API_extensions_Control *the_extension
- * @brief Adds the API extension post switch control to the post switch list.
- * The post switch control is only added to the list if it is in the off chain
- * state. Thus this function can be called multiple times with the same
- * post switch control and only the first invocation will actually add it to the
- * list.
- * There is no protection against concurrent access. This function must be
- * called within a _Thread_Disable_dispatch() critical section.
- * @param [in, out] post_switch The post switch control.
-void _API_extensions_Add_post_switch(
- API_extensions_Post_switch_control *post_switch
#if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
* @brief Execute all pre-driver extensions.
@@ -162,25 +117,6 @@ void _API_extensions_Add_post_switch(
void _API_extensions_Run_postdriver( void );
- * @brief Runs all API extension post switch hooks.
-static inline void _API_extensions_Run_post_switch( Thread_Control *executing )
- const Chain_Control *chain = &_API_extensions_Post_switch_list;
- const Chain_Node *tail = _Chain_Immutable_tail( chain );
- const Chain_Node *node = _Chain_Immutable_first( chain );
- while ( node != tail ) {
- const API_extensions_Post_switch_control *post_switch =
- (const API_extensions_Post_switch_control *) node;
- (*post_switch->hook)( executing );
- node = _Chain_Immutable_next( node );
#ifdef __cplusplus
diff --git a/cpukit/score/src/apiext.c b/cpukit/score/src/apiext.c
index d4e67bf..3d9121d 100644
--- a/cpukit/score/src/apiext.c
+++ b/cpukit/score/src/apiext.c
@@ -25,7 +25,6 @@
void _API_extensions_Initialization( void )
_Chain_Initialize_empty( &_API_extensions_List );
- _Chain_Initialize_empty( &_API_extensions_Post_switch_list );
@@ -35,16 +34,6 @@ void _API_extensions_Add(
_Chain_Append( &_API_extensions_List, &the_extension->Node );
- _Chain_Append_if_is_off_chain_unprotected(
- &_API_extensions_Post_switch_list,
- &post_switch->Node
void _API_extensions_Run_predriver( void )
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index ae30c0c..ae69a5c 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -207,6 +207,5 @@ post_switch:
_Per_CPU_Release_and_ISR_enable( per_cpu, level );
- _API_extensions_Run_post_switch( executing );
_Thread_Run_post_switch_actions( executing );
1.7.7
