[PATCH 15/17] score: Relax Giant lock usage for API mutexes
Sebastian Huber
Tue Mar 25 12:49:19 UTC 2014
It is no longer necessary to protect the workspace allocations with the
Giant lock due to the thread life cycle re-implementation.
cpukit/posix/src/pthread.c | 2 +-
cpukit/score/src/apimutexlock.c | 4 ++++
cpukit/score/src/apimutexunlock.c | 5 +----
3 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 8d1a8eb..512cd70 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -227,7 +227,7 @@ static bool _POSIX_Threads_Create_extension(
&& _Objects_Get_class( created->Object.id ) == 1
#endif
- executing_api = _Thread_Executing->API_Extensions[ THREAD_API_POSIX ];
+ executing_api = _Thread_Get_executing()->API_Extensions[ THREAD_API_POSIX ];
api->signals_blocked = executing_api->signals_blocked;
} else {
api->signals_blocked = SIGNAL_ALL_MASK;
diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
index 91f6af3..d943bdd 100644
--- a/cpukit/score/src/apimutexlock.c
+++ b/cpukit/score/src/apimutexlock.c
@@ -43,4 +43,8 @@ void _API_Mutex_Lock(
0,
level
+ #if defined(RTEMS_SMP)
+ _Thread_Enable_dispatch();
+ #endif
diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
index 354033c..43bdfe8 100644
--- a/cpukit/score/src/apimutexunlock.c
+++ b/cpukit/score/src/apimutexunlock.c
@@ -27,10 +27,7 @@ void _API_Mutex_Unlock(
API_Mutex_Control *the_mutex
- /* Dispatch is already disabled in SMP while lock is held. */
- #if !defined(RTEMS_SMP)
- _Thread_Disable_dispatch();
- #endif
+ _Thread_Disable_dispatch();
_CORE_mutex_Surrender(
&the_mutex->Mutex,
the_mutex->Object.id,
1.7.7
