[PATCH 16/17] score: Use thread life protection for API mutexes
Tue Mar 25 12:49:20 UTC 2014
This prevents that asynchronous thread deletion can lead to an unusable
allocator or once mutex.
 .../arm/altera-cyclone-v/startup/nocache-heap.c    |   10 ++--
 c/src/lib/libbsp/shared/src/irq-generic.c          |   47 ++++++++++-------
 cpukit/libcsupport/src/malloc_get_statistics.c     |    8 ++-
 cpukit/libcsupport/src/rtems_heap_greedy.c         |   16 ++++--
 cpukit/rtems/src/regioncreate.c                    |    6 ++-
 cpukit/rtems/src/regiondelete.c                    |    6 ++-
 cpukit/score/include/rtems/score/apimutex.h        |   56 ++++++++++---------
 cpukit/score/src/apimutexlock.c                    |   11 +++--
 cpukit/score/src/apimutexunlock.c                  |    6 ++-
 cpukit/score/src/once.c                            |    4 +-
 cpukit/score/src/pheapallocate.c                   |    5 +-
 cpukit/score/src/pheapextend.c                     |    5 +-
 cpukit/score/src/pheapfree.c                       |    8 ++-
 cpukit/score/src/pheapgetblocksize.c               |    6 ++-
 cpukit/score/src/pheapgetfreeinfo.c                |    4 +-
 cpukit/score/src/pheapgetinfo.c                    |    6 ++-
 cpukit/score/src/pheapiterate.c                    |    4 +-
 cpukit/score/src/pheapresizeblock.c                |    6 ++-
 cpukit/score/src/pheapwalk.c                       |    4 +-
 19 files changed, 129 insertions(+), 89 deletions(-)
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c
index 0f01989..bf85c8f 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c
@@ -62,10 +62,11 @@ void altera_cyclone_v_nocache_init_heap( void )
 void *altera_cyclone_v_nocache_malloc( const size_t size )
   void* ret = NULL;
+  bool previous_thread_life_protection;
-  _RTEMS_Lock_allocator();
+  previous_thread_life_protection = _RTEMS_Lock_allocator();
   ret = _Heap_Allocate( &nocache_heap, size );
-  _RTEMS_Unlock_allocator();
+  _RTEMS_Unlock_allocator( previous_thread_life_protection );
   return ret;
@@ -79,10 +80,11 @@ void altera_cyclone_v_nocache_free( void *ptr )
   if ( ptr != NULL ) {
     bool ok;
     ok = _Heap_Free( &nocache_heap, ptr );
     assert( ok );
diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c b/c/src/lib/libbsp/shared/src/irq-generic.c
index e30372d..777454d 100644
--- a/c/src/lib/libbsp/shared/src/irq-generic.c
+++ b/c/src/lib/libbsp/shared/src/irq-generic.c
@@ -153,17 +153,23 @@ static void bsp_interrupt_free_handler_entry(bsp_interrupt_handler_entry *e)
   #endif
-static void bsp_interrupt_lock(void)
+static bool bsp_interrupt_lock(void)
   if (_System_state_Is_up(_System_state_Get())) {
+  } else {
+    previous_thread_life_protection = false;
+  return previous_thread_life_protection;
-static void bsp_interrupt_unlock(void)
+static void bsp_interrupt_unlock(bool previous_thread_life_protection)
+    _RTEMS_Unlock_allocator(previous_thread_life_protection);
@@ -208,6 +214,7 @@ static rtems_status_code bsp_interrupt_handler_install(
   rtems_status_code sc = RTEMS_SUCCESSFUL;
   rtems_interrupt_level level;
   rtems_vector_number index = 0;
   bsp_interrupt_handler_entry *head = NULL;
@@ -226,7 +233,7 @@ static rtems_status_code bsp_interrupt_handler_install(
   /* Lock */
-  bsp_interrupt_lock();
+  previous_thread_life_protection = bsp_interrupt_lock();
   /* Get handler table index */
   index = bsp_interrupt_handler_index(vector);
@@ -237,7 +244,7 @@ static rtems_status_code bsp_interrupt_handler_install(
   if (bsp_interrupt_is_empty_handler_entry(head)) {
     if (replace) {
       /* No handler to replace exists */
-      bsp_interrupt_unlock();
+      bsp_interrupt_unlock(previous_thread_life_protection);
       return RTEMS_UNSATISFIED;
@@ -257,7 +264,7 @@ static rtems_status_code bsp_interrupt_handler_install(
       bsp_interrupt_handler_table [index].info = info;
     } else {
       /* Handler table is full */
       return RTEMS_NO_MEMORY;
@@ -278,7 +285,7 @@ static rtems_status_code bsp_interrupt_handler_install(
        * Tried to install a unique handler on a not empty
        * list or there is already a unique handler installed.
       return RTEMS_RESOURCE_IN_USE;
@@ -301,7 +308,7 @@ static rtems_status_code bsp_interrupt_handler_install(
     if (replace) {
       /* Ensure that a handler to replace exists */
       if (match == NULL) {
@@ -311,7 +318,7 @@ static rtems_status_code bsp_interrupt_handler_install(
       /* Ensure the handler is not already installed */
       if (match != NULL) {
         /* The handler is already installed */
         return RTEMS_TOO_MANY;
@@ -319,7 +326,7 @@ static rtems_status_code bsp_interrupt_handler_install(
       current = bsp_interrupt_allocate_handler_entry();
       if (current == NULL) {
         /* Not enough memory */
@@ -348,13 +355,13 @@ static rtems_status_code bsp_interrupt_handler_install(
   if (enable_vector) {
     sc = bsp_interrupt_vector_enable(vector);
     if (sc != RTEMS_SUCCESSFUL) {
       return sc;
   /* Unlock */
   return RTEMS_SUCCESSFUL;
@@ -376,6 +383,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
@@ -395,7 +403,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
   /* Lock */
@@ -461,7 +469,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
       /* Check status code */
         return sc;
     } else {
@@ -478,12 +486,12 @@ static rtems_status_code bsp_interrupt_handler_remove(
   } else {
     /* No matching entry found */
   /* Unlock */
@@ -504,6 +512,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
   void *arg
   bsp_interrupt_handler_entry *current = NULL;
   rtems_option options = 0;
@@ -518,7 +527,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
   /* Lock */
   /* Interate */
@@ -533,7 +542,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
   /* Unlock */
diff --git a/cpukit/libcsupport/src/malloc_get_statistics.c b/cpukit/libcsupport/src/malloc_get_statistics.c
index a54a4c1..039baca 100644
--- a/cpukit/libcsupport/src/malloc_get_statistics.c
+++ b/cpukit/libcsupport/src/malloc_get_statistics.c
@@ -25,11 +25,15 @@ int malloc_get_statistics(
   rtems_malloc_statistics_t *stats
   if ( !stats )
     return -1;
   *stats = rtems_malloc_statistics;
   return 0;
diff --git a/cpukit/libcsupport/src/rtems_heap_greedy.c b/cpukit/libcsupport/src/rtems_heap_greedy.c
index 9a55e39..083a8e4 100644
--- a/cpukit/libcsupport/src/rtems_heap_greedy.c
+++ b/cpukit/libcsupport/src/rtems_heap_greedy.c
@@ -31,10 +31,11 @@ void *rtems_heap_greedy_allocate(
   void *opaque;
   opaque = _Heap_Greedy_allocate( RTEMS_Malloc_Heap, block_sizes, block_count );
   return opaque;
@@ -44,20 +45,23 @@ void *rtems_heap_greedy_allocate_all_except_largest(
   void *opaque;
   opaque = _Heap_Greedy_allocate_all_except_largest(
     RTEMS_Malloc_Heap,
     allocatable_size
   return opaque;
 void rtems_heap_greedy_free( void *opaque )
   _Heap_Greedy_free( RTEMS_Malloc_Heap, opaque );
diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
index 3b4325e..23d42fc 100644
--- a/cpukit/rtems/src/regioncreate.c
+++ b/cpukit/rtems/src/regioncreate.c
@@ -56,6 +56,7 @@ rtems_status_code rtems_region_create(
   rtems_status_code  return_status;
   Region_Control    *the_region;
   if ( !rtems_is_name_valid( name ) )
     return RTEMS_INVALID_NAME;
@@ -66,7 +67,7 @@ rtems_status_code rtems_region_create(
   if ( !id )
     return RTEMS_INVALID_ADDRESS;
-  _RTEMS_Lock_allocator();                      /* to prevent deletion */
     the_region = _Region_Allocate();
@@ -111,6 +112,7 @@ rtems_status_code rtems_region_create(
   return return_status;
diff --git a/cpukit/rtems/src/regiondelete.c b/cpukit/rtems/src/regiondelete.c
index 5144db0..b793dc6 100644
--- a/cpukit/rtems/src/regiondelete.c
+++ b/cpukit/rtems/src/regiondelete.c
@@ -33,8 +33,9 @@ rtems_status_code rtems_region_delete(
   Objects_Locations   location;
     the_region = _Region_Get( id, &location );
     switch ( location ) {
@@ -61,6 +62,7 @@ rtems_status_code rtems_region_delete(
         break;
diff --git a/cpukit/score/include/rtems/score/apimutex.h b/cpukit/score/include/rtems/score/apimutex.h
index 380f054..80ccabb 100644
--- a/cpukit/score/include/rtems/score/apimutex.h
+++ b/cpukit/score/include/rtems/score/apimutex.h
@@ -66,20 +66,26 @@ void _API_Mutex_Initialization( uint32_t maximum_mutexes );
 void _API_Mutex_Allocate( API_Mutex_Control **mutex );
- *  @brief Acquires the specified API mutex.
+ * @brief Acquires the specified API mutex.
+ * @param[in] mutex The API mutex.
+ * @return The previous life protection of the executing thread.
-void _API_Mutex_Lock(
-   API_Mutex_Control *mutex
+bool _API_Mutex_Lock( API_Mutex_Control *mutex );
- *  @brief Releases the specified API mutex.
+ * @brief Releases the specified API mutex.
- *  Releases the specified @a mutex.
- *  @param[in] mutex is the mutex to be removed.
+ * @param[in] previous_thread_life_protection The previous life protection of
+ * the executing thread.  Must be the value returned by the corresponding
+ * _API_Mutex_Lock() call.
-void _API_Mutex_Unlock( API_Mutex_Control *mutex );
+void _API_Mutex_Unlock(
+  API_Mutex_Control *mutex,
@@ -104,32 +110,28 @@ void _API_Mutex_Unlock( API_Mutex_Control *mutex );
 SCORE_EXTERN API_Mutex_Control *_RTEMS_Allocator_Mutex;
- *  @brief Macro to ease locking the allocator mutex.
- *  This macro makes it explicit that one is locking the allocator mutex.
-#define _RTEMS_Lock_allocator() \
-  _API_Mutex_Lock( _RTEMS_Allocator_Mutex )
+static inline bool _RTEMS_Lock_allocator( void )
+  return _API_Mutex_Lock( _RTEMS_Allocator_Mutex );
- *  @brief Macro to ease unlocking the allocator mutex.
- *  This macro makes it explicit that one is unlocking the allocator mutex.
-#define _RTEMS_Unlock_allocator() \
-  _API_Mutex_Unlock( _RTEMS_Allocator_Mutex )
+static inline void _RTEMS_Unlock_allocator(
+  _API_Mutex_Unlock( _RTEMS_Allocator_Mutex, previous_thread_life_protection );
 SCORE_EXTERN API_Mutex_Control *_Once_Mutex;
-static inline void _Once_Lock( void )
+static inline bool _Once_Lock( void )
-  _API_Mutex_Lock( _Once_Mutex );
+  return _API_Mutex_Lock( _Once_Mutex );
-static inline void _Once_Unlock( void )
+static inline void _Once_Unlock( bool previous_thread_life_protection )
-  _API_Mutex_Unlock( _Once_Mutex );
+  _API_Mutex_Unlock( _Once_Mutex, previous_thread_life_protection );
diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
index d943bdd..e506245 100644
--- a/cpukit/score/src/apimutexlock.c
+++ b/cpukit/score/src/apimutexlock.c
@@ -19,16 +19,17 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
 #include <rtems/score/apimutex.h>
+#include <rtems/score/threadimpl.h>
-  API_Mutex_Control *the_mutex
+bool _API_Mutex_Lock( API_Mutex_Control *the_mutex )
   ISR_Level level;
+  previous_thread_life_protection = _Thread_Set_life_protection( true );
   #if defined(RTEMS_SMP)
     _Thread_Disable_dispatch();
   #endif
@@ -47,4 +48,6 @@ void _API_Mutex_Lock(
     _Thread_Enable_dispatch();
   #endif
diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
index 43bdfe8..3814004 100644
--- a/cpukit/score/src/apimutexunlock.c
+++ b/cpukit/score/src/apimutexunlock.c
@@ -19,12 +19,12 @@
 #include "config.h"
 #endif
+  API_Mutex_Control *the_mutex,
@@ -34,4 +34,6 @@ void _API_Mutex_Unlock(
       NULL
+  _Thread_Set_life_protection( previous_thread_life_protection );
diff --git a/cpukit/score/src/once.c b/cpukit/score/src/once.c
index 60ae7a7..e51719c 100644
--- a/cpukit/score/src/once.c
+++ b/cpukit/score/src/once.c
@@ -25,7 +25,7 @@ int _Once( int *once_state, void ( *init_routine )( void ) )
   int eno = 0;
   if ( *once_state != ONCE_STATE_COMPLETE ) {
-    _Once_Lock();
+    bool previous_thread_life_protection = _Once_Lock();
      * Getting to here means the once_control is locked so we have:
@@ -49,7 +49,7 @@ int _Once( int *once_state, void ( *init_routine )( void ) )
         break;
-    _Once_Unlock();
+    _Once_Unlock( previous_thread_life_protection );
   return eno;
diff --git a/cpukit/score/src/pheapallocate.c b/cpukit/score/src/pheapallocate.c
index 4fefb85..057c2e9 100644
--- a/cpukit/score/src/pheapallocate.c
+++ b/cpukit/score/src/pheapallocate.c
@@ -30,15 +30,16 @@ void *_Protected_heap_Allocate_aligned_with_boundary(
   void *p;
     p = _Heap_Allocate_aligned_with_boundary(
       heap,
       size,
       alignment,
       boundary
   return p;
diff --git a/cpukit/score/src/pheapextend.c b/cpukit/score/src/pheapextend.c
index 18f1992..89c44c4 100644
--- a/cpukit/score/src/pheapextend.c
+++ b/cpukit/score/src/pheapextend.c
@@ -29,10 +29,11 @@ bool _Protected_heap_Extend(
   uintptr_t amount_extended;
     amount_extended = _Heap_Extend( the_heap, starting_address, size, 0 );
   return amount_extended != 0;
diff --git a/cpukit/score/src/pheapfree.c b/cpukit/score/src/pheapfree.c
index f87b824..f98fc77 100644
--- a/cpukit/score/src/pheapfree.c
+++ b/cpukit/score/src/pheapfree.c
@@ -27,10 +27,12 @@ bool _Protected_heap_Free(
   void         *start_address
-  bool    status;
+  bool status;
     status = _Heap_Free( the_heap, start_address );
   return status;
diff --git a/cpukit/score/src/pheapgetblocksize.c b/cpukit/score/src/pheapgetblocksize.c
index 5a6f703..367e8a3 100644
--- a/cpukit/score/src/pheapgetblocksize.c
+++ b/cpukit/score/src/pheapgetblocksize.c
@@ -29,9 +29,11 @@ bool _Protected_heap_Get_block_size(
   bool status;
     status = _Heap_Size_of_alloc_area( the_heap, starting_address, size );
   return status;
diff --git a/cpukit/score/src/pheapgetfreeinfo.c b/cpukit/score/src/pheapgetfreeinfo.c
index e442ba9..72bdb3e 100644
--- a/cpukit/score/src/pheapgetfreeinfo.c
+++ b/cpukit/score/src/pheapgetfreeinfo.c
@@ -31,9 +31,9 @@ bool _Protected_heap_Get_free_information(
    * TBD: _Heap_Get_free_information does not error check or return status.
+  bool previous_thread_life_protection = _RTEMS_Lock_allocator();
     _Heap_Get_free_information( the_heap, info );
   return true;
diff --git a/cpukit/score/src/pheapgetinfo.c b/cpukit/score/src/pheapgetinfo.c
index 6ece4e4..a0d0a3e 100644
--- a/cpukit/score/src/pheapgetinfo.c
+++ b/cpukit/score/src/pheapgetinfo.c
@@ -27,15 +27,17 @@ bool _Protected_heap_Get_information(
   Heap_Information_block  *the_info
   if ( !the_heap )
     return false;
   if ( !the_info )
     return false;
     _Heap_Get_information( the_heap, the_info );
   return true;
diff --git a/cpukit/score/src/pheapiterate.c b/cpukit/score/src/pheapiterate.c
index 9b6d945..6bea29f 100644
--- a/cpukit/score/src/pheapiterate.c
+++ b/cpukit/score/src/pheapiterate.c
@@ -32,7 +32,7 @@ void _Protected_heap_Iterate(
   void *visitor_arg
   _Heap_Iterate( heap, visitor, visitor_arg );
diff --git a/cpukit/score/src/pheapresizeblock.c b/cpukit/score/src/pheapresizeblock.c
index c733ddc..416485e 100644
--- a/cpukit/score/src/pheapresizeblock.c
+++ b/cpukit/score/src/pheapresizeblock.c
@@ -31,11 +31,13 @@ bool _Protected_heap_Resize_block(
   Heap_Resize_status status;
   uintptr_t          old_mem_size;
   uintptr_t          avail_mem_size;
     status = _Heap_Resize_block(
       the_heap, starting_address, size, &old_mem_size, &avail_mem_size );
   return (status == HEAP_RESIZE_SUCCESSFUL);
diff --git a/cpukit/score/src/pheapwalk.c b/cpukit/score/src/pheapwalk.c
index 5605470..6b18c77 100644
--- a/cpukit/score/src/pheapwalk.c
+++ b/cpukit/score/src/pheapwalk.c
@@ -38,9 +38,9 @@ bool _Protected_heap_Walk(
    * NOTE: Dispatching is also disabled during initialization.
   if ( _Thread_Dispatch_is_enabled() ) {
       status = _Heap_Walk( the_heap, source, do_dump );
   } else {
1.7.7
