[PATCH 14/17] score: Thread life cycle re-implementation
Gedare Bloom
gedare at rtems.org
Wed Mar 26 14:56:11 UTC 2014
On Tue, Mar 25, 2014 at 8:49 AM, Sebastian Huber
> --- a/cpukit/score/include/rtems/score/thread.h
> +++ b/cpukit/score/include/rtems/score/thread.h
> @@ -11,6 +11,8 @@
> * COPYRIGHT (c) 1989-2014.
> * On-Line Applications Research Corporation (OAR).
> + * Copyright (c) 2014 embedded brains GmbH.
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> * http://www.rtems.org/license/LICENSE.
> @@ -412,8 +414,47 @@ typedef struct {
> Chain_Control Chain;
> } Thread_Action_control;
> + * @brief Thread life states.
> + * The thread life states are orthogonal to the thread states used for
> + * synchronization primitives and blocking operations. They reflect the state
> + * changes triggered with thread restart and delete requests.
> +typedef enum {
> + THREAD_LIFE_NORMAL = 0x0,
> + THREAD_LIFE_PROTECTED = 0x1,
> + THREAD_LIFE_RESTARTED = 0x2,
> + THREAD_LIFE_PROTECTED_RESTARTED = 0x3,
> + THREAD_LIFE_TERMINATED = 0x4,
> + THREAD_LIFE_PROTECTED_TERMINATED = 0x5,
> + THREAD_LIFE_RESTARTED_TERMINATED = 0x6,
> + THREAD_LIFE_PROTECTED_RESTARTED_TERMINATED = 0x7
> +} Thread_Life_state;
I would prefer the present tense (restarting, terminating) instead of
the past tense for restarted and terminated. I think it is easier to
follow then, because the life state flags are set while the
restart/terminate is happening. Protected is fine.
> + * @brief Thread life control.
> typedef struct {
> + * @brief Thread life action used to react upon thread restart and delete
> + * requests.
> Thread_Action Action;
> + * @brief The current thread life state.
> + Thread_Life_state state;
> + * @brief The terminator thread of this thread.
> + * In case the thread is terminated and another thread (the terminator) waits
> + * for the actual termination completion, then this field references the
> + * terminator thread.
> + Thread_Control *terminator;
> } Thread_Life_control;
> @@ -486,9 +527,10 @@ struct Thread_Control_struct {
> * thread and thread dispatching is necessary. On SMP a thread dispatch on a
> * remote processor needs help from an inter-processor interrupt, thus it
> * will take some time to complete the state change. A lot of things can
> - * happen in the meantime.
> + * happen in the meantime. This field is volatile since it is polled in
> + * _Thread_Kill_zombies().
> - bool is_executing;
> + volatile bool is_executing;
> #if __RTEMS_HAVE_SYS_CPUSET_H__
> diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
> index 2e31753..9166e9d 100644
> --- a/cpukit/score/include/rtems/score/threadimpl.h
> +++ b/cpukit/score/include/rtems/score/threadimpl.h
> @@ -11,6 +11,8 @@
> * COPYRIGHT (c) 1989-2008.
> @@ -194,6 +196,8 @@ bool _Thread_Restart(
> Thread_Entry_numeric_type numeric_argument
> +bool _Thread_Set_life_protection( bool protect );
> void _Thread_Life_action_handler(
> Thread_Control *executing,
> Thread_Action *action,
> @@ -201,17 +205,9 @@ void _Thread_Life_action_handler(
> ISR_Level level
> - * @brief Frees all memory associated with the specified thread.
> - * This routine frees all memory associated with the specified
> - * thread and removes it from the local object table so no further
> - * operations on this thread are allowed.
> -void _Thread_Close(
> - Objects_Information *information,
> - Thread_Control *the_thread
> +void _Thread_Kill_zombies( void );
> +void _Thread_Close( Thread_Control *the_thread, Thread_Control *executing );
Add doxygen for these two functions. Can be done in separate patch.
> * @brief Removes any set states for @a the_thread.
> @@ -710,6 +706,34 @@ RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action(
> _Thread_Action_release_and_ISR_enable( cpu, level );
> +RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarted(
> + Thread_Life_state life_state
> + return ( life_state & THREAD_LIFE_RESTARTED ) != 0;
> +RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminated(
> + return ( life_state & THREAD_LIFE_TERMINATED ) != 0;
> +RTEMS_INLINE_ROUTINE bool _Thread_Is_life_protected(
> + return ( life_state & THREAD_LIFE_PROTECTED ) != 0;
> +RTEMS_INLINE_ROUTINE bool _Thread_Is_life_change_requested(
> + return ( life_state & THREAD_LIFE_RESTARTED_TERMINATED ) != 0;
And also doxygen for these functions, and consider using the present
tense for restarting, terminating
Otherwise this looks OK to me.
Gedare
